My splict ac system is not draining the water throught the drainage hose and instead in dripping water the side corner opposite side of the drainage hose.
  • 29 Answers
Try lifting the unit off the wall and making sure its level and flat against the wall so the water flows as it should in the tray
common install related problem
cheers
Posted on Jul 05, 2010
1993 Toyota Corolla Dx: driving over labor day weekend, had the AC on for longer than i've normally had it on and noticed water on my passenger side floor mat. Then i looked and it was leaking from...
The drain on your evaporator core housing is most likely plugged. Condensation on the evaporator core drips down into the plastic housing and drips onto the ground through a hose on the firewall on the
passenger side.
Find the small hose on the firewall in the engine compartment. You should be able to pull off that
hose and see if its stopped up. If the hose is ok, you may need to remove some of the ac ducts
under the dash to get to the evaporator core housing to unclog the drain hole.
I have no doubt that thats the problem.
Sep 07, 2011 | 1993 Toyota Corolla
My LG Split AC leaks, the water drips from the front right side (inside the room, where it is installed) instead of from the drainage pipe (outside the room). What to do?
Hello, make sure the unit is tilted back somewhat so the Condensate can drain toward the back and not collect up in the front. Also, make sure the drain tube is not obstructed or blocked with sludge.
May 25, 2011 | LG Heating & Cooling
Water leaking out of hose on a fujitysu split system ast24rga
Normally, an Air Conditioner removes water from the air and that water condenses on the coils of the inside section that does the cooling. The water condenses on the cooling coils just like moisture condenses on the outside of a glass of ice water.
This excess water drains out of the cooling section through a "drip tube" and is supposed to drain outside of the house, or a drainage system. Your "drip tube" has either not been installed (if it is a brand new installation), has separated and water is now dripping into the house instead of outside of it. Or it is clogged. This happens when algae builds up inside the "drip pan". If that is the case, you can purchase "algaecide" tablets which kill the algae that is clogging the drip pan and preventing water from draining out through the drip tube. These tablets can be found in many hardware stores, refrigeration supply companies, or even Walmart. You can put a tablet inside the pan. (You will have to remove the cover of the unit). You can often use a little bit of Bleach and that will act as an algaecide. Hope this helps,
Best, Mark
Dec 26, 2010 | Fujitsu Heating & Cooling
Water coming from indoor unit
The problem is caused by fine particulants such as dust, pet dander, etc. which mix with the collected condinsation water and forms a grey gel eventually clogging up the drainage pipe. The solution is to attach a wet vaccuum hose to the discharge end of the drainage pipe and vaccuum out the gel. It is advisable to flush the system by adding water to the a/c's drain pan while the vaccuum is still running.
Oct 07, 2009 | Mitsubishi Heating & Cooling
Trying to find drainage system/idea for ac unit
You can install a condensate drip pan under it and attach a hose to take the water wherever you wish. Drip pans are standard A/C components -- you should be able to get one at an HVAC supply store.
May 06, 2009 | Frigidaire FAC107P1A Wall/Window Air...
Dehumidifier collecting water in container
If you have the hose drain tube connected, drainage will defer to it first. If you remove the hose drain tube, the place where it connects to the drain pan drips into the container instead.
Sep 17, 2008 | Maytag M7DH65B2A Dehumidifier
Ge profile leaks from front of freezer
your drain will be plugged under the tray. there is a hose that runs to the drip tray. the back cover comes off you can then get at the hose
Sep 05, 2007 | GE GSS25JEMWW Side by Side
Tank still fills when we are using direct drain feature
check to see that the hose isn't clogged, and that the hose runs down hill from the tank all the way to the drain. if it is higher than the tank at any point in its path it will not drain. you may put the dehumidifier on top of a small platform to aid drainage. also check that the knockout removed so there is a hole to let the water go from the tank to the hose?
Sep 24, 2006 | Danby DDR2504 Dehumidifier
A.C. unit
One of the cause of water dripping in the indoor is restricted drainage. To Identify if your drainage is restricted.
- Turn "off " the circuit breaker and take out the face cover of the unit.
- Turn "on" the circuit breaker and start the unit, wait until the unit drips.
- When the unit dripped check the drain pan if overflowed with water.
- If the drain pan is full of water you need to flush the drainage with water to remove the restriction. If the pressure of water in your area is high you can use your garden hose to flush the drainage.
Another is dirty evaporator fins (icing), dirty drain pan, broken drain pan or incorrect installation.
YOU CAN LOCATE THE DRAINAGE AT THE LEFT OR RIGHT SIDE OF THE DRAIN PAN
Aug 16, 2006 | Carrier IBM UNIT 2380 79F4796 Drive Case
Water dosent drain
well lets work with it becouse that the one you have..first let me tell you dont make that hole becouse the water that remaing in the tray is use to cool down the condenser and beleve me its a good idea..its not supouse to condese more water thant he can evaporate..but try to screw a littel bit more the two screw in the back of the cabinet to down the cabinet 10 degrees more to see if that help you...good luck
Aug 03, 2006 | Haier HWF05XC5 Air Conditioner
Heating & Cooling Logo
115 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
