Question about Car Audio & Video
How to cut hole in expedition and install trim to cover edges
    Problem Solver:
  • 8 Answers
Depends were you want your speaker, Rules of thumb
1) Do not cut steel frame more than 20% larger than nearest hole
2) Use pods/spacers to mount you speakers into this way you can put in larger, different shaped, custom designed enclosures, etc that do little damage to original trim and can be removed later if you so chose.
Assuming that you are putting speakers in to front door panels:
Remove door trimming and take note of removed components (Take pic's as you go it's easier)
Compare original speaker to new ones (in particular the depth of the cone) Factory tend to be shallow while after market ones deeper for better sound. Note depth difference.
Try your new speaker in the rough location you want it and wind down your window all the way and see if it will interfear with the mechanisms of the door. If it clears everything your laughing and just have to unscrew the old and replace with the new or...
Now the fun bit do the math on how much the difference is and how much you will have to space it out for it to fit into the door with out interfering with it's components, decide if you can deal with the speaker sticking out as far as it has to to fit, or can it be put in a different location. (Have a friend or family member help you with this so your hands are free to sit in your seat and feel it out, no point in putting it in if your not going to be happy with the end result)
Once your happy with your positioning make a blank up of a pod out of MDF (NOTE: MDF when cut/sanded creates toxic dust use appropriate Respiratory Protective Equipment (R.P.E.) such as a P2 paper mask as well as Personal Protective Equipment (P.P.E.) e.g. safety glasses, hearing protection and gloves) to make a shape that blends in with your doors contours and has a hole big enough for your new speaker to fit into. Dose not have to be perfect just yet as you shall have to mold it to suit what you want it to look like. Take your time and sit it in place till you are happy with the shape and placement. Make sure door closes and opens with pod.
Use this Blank to cut out a second pod just like this one (for the other door)
Shave off sharp corners
Match fabric to door trim (or go all out and highlight it in a contrasting cloure/pattern/texture)
If fabric stretch it over pod and staple into place (better yet glue some thin foam to pod first then use some spray addehisive to attach fabric to foam then stapel behind the pod to hold securely)
Vinal is a different story and requires spray adhesive heat and working it into position then stapling.
Good Idea to place speaker cage into place and secure to hold fabric around it. (Cut away excess in both cased inside cage and behind pod for a flat joining)
Mount speaker to pod and lay pod on a table placing door trim over it. Maneuver to correct position and use correct sized screws to join them together.
Connect wires
Test speaker
Replace modified door trim on to door
Repeat on opposite door
Fin.
Posted on Jul 03, 2010
Triumph 955i air filter box has been altered by cutting two holes 60x50mm in the top under the tank i think to increase air flow
It could be for increase air flow.
S & S stated they picked up about 3 hp by trimming 1/4" off the back edge of their air filter teardrop cover.
Aug 04, 2013 | 2002 Triumph Daytona 955i
HOW CAN I CHANGE THE SHIFT KNOB ON MY 2000 FORD EXPEDITION
The shift knob is part of the shifter handle. The overdrive shift button assembly and button cover are replacable seperately. To remove the button, simply pry off the cover, pull out the button and replace. reverse the order to assemble.
To remove the shift handle, remove the ignition cylinder by turning to the run position and pushing a small pin, drill bit or allen wrench into the hole on the bottom of the trim cover hole to release the ignition cylinder. Pull the cylinder out. Next remove the screws from the bottom column trim cover and remove the upper trim. Next, remove the pin from the shifter and disconnect the electrical connector. Replace the shifter and reassemble. Good luck, please ask for more information if you can't leave four thumbs up. Have a great day!
Apr 12, 2011 | 2000 Ford Expedition
How do I lay lino round the base of the toilet?
Mark out and cut the base of the bowl size, using a old Cornflakes packet is useful, cut the hole and behind the bowl part of the cardboard test piece cut to the edge in a straight line. The cardboard will now open (a bit like a keyring) and alow the cardboard cut out hole to be placed around the base of the toilet bowl. Trim it to fit perfectly.
When you have the exact size in you cardboard cornflakes packet, transfer the cut out on to your lino, cutting in a straight line at the rear of the lino where is will not be seen, to allow fitting over the bowl. Trim your lino edges and there you have it, lots of scrap cardboard but a professionally fitted lino floor covering.
I hope that helps.
