Question about Insignia LCDTV26 26 in. Television
When the first time my computer connect to the lcd tv is working but when I do again it show no signal on the tv.. what is the problem
  • 1,056 Answers
Press start then choose control panel. On "Mobile PC" choose "adjust commonly used mobilty setting". Then choose connect display. Then choose how you want it to display on the lcd TV.
Posted on Jul 03, 2010
My Alba TV , when scanning for channels ,says no signal, check antannae, which i have by connecting a different tv, its working good , but my tv not showing any channels when even using first time ins
Check and replace the tuner inside the TV. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 01, 2014 | Alba LDVD1538WDCH LCD TV
I could not connect to internet with my sony bravia kdl 32ex520 I am using the ethernet cable( no modem) when i check the status it is showing as cable is connected and internet is failed error 1106 i...
Ethernet connections between the tv and the computer into one signal frequencies are not compatible signals.Ur main home computer have internet service connection go through a wire or wire less Router for a internet signal through out the house.Connect the tv internet signal through the Router.Internet signal will work fine.
Aug 18, 2011 | Sony KDL46HX800 46 in. 3D LCD TV
TV won't show picture the power and OPC light blink twice together followed by three blinks from the OPC alone.
The main tv Tuner signal board have problems or it is dying or might be dead already.But sometimes this tv will still work and can be used,i have the same tv have the same problems it work for me all the times.By doing this process.Everytimes Power and OPC lights blinks.Just push the remote power switch again for tv to repower the tv power and OPC lights again,have go thought this process pushing power remote switch again have to do this like 3 or 4 times sometimes before the tv to work.Tries websites like Shopjimmy.com or Ebay.com to buy a whole new refurbish main tv Tuner signal board for the replacement.
Jul 30, 2011 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
My tv doesnt show any images and the panel has the light of fopc on
Common problems on Sharp LCD tvs as tv it is agings,tv Power LED and OPC LED,LEDS lights flashes happen to mine Sharp tv many times and i had it two years,do this many times,tries to turn on the tv.By trying pushes the power button the remote again if OPC LED and power LED,LEDS lights flashes together.Everytimes the OPC LED and power LED lights flashes,just push the power switch on the tv remote and wait for the tv main Tuner signal board to kick in the backlight to light up tv to work.Have to do this like three or four times before the power supply board to kick it in to make Tuner signal to work.If u require to this more than 5 or 6 times the main tv Tuner signal board it is shorting out and beyond trying to kick in by the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
May 31, 2011 | Sharp LC-32SB24U 32 in. LCD TV
Hello i have an hp pavilon dv6000 laptop and connceted to my lcd tv without any problems,3 days ago it was disconnceted and the cable was complitly out of work,i bought a new HDMI cable now,but it shows...
The first thing you can try is, connect the LCD Tv to another computer with the HDMI cable and verify it's working that way on the other pc. If it works, then the HDMI port on the Laptop might have a problem which will require Service. Troubleshooting and TIY will not fix the issue.
If the same LCD TV doesn't work on another computer, then double-check the cable and the connection. You'll be able to narrow down to the culprit and may need another LCT TV.
Is the LCD TV still working with other connections? like with your DVD Player or Cable.
Let me know the outcome.
Good luck.
Thanks for using FixYa.
Oct 27, 2010 | Computers & Internet
I have a Sharp LCD TV and a Toshiba Satelite laptop. I have never had any problems connecting my laptop to the tv using a vga cable. It isn't working anymore however. I checked the cables and...
I would check the video setting on your laptop. The resolution or refresh rate might have been changed and the LCD TV might not be able to process the signal. Try changing the laptop's resolution to the lowest setting(right-click on desktop and pick properties) and see if the TV produces a picture. Also verify the video output on the laptop is working by hooking it up to a computer monitor if available.
Jan 09, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Toshiba Satellite L25-S1194 attached to TV monitor can't get display on laptop at same time HELP!!
Connect your TV to the computer with an S-Video cable. Turn the TV on and choose the AV option (of your TV) to S-Video. It will tell you that there is no signal on the TV.Press the Fn key on the keyboard. While keeping that key pressed, press the F5 key. A small rectangle appears on the screen showing different connection possibilities (LCD, LCD +TV, LCD+CRT, TV only, CRT only). You can cycle through the options by pressing F5 repeatedly. You select the output option (TV + LCD).Release the keys . You will then have your two screens.
Note: I assumed you connect the TV through the S-Video. If your TV can be used as a monitor (it has a VGA adaptor), then with the F5 key select option LCD and CRT
Hope it helps
Aug 28, 2009 | Toshiba Computers & Internet
''no signal'' message on blue screen after watching for 10-30 min
First try another signal input like a DVD player or other source, is the signal displayed ok? Then you have lost the signal on one input from whatever the device is.
Mar 16, 2017 | Spectroniq PLTV3250 32 in. LCD TV
Weak or no Signal issue when connected to my TV.
Yes weak signal. Also closing the laptop lid puts the computer in sleep mode.
Jul 07, 2017 | Digital Lifestyle FA1B32Z 32 in. LCD...
Insignia LCDTV26 26 in. Television Logo
76 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
