Outside unit freezes up - Heating & Cooling
  • 29 Answers
The unit must be in heating...
when we heat the room we effectively refrigerate outside to gain heat and put it to the indoor unit, hence the outdoor coil freezes up, it should defrost every now and then but each unit is individual..
check your settings
cheers
Posted on Jul 05, 2010
We have a Goodman AC Unit and the pipe continues to freeze.
either the inside coil is dirty or system is overcharged.
May 14, 2014 | Goodman CLQ36AR49 Air Conditioner
Outside unit freezing
Hi there well it sounds like you got a R22 gas leak thats all
Dec 09, 2013 | Soleus Mini Split Air Conditioner
I have noticed my heat pump is freezing up on the outside unit, we have had freezing rain and snow the last 2 days but I have never noticed ice accumulation on the outside of the unit, it also seems like...
In freezing weather the heat pump efficiency drops. The freezing is normal. The equipment has a board and sensor to defrost your heat pump. Now this system can fail but freezing rain and snow get pulled into the unit get pulled into the unit coil and freeze blocking airflow. You can defrost the unit by turning it to cooling. This is what the defrost board does automatically.
Dec 27, 2012 | Goodman Heating & Cooling
My A/C freezing its coils, while the fans keep running. The AC unit (outside) keep running and never stop caused the coils freezing. It doesn't matter when I turn off or set it to Cool position, the...
Sounds like the contactor in the condensing unit is stuck. That is why it will not turn off when the thermostat is satisfied. If the inside air handler is not blowing and the outside condensing unit is running, then this will cause the inside coils to freeze up rather quickly.
The contactor is located in the outside condensing uni in the electrical compartment.
If it is sticking it will need to be replaced.
Sep 07, 2011 | Heating & Cooling
Unit set to heat but outside unit fan won't turn on. Outside temp is below freezing. The weird thing is that you unit is putting out heat and not set to emergency heat
If it is a heatpump, the outside unit should not turn on below 35degrees or so. Below that temperature, the unit cannot effeciently exchange heat. When the outside temperature is low, the system automatically switches over to auxillary heat which uses the same heating elements as emergency heat.
Jan 11, 2011 | Ruud Heating & Cooling
Not cooling, water is leaking around the outside unit. plus ice has formed around hose on the unit outside. goodman model number gsh130421ac.
take a garden hose and wash the unit real good,if the unit outside cant breath this will cause it to freeze up
May 16, 2010 | Goodman CKL36AR36 Air Conditioner
Fujitsu ASU12C1 is freezing up
unit is freezing up because it either has too much freon or not enough. the pressure should be checked on both the low and high sides and corrected.
Jun 13, 2009 | EMI EHW 18000 Air Conditioner
Small pipe running from outside unit freezing up
SOUNDS LIKE THE FAN SPEED MAY BE TO LOW SO AS THE AIR GOES THROUGH THE COIL IT WILL START TO FREEZE HAVE SOMEONE CHECK THE FAN SPEED MAKE SURE IT IS ON HIGH ALSO MAKE SURE IF THAT IS THE ONLY FILTER ON THE SYSTEM
May 03, 2009 | Heating & Cooling
Outside unit freezing over
check the outside drain in the pan if there is a plug in the bottom pull it out.the ptac unit will go into emergency heat and run more the colder it gets outside
Nov 23, 2008 | Amana PTH123B25AJ Heat Pump Air...
Goodman Model CK60-1C with White Rogers mercury tube thermostat
The contactor on the outside unit is sticking and must be replaced. The inside unit cycles off and the outside continues to run causing the refrigerant lines to freeze up.
Jul 29, 2008 | Goodman CKL60AR60 Air Conditioner
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
