Question about HP Pavilion dv7-1132nr Notebook PC
Red line on screen - HP Pavilion dv7-1132nr Notebook PC
  • 162 Answers
Are you able to view the same Red lines even in the BIOS window? If yes, this may be LCD issue too.. The LCD will show small red dots which are called Dead Pixels. If the Red lines and dots are more, then it is better to contact the Service Center
Posted on Jul 03, 2010
Thin red line running from top to bottom of screen
What is this thin red line that is on my screen whenever my ...
https://answers.yahoo.com/question/index?qid...
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Thin Vertical Red Line [Solved] - Acer - Displays - Tom's Hardware
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - ‎2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Why is there a straight vertical line going from top to bottom on ...
forums.androidcentral.com > ... > Samsung Galaxy S6 edge
Apr 15, 2015 - 7 posts - ‎4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
Jan 26, 2016 | Samsung UN60ES6100 60-inch LED TV
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Red line in screen
Please provide more details. Is this red line seen across the screen?
Jun 06, 2012 | Televison & Video
A red line in the middle of screen
I have seen this many times . most people would said video card but for a fact i use a monitor with 3 red lines down the screen for a test monitor . the monitor has failed .
May 17, 2010 | Computers & Internet
Screen is red with lines when channel is changed
If its a kp-51hw40 : go to an unused video input and look at the screen---if it is redish in the background with curved faint trace lines you have one of two things wrong; First: the red "screen" control may be set too high. Second: you may have a problem with the RED picture tube.
To try to adjust the RED screen down you have to remove the entire front grill plate on the front of the TV(some have screws on the back on either side that have to be removed---and then you should be able to pop it out. Behind it there is a masonite inspection plate held in with screws----Once you have that off look for a SMALL SQUARE BLACK PLASTIC BLOCK; it has 6 black adjustable controls---you have to use a flashlight and look carefully---one row left to right will be marked FOCUS--DON'T TOUCH THOSE---THE OTHER ROW left to right will be marked SCREEN; if you look carefully you will see marked by each r (red) g (Green) b (blue)
you want to locate the RED SCREEN CONTROL.
WITH the set still on a blank video input where you can see it clearly turn the RED Screen Control to the left until the lines and red tint go away---do this slowly and make sure you are adjusting the RED screen--not the FOCUS.
IF this has been helpful give me a vote here as I do this for free; yesterday I adjusted one of these in a home that was blue with the faint lines---about 15 minute job for me.
if you have questions or need help:
etower.766@netzero.net
Aug 23, 2009 | Sony KP-51HW40 51" Rear Projection...
Vertical red lines on screen
try a dif game and send me a msg at kickop1@ymail.com
Jun 27, 2009 | Microsoft Xbox 360 Console
The tv is showing red lines on the screen.
These are retrace lines. The screen on the red tube is turned up too high. Inside the set there are 6 knobs. 3 for focus & 3 for screen. Turn down the red screen until lines are gone. These knobs are usually found by pulling of the front panel.
Apr 06, 2009 | Televison & Video
My screen have some red lines
I will assume from you description that this is a rear projection crt(picture tube) tv. if this is true I have good news/bad news.
faint red horizontal bowed lines in the picture indicate the screen(G2) voltage for the red tube is too high.Slight lowering of the G2 adjustment will eliminate these lines. I stress SLIGHT because too much adjustment will mess up the gray scale .
The bad news the red crt made be bad. if the adjustment works but in the future the problem reappears then suspect the red crt.red crt replacement is probably not economical to repair.
Jun 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Red line across top half of screen
Uh-Oh.. Sounds like the BGA RAM in the video circuit. (These units are Intel based and Core 2 duo if posted correct).. We can repair if you need help and its under warranty and sorry its not a home remedy situation..
ikenfixit.com
Jan 17, 2008 | Apple MacBook Pro Laptop Computer with...
Inverter board is bad or video cable loose either behind LCD panel or near video adapter.
Dec 02, 2007 | Gateway MX6438 Notebook
HP Pavilion dv7-1132nr Notebook PC Logo
508 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
