Question about Alienware PC Systems Alienware Aurora High Performance Gaming Desktop Computer
New alienware aurora pc acting up ever since i got it. Crashes in crossfire during benchmarks or games, first monitor shuts down few seconds after pc follows... Alienware Aurora, i7 730, 6Gig ram, 2*HD5770 watercooled temperatures are all around 30°C
  • joecoolvette
    joecoolvette Jul 03, 2010
    For the money that thing costs, I'd be all over Dell to have it fixed. Still under warranty?
  • dyeh76 Jan 26, 2011
    The problem has been solved in the meanwhile sorry for not getting back earlier :)
    First problem was overheating processor due to watercooler not being fixed firmly on the processor (caused the fans to spin like mad and make a lot of noise) solved by gently pressing the cooler against the CPU.
    Second problem appeared one of the cards was malfunctioning causing artefacts, so in the end I ended up returning the two HD 5770' s and asked for a single HD 5870 and so far no more problems :)
  • 63 Answers
Try going to the alienware website and updating the drivers for all your components, otherwise call dell customer support as they generally provide excellent service.
Posted on Jan 26, 2011
    Sorry for getting back so late...
    I had overheating problems in the beginning which caused these symptoms.
    First cause was the watercooling plate not touching the CPU firmly causing overheating and excessive fan noise due to the fans trying to cool the system.
    Solution was gently pressing the cooling plate against the CPU.
    Second problem was one of the Graphic cards was defect so turned it in for another but temperature problem remained (think because of the two graphic cards being very close to each other, generating a lot of heat and almost no place for the air to go to.
    Ended up turning the two HD5770's in and traded them for one HD 5870 performance is nearly the same and no problems at all anymore :)
    The temperatures I posted initially were taken from the alienware control panel tool but seemed not to be really accurate.
    When using GPU-Z I found out the real temperatures were way higher :)
2 short beeps from BIOS
Hello there!
2 shorts beeps, are always reference on BIOS post, or error on BIOS settings, check this first!
Carl
Jan 15, 2014 | Dell Alienware Aurora-R3 Gaming Desktop...
My Alienware M9700 starts up but turns off before Windows can start
sounds like a thermal shut down maybe heat sink is full of dust under cpu fan or you need fresh thermal paste on processer
Jan 03, 2014 | Alienware PC Systems Alienware Aurora High...
Alienware x51 random restarts [solved: Dell had the audacity to supply the need with an underpowered PSU for the GPU they offered]
Hello Wiryan =)
Sounds like either a power supply or graphics card issue to me. You could try downloading Almico's speedfan to check your temperatures just to be sure that they are fine.
You should contact Dell, they can probably troubleshoot the issue pretty fast/send a technician to you. The X51 randomly shutting down is a common issue if you check the forums over there. http://en.community.dell.com/owners-club/alienware/f/3746/t/19437557.aspx?PageIndex=1
I assume you have updated every driver to the latest?
Hope this helps! :)
Aug 07, 2013 | Dell Alienware X51 Desktop PC | Core i7 |...
My aurora which recently had its motherboard replaced has been shutting down seemingly at random. Sometimes when I'm watching hulu or playing a game.
It's probably heat-related -- start the Windows Task Manager, and minimize it, and then view HULU -- the CPU-meter probably will rise to 100% and stay there. The minimized Task Manager will be a small icon on the bottom-right of your monitor.
The "harder" the CPU works, the hotter it gets.
Be sure that the warm air leaving the back of your tower has some place to go -- don't back your tower directly into a wall, or put it tightly into a computer-desk.
Jun 28, 2010 | Alienware PC Systems Alienware Aurora High...
Alien Aurora will not come out of sleep mode.
try unpluging it and leave it for a few minutes then plug it back in and try yo boot it up.
Jun 21, 2010 | Alienware PC Systems Alienware Aurora High...
Once I turn on my Alienware computer, it immediately shuts off. How can I fix it?
Are there any beeps? Does anything come up on the screen?
Suspected powersupply fault if no beeps are emitted. Try a new powersupply but remember to adhere to wattage..
My alienwars m8700 starts and shuts down after afew seconds to one min both fans are working any idears
try to fromat the system and see if the problem is solved otherwise it might be a hardware problem go to dell care
May 23, 2010 | Alienware PC Systems Alienware Aurora High...
M9700 starts up but shuts down few minutes after vista loads
Sounds like it is a problem with the m9700 overheating. I have just repaired an m9700 with this exact issue and it was resolved by taking the CPU heatblock off, removing the dried/caked-on heat compound, and replacing it with my own (Arctic Silver 5).
Was 91c before, now down to 74c max on load (Measured with coretemp). Random crashing has stopped.
Sep 03, 2009 | Alienware PC Systems Alienware Aurora High...
The montor doesn't come on and shows no connection on the monitor screen
check the pins on the monitor cable my be some are broken
and also check your VGA card it may not be good and need to be changed
May 11, 2009 | Alienware PC Systems Alienware Aurora High...
Alienware Aurora desktop crashes on bootup
try to change the cooling fan mayhbe its the problem that your proccessor is over heated.
Dec 25, 2008 | Alienware PC Systems Alienware Aurora High...
Alienware PC Systems Alienware Aurora High Performance Gaming Desktop Computer  Logo
467 people viewed this question
Top Alienware PC Systems Computers & Internet Experts
Martin Murray
Frank Zabroski
Frank Zabroski
Larry Chandler
Are you an Alienware PC Systems Computer and Internet Expert? Answer questions, earn points and help others
