Question about Cycling
I tightened my chain by pulling my bike tire back and tightening the bolts and now every-time i pedal it either gets extremely loose or extremely tight depending on the angle of the crank pedals i dont know what else to do
  • 57 Answers
Does your bike have a derailuer? (gears) If so, check that the chain is running though it correctly. Also check that your wheel is aligned correctly, you can check this by simply lifting the rear wheel off the ground and spinning it. If the wheel rubs on your frame, then simply loosening the bolts and tightening them up when the wheel is straight should fix the problem.
Cheers.
Posted on Jul 03, 2010
Can you adjust the tension on the wheel?
What sort of tension?
Rim loose on spokes: evenly tighten the spokes to add tension ( very high skill required to keep the rim true. Pro help should be sought)
Too much wheel side play: tighten the wheel to frame axle bolt (unless the bearing is gone, then you'll need new hub bearings).
Chain tension too loose: Move the rear wheel away from the pedals by loosening the axle bolt, pulling back to remove most (but not all) or the slack from the chain. Pay attention to the alignment of the wheel in the frame. Tighten the nuts back down
Feb 17, 2015 | Cycling
Seems to petal to hard ??
Easy answer? Check you tire inflation.
More complex? It could be a number of things starting with your chain too tight. Have someone hold the back of the bike up and turn the crank to see if it turns easy. Take note of the chain; at some point when turning slowly you should see it/feel it loosen. If it seems really tight undo your rear axle bolts and adjust the chain so it has about a quarter inch of slack. Make sure that the wheel is centered before you tighten the bolts back down.
This also could be a problem: the back wheel wasn't secure and it is rubbing on the frame. Center the tire between the frame and tighten the bolts.
If all that is OK then it could be bad or over tight bearings.Then it is really bike shop time.
Mar 19, 2013 | Huffy 26 in. Cranbrook Cruiser Bike
Chain coming loose
Yes. Loosen the two nuts on the back wheel. When they are loose just pull the wheel back until the chain is tight enough and tighten nuts while holding the tire in the proper position at the proper tightness of the chain. Make sure that the tire is running true when tightened.
Jun 24, 2012 | Dynacraft Cycling
On mountain bike the chain or peddles seem to slip or click goning up a hill. Is it the chain slipping or worn gear?
It sounds like your chain is loose. Flip the bike over and loosen up the nuts on the back tire and tighten the nuts as you are pulling the rim back making the chain as tight as you can. You might need someone to help you pull as you tighten the nuts.
Aug 26, 2011 | Cycling
My new moongoose mischief keeps getting loose chain and pedals, ive tightend it up sevral times but keeps doing it, and the pedals keep loosening from the body??? anyone know how to solve this/
My first thought about the chain continuuin to become loose, is that you need to loosen the nuts on the back wheel, and pull the wheel (while the chain is still attached to bot hsprockets) in order to remove any slack. If it's a continuous issue, chances are that back tire keeps migrating forward because those nuts aren't tight enough.
To the pedal issue-If the pedals are wobbling or vibrating because the aren't snug while on the pedal bar (the bar that the pedals revolve around) it is probably because the peddals are too large. Try buying a new set of pedals. If they are loose and trying to slip off of the pedal bar and if you have tightened the nuts that keep the pedal on the pedal bar and they are continuing to become loose, it could be that you need to use locking nuts.
A quick fix to solving loose pedals is to add washers to the end of the bar until the washers are flush up against the pedal and the nut.
Happy pedaling!
Mar 23, 2011 | Mongoose Mischief Mag BMX Bike
I need to tighten the chian on my schwinn airdyne.
Two places to tighten the chain and it requires you to loosen the nuts on BOTH sides of the bike, almost at the same time. Start at the fan wheel (top) of the bike. First thing you need to do is to loosen the little nut at the hub of the fan wheel on both sides. Unscrew it almost to the point of taking it off, but leave it screwed on the end of the bolt so it will stay on the bike. Then use an adjustable wrench to loosen the nut a bit on one side and then do the same on the other side OR use both hands and loosen both at the same time by unscrewing with adjustable wrench in opposite directions on both sides. Once the wheel is loose, you want to sit in front of the bike and pull both of the large nuts at the same time toward you and the chain will tighten. The goal is to have the fan wheel centered and for you to be able to see about 1/4" inch of clear gap behind the nut on both sides. Then use your fingers to tighten the nuts to the frame just enough until you can use the adjustable wrench again. I have sometimes used a flat head screwdriver to insert into the gaps to prevent the chain from loosening up. The tighten the nut on both sides of the bike. Be sure you tighten the little nuts as well (they are called chain tensioners). That SHOULD do the trick. However, if your bike chain is still too loose, you need to do the same for the chain at the pedal area, That requires the same thing all over again, but in most cases, the chain loosens at the top part of the bike (fan wheel place). However, if you do work on the pedal area, you want the chain to be pushed toward the fan and not toward the **** side of the bike. It may sound crazy but that's the only way to tighten the chain. give me a thumbs up with my solution.
Feb 18, 2011 | Schwinn Original Airdyne
Chain is to loose. How do I tighten the chain tension?
LOOSEN THE 2 BOLTS HOLD WHEEL ON PULL BACK ON WHEEL WHILE TIGTHEN BOLTS BACK UP. CHAIN DONT HAVE TO BE SUPER TIGTH . ABOUT 3/4 OF SLACK IN CHAIN.
Nov 18, 2010 | Schwinn Scwhinn 26 Inch Womens Coronado...
How to tighten a loose chain
To tighten a loose chain you need to pull the cotter key pin from the rear axle then loosen but do not remove the nut. It just has to be loose enough to slide in the swingarm. At this point there are tension adjusters on the ends of the swing arm you tighten them to take the slack out of the chain. NOT TO TIGHT! You should have 1 inch of play in the chain this is up down play not front to back. I push the chain up the highest it can go and measure how far it falls. NOTE: TURN THE TENSION ADJUSTERS THE SAME AMOUNT THE SAME DIRECTION IF THE AXLE IS TWISTED YOU WILL THROW THE CHAIN. This can make for a bad six months!
Aug 19, 2009 | 1998 Suzuki VZ 800 Marauder
Loose chain
Loosen the Back Nuts on the Side of the Rear Wheel, Then use a Wrench to Turn the Bolts extending out the Rear of the Bike in Clockwise to pull the Rear Wheel Back, Thus Tacking Slack out of the Chain. Do Not over Tighten as the CHain Tightens some itself with Flex when you put Weight on it. Retighten Axle Nut. Thats it.
Apr 25, 2009 | 2002 kawasaki VN 800 Vulcan Classic
Bicycle Chain Problem
Your chain problem is probably because your chain is not tightened and maintained.
You should clean your chain after a ride, and oil it (very little oil).
Good luck
Oct 29, 2008 | kawasaki 73026-9 KDX126FS Dual Suspension...
Cycling Logo
96 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