Feb 03, 2011 | Microwave Ovens
Can the hand-held shower hose be replace without accessing the plumbing underneath the tub? I can't figure out how to disconnect the existing hose from the diverter without cutting an opening under the...
No, you need to cut a hole. Usually an access panel is provided during the initial installation, either in the ceiling from downstairs or in the other side of the adjacent wall. But it's pretty easy to add one. After you cut a nice rectangular hole, you can cover it with a piece of painted plywood that has a trim piece attached to the plywood. The plywood is held in place with a couple of screws. When you remove the panel, the trim stays attached to the plywood. When you place the panel in the hole, the trim covers the gap between the drywall and the plywood.
Dec 01, 2010 | Grohe 25 597 Talia Tub Filler w/Personal...
How to replace rear blower motor motor in 2006 chrysler town and country van
from autozone.com:
Removal & Installation
  1. Disconnect and isolate the negative battery cable.
  2. Remove the right quarter trim panel as follows:
    1. Remove first rear seat. Remove the second rear seat, if equipped.
    2. Remove the sliding door sill plate.
    3. Remove the quarter trim bolster.
    4. Remove the upper C-pillar trim and D-pillar trim panel.
    5. Remove the first and second rear seat belt anchors.
    6. Remove the screws securing the quarter trim to quarter panel from the bolster area.
    7. Remove the screws securing the rear edge of the quarter trim to the support bracket.
    8. Carefully disengage the hidden clips securing the front of the quarter trim to the quarter panel just rearward of the sliding door opening.
Fig. Removing the trim panel to access the rear blower motor
i. Disconnect the wiring harness connector from the accessory power outlet, if equipped.
j. On long wheelbase wagons only, remove the quarter trim from the quarter panel and pull second rear seat belt through access hole.
k. Pull first rear seat belt through the access hole.
l. Remove the quarter trim panel from the vehicle.
3. Remove the 5 screws mounting the A/C-heater blower motor housing to the rear HVAC unit (one mounting screw located on evaporator cover).
4. Twist the blower motor out of scroll housing.
5. Disconnect the blower motor wiring connector.
6. Remove the blower motor from vehicle.
Fig. The rear blower motor is held in place by four screws
To install:
  1. Install the blower motor unit into the vehicle.
  2. Reconnect the blower motor wiring connector.
  3. Secure the blower motor into scroll housing.
  4. Install and tighten the 5 screws mounting the A/C-heater blower motor housing to the rear HVAC unit (one mounting screw located on evaporator cover).
  5. Install the right quarter trim panel as follows:
    1. Install the quarter trim panel in position in the vehicle.
    2. Insert and pull the first rear seat belt through the access hole in quarter trim panel.
    3. On long wheelbase wagons only, insert and pull the second rear seat belt through access hole in quarter trim panel.
    4. Reconnect the wiring harness connector to the accessory power outlet, if equipped.
    5. Engage the hidden clips to secure the front of quarter trim to quarter panel rearward of sliding door opening.
    6. Install the retaining screws that secure the rear edge of quarter trim to support bracket.
    7. Install the retaining screws that secure the quarter trim to the quarter panel in bolster area.
    8. Install the second rear seat belt anchor (if equipped), and the first rear seat belt anchor.
    9. Install the D-pillar trim panel and upper C-pillar trim.
    10. Install the quarter trim bolster.
    11. Install the sliding door sill plate.
    12. Install the second rear seat, if equipped, and install the first rear seat.
  6. Reconnect the negative battery cable. Check blower motor operation.
Nov 04, 2010 | Chrysler Town and Country Cars & Trucks
How to replace the blower motor in a dodge 2001 caravan
    9. Disconnect the wiring harness connector from the accessory power outlet, if equipped.
    10. On long wheelbase wagons only, remove the quarter trim from the quarter panel and pull second rear seat belt through access hole.
    11. Pull first rear seat belt through the access hole.
    12. Remove the quarter trim panel from the vehicle.
To install:
Hope helps (remember to rate this).
Nov 01, 2010 | 2000 Dodge Caravan
Where is the blower motor resistor in a 2001 dodge caravan se. I do not see it behind the glove box. I do see soemthing similar under the hood on the passenger side aginst the firewall but it is not...
Caravan, Grand Voyager, Town and Country, Voyager, 2000-2004
Blower Motor - Removal & Installation
  1. Disconnect and isolate the negative battery cable, then wait 2 minutes before proceeding with the removal. This will effectively disable the air bag system preventing possible personal injury.
