Question about GPX MW6347DT MP3 Player
The battery is dead and it won't come back on
My U200E won`t charge unless it`s completely dead and the touchscreen won`t work anymore
Hi Bell, please don;t panic. Let us try to solve it.
> remove -- and don't replace -- the battery, than connect the charger and turning on the Laptop.
> also check the charging LED is turned On.
> if its working than check the battery else check the charger.
Feel free to revert back if issue not resolve.
Thanks
Nov 07, 2013 | ASUS Computers & Internet
12 RES - Control Panel Dead With New Battery
If it won't start in manual, you have a short and/or a bad control board. Make sure battery polarity is correct, did you disconnect battery charger before removing old battery? If not charger can push DC volts over 20V and can damage control board.
May 26, 2013 | Kohler Electrical Supplies
Key won't turn, won't shift from Park
My 2003 Saturn l200 2.2 ecotec did this when the battery was dead. Put some juice on the battery, then the car came out of park, and I was able to remove the key. To the car, there's a vast difference between a sluggish battery and a dead battery. It may have enough amps to crank it, but it wont start w/out full output from the battery.
Apr 12, 2013 | 2004 Chevrolet Cavalier
Blueparrrot B250 is 1 year old & it went dead so I
how do you know it is fully charged? i think it may be dead battery
Nov 06, 2012 | Computers & Internet
My 2004 ford expedition won't turn over, it make a
You need to have the battery tested and the battery cables looked at, both symptoms you have are from a dead battery or a defective battery or dirty corroded battery cables. Autozone tests batteries for free as well as other stores like Sams club.
Sep 18, 2012 | Cars & Trucks
Laptop Battery Won T Charge on a laptop dell inspiron 1525
Battery could be dead and won't hold another charge. Batteries only last for so long until you have to replace them. If you laptop is ok with the AC Adapter & Power Cord meaning it boots and allows you to work in windows, then the battery is definitely dead.
Mar 19, 2012 | Dell Computers & Internet
The car was running fine one day then the next day it would not start. We tried jumping it thinking the battery might be dead and it still would niot start. The car has power until we take the jumper...
Sounds like you have a toasted battery or alternator. Have you performed a load test on the battery? Have you tried to charge the battery? First remove the battery and charge it externally from the vehicle. If the battery won't hold a charge, or won't hold a charge of 12 volts, replace it. Once you have the vehicle started, test the operation of the alternator. It should be putting out at least 13 volts back to the battery to keep it charged - if it is putting less than 13 volts or more than 16 volts, replace the alternator.
Nov 01, 2011 | 2005 Chevrolet Malibu
My laptop won't turn on..it goes dead and doesn't turn back on..Is there some procedure to help this..its an acer aspire 5532..
When you say it goes dead are you saying the batteries die because if so you do realize they have to be charged once in awhile right? If you do know that and were serious about the problem try removing the battery for a minute then replace battery and restart see if that helps!
Good luck!!!
Jun 08, 2011 | Computers & Internet
GPX MW6347DT MP3 Player Logo
20 people viewed this question
Top GPX Audio Players & Recorders Experts
Tequella Chapman
Level 1 Expert
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
