Question about Hotpoint 18 in. BCI45 Slim-Line Built-in Dishwasher
This is regards to Hotpoint Slimline Dishwasher BCI450. We always use 3-in-1 tablets to add to the dishwasher on a 'Normal' cycle. We had no problems for a year...then we heard a loud bang. Apparanetly it was a Control Card problem. This was fixed but about a month later the same thing happened. The engineer said this was happening because we were using the 3-in-1 tablets which weren't designed for small (slimline) dishwashers. Produce too much foam maybe ? However, the Instructions give instructions for using tablets ! The tablets being used are Finish Powerball. The only thing it says on the Finish Powerball packet is don't use for short cycles - the 'Normal' cycle is usually around 1hr 30mins so would have thought this was ok and not a short cycle. I can't find anywhere that does tablets specifically for slimline dishwashers so would assume the size of the tablet isn't the problem here. We're currently using powder / rinse aid / salt but would much prefer to use the tablets. I'm confused....can anyone help ? Thanks.
  • m_j_brayford Jul 07, 2010
    Thnaks for all your help
  • Hotpoint Master
  • 3,247 Answers
Hotpoint recommend the use of Glist 3 in 1 Dishwasher tablets for the BCI45 model dishwasher. The tablet should be put in the larger of the two detergent compartments. Also the lid should be closed.
The cause of your control card problem could be water leaking through the door seals and shorting the motor circuit. The would be more so when excessive foaming takes place. I would suggest that you take off the door gasket and dry out all the moisture from the tub - this is the area at the base of the dishwasher where the motor and pump are located. Then replace the gasket with a new one.
Posted on Jul 03, 2010
  • m_j_brayford Jul 04, 2010
    Many thanks for your reply.
    Thanks for the advice about the tablets. The instruction booklet doesn't mention any specific tablets to use - the engineer said this model wasn't suitable for tablets so it's good to have this advice.
    One question - would certain tablets e.g, Finish Powerball - be a potential cause of the shorting of the motor circuit for this model ? Do these tablets create greater amounts of foam and therefore potentially cause the shorting in slimline models ?
    Thanks also for the info on the control card problem. We are in fact going to have to call out the engineer again as the 'normal' cycle - which should take 1hr 33mins is finishing in 1hr. Would this be because the engineer - when fixing the control card problem - has not set the program cycles correctly ? The dishes are being washed but not as well as previously and they don't come out feeling warm.
    Thanks again and await your replies.
  • Sam Jul 04, 2010
    The mention of the dishwasher tablet is on page 10 of the UK version of the manual
    Does not mention anything about Finish powerball tablets. My guess is that they do create lot of foam. Do you not get Glist tablets in your part of the world.
    Now the problem with long cycle time and dishes not feeling warm. My guess is that the heater or the heater sensor has been not connected properly. This would cause long cycle times and the dishes not cleaning properly. If this was not the problem before the control card was replaced then the technician should be able to fix it.
    Hope your dishwasher works well.
Hotpoint aquarius dishwasher tablet dispenser not working
Clean it by running a cycle with hot water and 2 cups white vinegar, I suspect you have mineral deposits built up and causing it to stick closed and this causes the problem
Jan 18, 2012 | Hotpoint Dishwashers
Dishwasher tablet always in bottom of dishwasher
Question : has it always done this?? is it hooked up to the hot water and is the water HOT !!! 140-145 degrees
Dec 10, 2011 | Hotpoint 24 in. FDW60 Free-standing...
Hi, The last two washes i've just done on my Hotpoint WD72, the washing has gone full cycle but has come out smelling damp. Any ideas? I've had it since 2005 when it was new.
This will potentially sound odd, but run the 90 degree cycle with 3 dishwasher tablets in the drum. The smell is bacterial and probably the result of a build up of residue from biological soap powder (Which is simply bacteria that eat your stains). Dishwasher tablets are anti-bacterial and will kill the bugs making the smell
Jul 26, 2011 | Hotpoint Ultima WD72 Front Load...
My Hotpoint Aquarius diswasher won't dissolve the washing tablets
I don't have a solution, but the exact same problem is happening with my dishwasher. Nothing is getting cleaned properly.
Did you manage to get the problem fixed?
Jun 01, 2009 | Dishwashers
Bottom water sprayer is not going round
Hello Joannekirk9,
I used to work at Miele in the technical services department. The most likely cause of your problem is the jets on the spray arm are clogged with soap build up or debris.
Solution - Try cleaning out the bottom spray arm jets with a toothpick and then running the dishwasher through a short cycle like normal or china crystal setting. You may also periodically do this with about 1 liter of vinegar to clean out the stainless steel tub once every 6 months to prolong the life of the dishwasher. The vinegar acts as a really good cleaning agent. Also, When using soap use 2 tablespoons of powder solution only!!! Oversudsing is the biggest problem I have seen with these dishwashers. If you are still having a problem contact Miele technical support. They are always extremely helpful. I also have a G832sci and has been great
Residential appliance tech support: (800) 999-1360
Dec 16, 2008 | Miele Slimline G832SCi Built-in Dishwasher
Hotpoint BCI450 Programme cycles
I attempted to locate an answer to resolve the issue for you, but you have not provided me with enough information to access my service database. Please observe the TIP below, and post me back and I will be happy to assist you further. Should you require more extensive consultation to help resolve your complaint(s), you may contact me through our premium chat service.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information. From this link you can identify your issue and order parts to repair your unit.
http://www.repairclinic.com/0088_9_1.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 23, 2008 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
Hotpoint dishwasher bci450
Here are the eco related error codes for your washer..
1)Light 3 (eco) flashes. Water is present in the flood catching tray at the bottom which usually indicates that there is a leak somewhere. More often than not this is just a pipe with a poor fitting and simply tightening the clip is enough to stop the leak. Our machine had a very slow leak from one pipe (not enough to trigger the alarm) which was fixed in this way. The leak is detected by a small float switch located in the flood catch tray.
Undo 4 screws on the metal plate under the dishwasher 3 at the front 1 at the back, this reveals The pump check the seals are in place on the waste pump.
2) Wash indicator lights 3 + 5 (eco + pre) flashing rapidly. Filter is clogged. Pull out the filter and clean it.
3)Runs for approx. 3 minutes and then stops. Lights 3 + 4 (eco and fast) flash. Probably caused by being plumbed into a hot rather than cold water supply. The incoming water is hotter than required for the wash which causes the machine to cut out. Plumbing the machine into a cold water supply will fix the problem with no apparent long term problems.
May 23, 2008 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
Drainage problem
cycle switch on the front is most likely bad
Jan 09, 2008 | Hotpoint 24 in. HDA3740G Built-in...
It's Leaking Water!
Most common reason is that the lower spray arm splits on the seem and sprays water under the door, to proove if it is this remove lower spray arm and run through program if no leak fit new arm. Regards Advisor
Aug 30, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint 18 in. BCI45 Slim-Line Built-in Dishwasher Logo
129 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
