Question about Belkin F5D8631-4 Router (F5D8631au4A)
After firmware update, modem is not working lan, wl just power on only
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 81 Answers
You can try resetting your unit and see if it will goes back to normal.
Usually factory reset is performed after updating the firmware.
Cheers,
KJ
Posted on Jul 04, 2010
D-Link DSL2730U dead after firmware update
Did you do a Hard reset of the Router after the Firmware Update? Try a 30/30/30 reset procedure: http://compnetworking.about.com/b/2009/03/11/the-30-30-30-hard-reset-rule-for-routers.htm Then reconfigure the SSID and the Security Key. AFTER, Shutdown the Laptop remove battery, plug in, reboot. post results.
May 08, 2013 | D-Link Computers & Internet
GLB-802C new firmware
Usually you can login on your browser to you router and go to the management section to check for firmware updates and select that button and it will download and install the firmware. On some models, you have to go to the D-link web site and look for firmware updates for your router. Always check what you current firmware you have installed and check the version of you router modem (A, B, C etc). Then you can manually download the firmware (usually in a ZIP file), open the zip file, and then using your browser connected to the router look for Update Firmware. You will have to go to where (folder) you saved the downloaded update and select that file. It is recommended that you update using a LAN connection and not a wireless connection.
Feb 08, 2012 | D-Link ADSL2/2+ Modem/Wireless Router...
I cant open my WIRELESS ROUTER |WL-520G - RT (WL520GC) on my browser; if i open the default gateway the isp modem settings pops out not my asus router seting... pls hep
Hi!
I tried to figure out some explanation, and I think it's possible that both WAN side of the router and LAN side of it have same types od ip adresses, maybe the default 192.168.1.***. That means that the WAN port of the Router, the ethernet port of the modem, the wireless and LAN ports of the router have same tuype of adresses, maybe all asigned by DHCP.
To be sure, I suggest you to:
1. turn of the modem
2. check that the network connection obtains ip adress automatically
3. in a dos prompt (START - RUN -CMD) type IPCONFIG, it will return among other infos the adress of the default gateway.
4. now type that adress in the browser.
5. if it works, log on to the router and change the LAN settings so that the adresses used in the LAN will be different from the WAN, let's say 10.10.10.1 and so on
Aug 06, 2011 | ASUS WIRELESS ROUTER |WL-520G - RT...
HOW TO UPDATE ASUS WL-AM604g Wireless Router Firmware I HAVE THR TRX FILE
1. Download the updated software from the vendor's web-site.
2. Connect your computer with an Ethernet cable, *NOT* via wireless, to the router.
3. Access the router's built-in web-server interface.
4. Navigate through the web-pages to the "update firmware" page.
5. Click "browse", and point to the file on your computer that is the updated software.
6. Click "update".
7. Hopefully, BC Hydro wil NOT cut your AC power while your router is updating.
8. The router will restart.
9. Done.
Dec 14, 2009 | ASUS WL-AM604G Wireless Router
My internet service is working sporadically when it is connected to the D-Link router. Right now I have my computer directly connected to the cable modem and it works fine. When the computer is connected...
You need to update the firmware of your router. Download the latest firmware from Dlink website. You need to hard reset the router, load the firmware, then do another hard reset after you successfully updated the firmware.
Jun 25, 2009 | Computers & Internet
D-link Modem Lan Light
Try to update the firmware of your modem.
Mar 04, 2009 | D-Link DIR-625 (790069292637) Wireless...
I have a 2640b router failure
I think that u need to go on, open your internet explorer, and enter your ip address in the address bar. Enter your password. Check your settings. Sometimes, internet stops, because firmware needs to be updated, sometimes its your computers driver (this is not likely); but most likely, your best option is to update the firmware for it. Consult your manual or internet on how to do it.
Jan 06, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Can not get my adsl modem to connect through ASUS wireless router
it could be the modem and the router has the same ip address. the asus router has an ip of 192.168.1.1, check if the dynalink modem has an ip of 192.168.1.x. if so, change the router's ip to 192.168.x.x (e.g. 192.168.2.1) then see if you'll be able to connect to the internet while the modem is connected to the wan port of the router
Apr 02, 2008 | ASUS WIRELESS ROUTER |WL-520G - RT...
Problem after firmware update Edimax BR-6114Wg
Hi Fklco,
Why are you connecting the WAN,, (the internet modem cable), to the standard ports? It should have a WAN port, for the cable from the modem, and a LAN for the cables to the computer?
On the other hand, if it is working, I would leave well enough alone, :D
Jan 06, 2008 | Edimax BR-6114Wg Router (BR6114WG)
Open Questions:
Belkin F5D8631-4 Router (F5D8631au4A) Logo
103 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