  2. Remove the glove box from the instrument panel.
    Fig. The blower motor is located behind the glovebox, behind the blower motor cover
  3. Remove the A/C-heater blower motor cover.
  4. Disconnect the blower motor wiring connector.
  5. Remove the blower motor wiring grommet and feed the wiring through the blower motor housing.
  6. Remove the blower motor mounting screws.
    Fig. Once the cover is removed, unplug the electrical connector and push it through the opening in the housing
    Fig. The blower motor is secured to the housing with three small screws
  7. Allow the blower motor assembly to drop downward to clear the instrument panel and remove from vehicle.
To install:
  1. Place the blower motor assembly into position on the A/C-heater unit and tighten the mounting screws.
  2. Route the blower motor wiring through the blower motor housing and seat the wiring grommet in the hole of the blower motor housing.
  3. Reconnect the blower motor electrical connector.
  4. Install the A/C-heater blower motor cover.
  5. Install the glove box into the instrument panel.
Auxiliary Heater and Air Conditioner
To install:
Hope helps (remember rated this).
Jul 11, 2010 | 2001 Dodge Grand Caravan
Diagram on how to take off left door panel on 1998 ford expedition
REMOVAL AND INSTALLATION Trim Panel —Front Door, Expedition Removal
  1. NOTE: Release the top portion first.
    Remove the sail panel.
  1. Disconnect the electrical connectors.
  1. Remove the door trim panel screw at the window regulator switch plate opening. 149d0a6.gif
  1. Remove the door trim panel screw in the courtesy lamp housing.
    1. Remove the courtesy lamp lens.
  1. Remove the inside door handle.
  1. swj~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: To avoid damage to the front door trim panel, do not pull directly outward.
    Lift upward and then outward to remove the front door trim panel (23943). d6459fb.gif
  1. Disconnect the power mirror electrical connector.
Installation
  1. Connect the power mirror electrical connector.
  1. Install the courtesy lamp and socket.
  1. Install the front door trim panel.
  1. Install the inside door handle.
    • Install the bolt.
  1. Install the inside door handle trim cover.
  1. Install the door trim panel screw in the courtesy lamp housing.
    1. Install the screw.
    1. Install the courtesy lamp lens.
  1. Install the door trim panel screw at the window regulator switch plate opening.
  1. Install the upper door trim panel screw.
  1. Connect the electrical connectors.
  1. NOTE: If a new trim panel is required: Some new trim panels have a cut out opening for the window switchplate that is larger than that on the original trim panel. When installing a new trim panel, install the window switchplate in the following sequence to make sure that the switchplate is secured fully into the door trim panel.
    Install the window regulator switchplate.
    • Insert the rear switchplate clip into the trim panel opening.
    • Install the forward and side clips into the trim panel opening.
  1. NOTE: Install the lower portion first.
    Install the sail panel.
Mar 14, 2010 | 1998 Ford Expedition
Ford expedition side mirror (instalation giude)
SECTION 501-09: Rear View Mirrors 2003 Expedition/Navigator Workshop Manual REMOVAL AND INSTALLATION Exterior Mirror Removal and Installation
  1. Remove the front door trim panel. For additional information, refer to Section 501-05 .
Front Door Trim Panel —Expedition Removal and Installation
NOTE: Left front door shown, right front similar.
  1. Remove the door handle bezel.
    • Use service notch.
  1. Remove the window control switch plate.
    • Use service notch and disconnect the electrical connectors.
  1. s3j~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: To avoid damage to the door trim panel, lift the door trim panel by pulling directly upward on the armrest to disengage the panel clips.
    Remove the two bolts and three screws, and remove the door trim panel.
  1. Remove the weather shield.
  1. Disconnect the exterior mirror electrical connector.
  1. Remove the exterior mirror.
    • Remove the nuts.
  1. To install, reverse the removal procedure.
    • Install top nut first.
Exterior Mirror Motor Removal and Installation
  1. Position the mirror glass to obtain a gap at the top edge of the mirror and carefully pull the top edge of the glass away from the mirror housing.
  1. Disconnect the heated mirror electrical connectors.
  1. Remove the exterior mirror motor screws and exterior mirror motor.
    • Disconnect the electrical connectors.
Oct 26, 2009 | 2003 Ford Expedition
Car Audio & Video Logo
54 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
