Question about Motorola Mobility RAZR V3i Cellular Phone
Battery backup problem
Battery discharger After 15 to 20 call of 2 minites,we change battery. tell how to solve
  • 32 Answers
If ur mobile problem is heat then circuit short
Posted on Jul 03, 2010
The power wents off and the batery got completly discharged , then i turn it on and run the self test and replace icon staid illminate but in the next self test didn't, i hace to replace the battery?
First tell how old is your UPS ?
if its older by two to three years may be the Battery eeds a replacement .Try charging the battery externally with a good battery chargers but before charging externally please take out the battery outside.
Then if the battery shows very low voltage even after charging for some 8 hours then you have one alternative that is replace with new battery.and promptly keep it under charge with out fail.
Aug 16, 2014 | Tripp Lite G1000U Intelligent LCD 1000VA...
APC Back-UPS rs900 Not working
It could be DOA. The battery may have discharged completely and was left discharged for some time
Jul 24, 2013 | APC Computers & Internet
Apc 10kva SUVT10KH4B4S problem after changing battery
please you know your topology change battery
Jul 22, 2013 | Computers & Internet
How can I replace backup battery, Every time that the rechargeable battery is removed we lost the setting for WLAN and GTL scanner program
Hi
When you set the wireless profile you set the SSID, WEP, IP etc. Which I'm sure you already know. Now you want to make them persist through either a cold boot or when the terminal has been left without a battery for a substantial amount of time.
This can be done 2 ways. When the profile has been set up highlight it by holding down the stylus on it and from the menu select export. This saves the registry key to the Application folder; a folder which persist through a cold boot. When it does cold boot it takes all the registry keys from the Application folder and builds 1 complete key.
The other way is to close the WLAN profile and selection options, from the pull down menu select export and save all profiles.
The GTL scanner program, I don’t know what this is, but you could use Motorola Start up Control to mange the program. It has a function to restore programs after a cold boot or reset.
Hope this helps.
If you need any more help then please do not hesitate to contact us:-
http://www.biastechnology.com/
or TEL 01202 620955
Dec 04, 2009 | Symbol MC9090 Mobile Computer Portable...
Change the backup battery in MC9060
Hello mis1539. I think I can help you here. First: are you sure the backup battery is defunct? Bear in mind that the backup battery takes about 15 hours to fully charge and will discharge if the main battery or power source is disconnected or goes completely dead for anywhere from 30 minutes to a few hours. If the backup battery discharges, the process starts all over and the backup battery will need to be charged for 15 hours again. If you think the backup battery may have discharged at some point, it could be that it never full re-charged so it will discharge and lose your settings (cache/flash memory) almost instantly. It is worth mentioning that about 95% of my clients that have this problem have fixed it by simply making sure that the unit is in it's cradle, with the battery in and charging overnight to fully recharge the backup. Again, I really would implore you to give this a shot before resorting to cracking open the unit and getting to the backup battery (which is no fun task, I assure you). If this doesn't work for you, please let me know and I can help you further. I hope this solves your problem. Good luck!
Sep 23, 2009 | Symbol MC9090 Mobile Computer Portable...
How do I prevent loosing data when my battery discharges
Hi. Actually, on pocket pcs there's a backup battery onboard, but in your case maybe backup battery is dead. So you can have that changed or you can charge your PDA on regular basis. Hope this helps.
Jun 28, 2009 | Toshiba e355 Pocket PC
HOW TO CHANGE OR CHARGE THE BACKUP BATTERY?
y hp6365 keeps telling me that i my backup battery is low..i keep charging my phone but the only the main battery is charging..how do i charge or change the backup battery?
Feb 17, 2009 | HP iPAQ h6315/h6365 Pocket PC
Battery charging problem
well, the charging voltage is the right one, you may have a problem with charger board, did you check that? tbe 2 big capacitators, maybe you will need to change them, there could be a couple of things, and to be honest i don´t have the circuits sheets, cause i stopped working with powerware.
good luck.
Jul 29, 2008 | Computers & Internet
Garmin IQue M5
Make a sprite backup to an SD card before changing battery. If you lose data just restore it from the backup.
May 31, 2008 | Garmin iQue M5 GPS Receiver
Motorola Mobility RAZR V3i Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
