Question about Yard Machines 158cc Push Lawn Mower #11a 034f200
I let go of the safety handle and it die a little but but still runs
    Problem Solver:
  • 9 Answers
Well follow the cable down to the engine if you look at the bracket that the cable hooks to look around youll see a black wire ,that wire hooks to the coil make sure the wire is good and make sure it goes from the bracket to the coil and where the black wire hooks to the bracket on the engine is grounded when the safty handle is released watch the mechanics of thesafty st the engine its pretty simple thanks have a good day
Posted on Apr 26, 2015
    Master:
  • 501 Answers
American mowers are designed to kill the engine,and put the brake on the flywheel if you let the handle go.we in nz,bypass that
Posted on Jul 03, 2010
Electric hedge trimmer want run why?
electric hedge trimmers have 2 switches to press before it runs
one is the trigger that you pull and the other is in the handle that you hold in your left hand
both have to be on before it starts
it is a safety feature to stop operators cutting off their fingers
Jun 09, 2016 | Little Wonder 2230S 30 Single Side Hedge...
When running and you push in the auger it will turn for a short time than motor well die
On the top of the right & left handle grips there are safety switches that you have to hold down and what happens is those switches get worn or the wiring connections to them get corroded or the wire brakes off you need to replace those safety switches
Apr 18, 2015 | John Deere 826 1032 Snowblower Operators...
The lawn mower blades lock up and will not start
Did you pull the safety handle back all the way. or has it slipped so it doesn't work right.That is what the little safety handle is made to do not only to shut the engine off but stop the blades.
Has the engine seized up? Just ideas.
Is there junk that is holding the blades from turning.
Mar 14, 2015 | Garden
Craftsman zts7500. rear engine mid deck zero turn. All safety swithes appear to be good and all wires appear good. Starts great but as soon as you pull the handles in it dies.
has to be one of the safty switches are bad dosnt make any sence it could be some else not unless you have a lock hydro pump im curious what it could be let me know
Aug 28, 2014 | Garden
Cuts out after start up
some have a manual off /on fuel control, some have a safety bar that you hold while running and the blade is engaged. I f you have the bar at the handle end and you do not engage the blade, and this still happens, check the cable from the handle to the engine and see if when you assembled the unit that the cable has been run properly.Ever year I remove the handle for winter storage and fold the cable and handle on top of mower, and not disconnect cables. In Alaska we get snow in winter and mower does not work well, a little humor. good luck..
Jun 05, 2013 | Briggs & Stratton Garden
GOT A 1100 GOLDWING RUNS BUT SPUTTERS A LITTLE AND WHEN YOU LET THE CLUTCH OUT IN FIRST IN WANT PULL IT JUST DIES
Hi, N_prissy_pin and the usual suspects are:
1. Faulty wiring to any safety switch.
2. Safety switches loose at the mounting point.
3. Faulty kickstand safety switch.
4. Failed kickstand safety switch circuit diode.
5. Stretched side stand spring.
6. Side stand not coming up far enough to disengage switch.
7. Faulty clutch lever safety switch.
8. Faulty neutral safety switch.
9. Clutch not properly adjusted.
10. Clutch plates sticking, forward lurch
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
cutting out at 5000 rpms GL1100 Information Questions goldwingdocs com
77 GL1000 Still Idles goofy
Honda GoldWing GL1100 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda Gold Wing GL1100 Owner Manual
May 07, 2010 | 1983 Honda GL 1100 Innerstate Gold Wing
My motorcycle died suddenly in traffic andwill not start again. my battery seems to work fine , but it will not start.
Does it have a safety switch on the kickstand? If yes check to make sure it is working properly as it will shut the bike engine off. It's simple but most of the time it's the simple things that stop us...
Sep 17, 2009 | 1999 Suzuki TL 1000 R
CubCadet ZForce 23 50" - runs, but dies when try to move
The safety switch under the seat is faulty and it must be replaced.
Apr 24, 2009 | Garden
Yard Machines 158cc Push Lawn Mower #11a 034f200 Logo
124 people viewed this question
Top Yard Machines Garden Experts
Phil Walker
Phil Walker
Dean Gruber
Tim Whalen
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
