Question about Sharp AR-M162 All-In-One Laser Printer
"clear paper path" displayed. I have removed what paper is visible but the error message still displays
  • Sharp Expert
  • 316 Answers
Paper sensor. liver displace
Posted on Jul 03, 2010
HP 3030 error message paper jam - clear papaer path. There is no paper in the machine. I have cleared and cleaned the machine, turned it off, waited 30 secondsand turnedit back on and still get the error...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Mar 29, 2011 | HP LaserJet 3030 All-In-One Printer
Printer states there is a paper jam but when checked everything is clear. Can not clear indicator
Feb 16, 2011 | HP 8500 Premier All-In-One InkJet Printer
HP 3005dn Printer Tray 1 paper jam error
If message in display panel reads [13.XX PAPER JAM [LOCATION]]Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken.
Soln.
For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation.
For message 3.0 PAPER JAM [LOCATION]
means
A non-specific paper jam occurred.
Soln
1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation.
For more help check yhis site
http://www.printertechs.com/tech/error-codes/error-codes-0-19.php
Nov 26, 2010 | HP LaserJet P3005n Printer
Will not copy says "clear paper jam"! I have cleared all paper
Sep 12, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
I have the following error message:
SOMETHING MOST LIKELY FELL DOWN IN BACK PAPER PATH OR TORN PAPER THAT HAS PAPER SENSOR STUCK. HARD TO SEE SOMETIMES. MIGHT WHAT TO TURN MACH UPSIDE DOWN AND SHAKE BE VERY CAREFULL
Apr 14, 2010 | Canon PIXMA MP830 All-In-One InkJet...
I have a Ricoh Aficio AP410N printer and it displays a message that says "remove misfeed internal path" error message. I checked the paper path and there is nothing there. I checked the manual and there...
Did you take out the toner cartridge and paper trays and open all the covers to try to find the misfeed? If there is really nothing there, you can try turning the printer off and back on to see if it clears itself.
Oct 06, 2009 | Ricoh Aficio AP410N Laser Printer
Kodak All-in-one Printer has Paper Jam problem
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
Sep 15, 2009 | Kodak ESP 5 Printer
My LaserJet4250n Printer keeps printing a page recurrently. Except the former job is cancelled Manually, it prints the previous instead of the currently sent job. Moreover,it displays the following...
I think what is happening is when you get the error, the printer automaticaly reprints the page it was on when it got an error condition that makes it think it didn't print the page correctly. The clearing paper path message comes up after it thinks it had a jam. Displaying load plain paper could be because either the printer is not configed for the correct type of paper you have in the tray you are trying to prin form(push the green check button, arrow downt to paper handling and see what your trays are set for.) Also there is a blue switch on the tay(looking for front of tray it will be on the right hand side of tray rail) the switch says standard or custom. The switch should be in the standard position.
Are you getting any errors or jams, if so, tell me what they are.
Feb 25, 2009 | HP LaserJet 4250n Printer
Sharp AR-M162 All-In-One Laser Printer Logo
119 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
