Question about Maytag Neptune MDE5500AY Electric Dryer
I have a Magtag Neptune MDE550AYQ electric dryer. Inside the tumbler (where the clothes are dried) there are three arms that turn the clothes. One of these are loose and make noise as the dryer turns. What is the best approach to to tighten the screws that hold the arm on?
  • Maytag Master
  • 3,053 Answers
Hello, I was trying to help you out here. I wasgoing back to some customers that asked questions in the past and it appearedthat no one answered them, so I thought I would take some of my personal timeto see if I can help. Here is a link to about everything you want to know aboutyour dryer, from repair to trouble shooting it. If you go to this link andclick around, I am sure you will find out so much about your dryer, you willknow more that the company that made it. Here Is the link for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helped you at all, if youcan find the time to rate my help and some kind words written would beappreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
Posted on Oct 26, 2011
I bought it in 2003 neptune dryer and the 3 bar inside the dryer broke and the dryer is not working right . we have to dry them 3 time before they are all dry
Instructions
Things You'll Need:
* Phillips-head screwdriver
* Replacement belt
1. Disconnect the power cord of the Maytag Neptune dryer from the dryer electrical outlet.
2. Open the dryer door, and locate the four screws on the inside lip of the door opening. Use a Phillips-head screwdriver to remove the four screws. This will disconnect the front panel from the shroud assembly.
3. Grab the front panel on each side with your hands. Lift up on the front panel to unhook it from the retaining tabs on the side panels. Remove the front panel, and set it out of your way.
4. Use a Phillips-head screwdriver to remove the four outside perimeter screws that secure the shroud and tumbler front to the dryer cabinet. Pull the shroud and tumbler front away from the tumbler while lifting the top panel partially up.
5. Reach both of your hands underneath each side of the tumbler. Use your left hand to grasp the idler pulley, and pull it to the left while using your right hand to slip the belt off the motor pulley. Pulling the idler pulley to the left releases tension on the belt. You can now slip the belt off the back of the tumbler.
6. Take the old belt with you along with the model number of your dryer to purchase a new belt. Most appliance repair shops will have replacement belts in stock. Make sure that the new belt matches the old one by comparing the two.
7. Slide the new belt over the rear of the tumbler with the ribbed side pointed to the inside. Using both hands under the tumbler, route the belt around the motor pulley and idler pulley. Pull the idler pulley to the left while routing the belt, and carefully allow the idler pulley back to the right to apply tension.
8. Reattach the tumbler front and shroud to the front of the cabinet using the retaining screws. Place the front panel over the side retaining tabs, and push it down to lock it in place.
9. Open the dryer door, and secure the front panel to the shroud using the retaining screws. Close the dryer door, and plug the power cord back into the dryer electrical outlet.
Feb 28, 2011 | Maytag Neptune MDE5500AY Electric Dryer
How do i get the top open on the dryer so i can get to the drum to tighten the screws that hold the rails in place that are inside the drum to keep the clothes turning over
  1. Remove 4 screws with #2 philips screwdriver to remove door
  2. Remove door
  3. Pull top of front panel out and lift up off of 2 tabs
  4. This will expose the drum to allow you to tighten the tumblers
Dec 04, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I have a Magtag Neptune dryer that recently began taking a long time to dry the clothes. I noticed that the exhaust hose was not very secure at the dryer and there was a lot of excess lint could that cause...
a vent hose that is full of lint or clogged/restricted will cause the dry to take longer to dry or leave the clothes damp. if you clean/get the hose unrestricted this should rectify the problem. Hope this helped tim
Sep 01, 2010 | Maytag Dryers
Neptune glass front takes 4 hours to dry clothes.
make sure the vent system is clean. any restrictions can cause the safety switches to activate and turn off heaters. When it cools, the switch resets and starts heating. Unit will continue to cycle the heat off and on. Make sure all elements are working.
Start there.
Jun 07, 2010 | Maytag Neptune MDE6700A Electric Dryer
My 8yr old Magtag PYET244AYW dryer is getting worse...
check the air flow at the exhaust,
you should have a good and steady flow while the dryer is running.
sometimes cloggs happen in the middle of the exhaust line
Oct 05, 2009 | Maytag PYE2300AY Electric Dryer
Rattle inside dryer drum
remove the front cover and then you can access the top cover screws to open top then you can locate and tighten screws
Jul 27, 2009 | Maytag Neptune MDE5500AY Electric Dryer
How to install moisture sensor bar on Maytag Neptune
I do not recognize that part number but an exploded diagram for the dry is at;
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47833
Click on the tumbler diagram.
Mar 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag gas dryer runs, doesn't dry
Check in the hole where the screen goes for blockage. Many times debries falls in there when removing screen. It cant make it out of the vent so it builds up and clogs the vent.
Dec 01, 2008 | Maytag Neptune MCG8000AW Gas Dryer
DRUM/TUMBLER ISSUE
look at the rollers of the drum, it could have been dameged already and needs to be replaced.
Mar 21, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Neptune dryer
sounds like one of your tumbler veins inside the drum is loose. there should be two or three screws holding them in
Nov 20, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
219 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
