Question about Toshiba Satellite L305-S5894 Notebook
My wireless LAN did not function even i click the repair box at support settings of internet connection
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 81 Answers
You can check if your wirless built is working fine or not by following the instructions below.
Right click on my computer
go to properties
Click on hard ware and then device manager.
Look for network adapter.
Look for wireless.
Check if the wireless has a yellow exclamation point , or green icon beside it.
Right click on your wireless adapter and then go to properties
On the properties box. Thats where you see the status of your wireless and it will give you option to update the driver if it needs to be updated or enabled.
Cheers
KJ
Posted on Jul 04, 2010
I have internet connection but cannot access internet
Bluetooth connections allow devices to connect without the use of wires or cables.
Some users of the Sony Vaio laptop computer have encountered problems with the connection of Bluetooth devices with their computer.
The problem lies with turning on the Vaio's Bluetooth function.
This is turned on through the computer's Wireless Switch Settings manager.
The icon for this is in the system tray in the taskbar when the computer is first purchased.
Double-click the "Wireless Switch Settings" icon in the system tray of the taskbar.
It is a a blue-green icon with "LAN" in one corner and "B" in the other.
Check the "Enable Bluetooth Device" setting in the Bluetooth Device section.
Click "OK."
If the device was already enabled, change the wireless LAN from "2.4GHz" to "5GHz" because, as the warning message should say, using the 2.4GHz wireless LAN and the Bluetooth device can make the connection unstable.
Click the "Apply" button after the appropriate boxes are checked to activate the Bluetooth signal. A blue light should come on near the computer's on/off switch for the Wi-Fi radio.
Click "OK." Another dialog box should appear explaining that the Wireless Switch Settings icon should now be in the taskbar.
Use this icon if you need to turn off or on the Bluetooth device in the future.
http://supportforsony.iyogi.com/vaio-f-series/bluetooth-4.html
sony support
Apr 15, 2014 | Sony Vaio Tap 20
Why won't my emachines laptop get online via an ethernet cord or wirelessly? I have a usb wireless adapter I use for my netbook and it works fine but the emachines laptop does not even read it.
Check your Internet Options then try connecting via the ethernet cord.
Let's start with Internet Options. If you have Windows XP Click Start/Control Panel/Internet Options. If you have Windows Vista or Windows 7 click Start/Control Panel/Network and Internet/Internet Options.
When the Internet Options window opens on the General Tab make sure you have a valid web address as the Home Page. If not, create a simple Home Page by typing: http://www.google.com You don't have to click OK now because if you do the Internet Options window will close.
Click the Security Tab and under where it says "select a zone to view or change settings" Click on the one that says Internet, then scroll down to near the bottom right and make sure that DEFAULT is grayed out (whereas you cannot click on it). You can Click on Default just to be sure. Next click the Intranet so that it is highlighted and make sure DEFAULT is grayed out so that you cannot click on it. Do the same thing for the other two zones (Trusted Sites and Restricted Sites). After all zones under the Security Tab are set to Default click the next Tab which is the Privacy tab.
On the Privacy Tab you want to make sure that DEFAULT is grayed out, if not click on it. When in doubt just click the Default tab.
Next skip over the Content tab and proceed to click the Connections Tab. On the Connections Tab make sure that the Never Dial A Connection is checked if you have something in the white box above it in for Dialup and Virtual Private Networks settings. Look down on the right near the bottom and Click the LAN SETTINGS button. When Lan Settings open up the only box that should be checked is the very first box that says: Automatically Detect Settings. If any other box is checked remove the check from it or you will never be able to connect. Click OK to close the LAN SETTINGS tab.
Next skip over the Programs tab and click the Advanced tab. When it opens slide the blue bar on the right all the way down until you get to the bottom of the window. You want to be able to make sure that if you see something like (Use SSL 2.0, Use SSL 3.0, Use TSL 1.0) that you put a check in the box to the left of each one of them. Afterwards you can click OK to close the Internet Options Window.
Next lets go boot your computer in Safe Mode.
Go to www.google.com and in the search box type:"Download cnet Malwarebytes" (without the quotes). Download andinstall malwarebytes from the sites download.cnet/malwarebytes. When thesite opens up click on the Green Download button on the left. Do notclick the Red Download button, that's junk. When it finishes installing the GuiInterface will open up with an offer to Accept a Trial Version orDecline. CLICK DECLINE you want the totally free version. Run aQUICK SCAN. As it scans, if it finds infections the number will be inred. When it finishes scanning, click SHOW RESULTS. A notepad textdocument will open up showing you the results. You can close the textdocument and go back to the Gui Interface where you will click
If it works then unplug the network cable (ethernet cord) and turn on the wireless on the laptop. Also make sure you have installed the wireless usb adapter's drivers on the laptop.
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
Jun 05, 2012 | Gateway Computers & Internet
I have sony vaio S. but the wirelees is not working no wireless host shown. how can i fix it?
Selecting the wireless function Follow the steps below to select the wireless function to be activated when you set the WIRELESS switch on your computer to on. Double-click (wireless switch icon) on the Notification area at the bottom right of the desktop.The Wireless Device Switch dialog box appears. Hints The appearance of the wireless switch icon changes depending on the selected wireless function. Point to the wireless switch icon to display the selected wireless function. Alternatively, you can right-click the wireless switch icon and select "show Wireless Device Switch settings" to display the Wireless Device Switch dialog box. Select the desired wireless function from "Wireless LAN" or "Bluetooth Device". Notes 5 GHz Wireless LAN is available on certain models only. You must select at least one wireless function to perform wireless communications. The 2.4 GHz and 5 GHz Wireless LAN functions employ different frequency bandwidths, thus are not compatible with each other. Checking the check box for both "Enable 2.4 GHz Wireless LAN" and "Enable Bluetooth Device" may cause poor communication performance or a connection loss due to electromagnetic interference. Click OK. The message "Setting up the wireless devices. Process may take several minutes. Please wait." appears first, then the Wireless Device Switch dialog box is closed, and finally the dialog box that describes what to do with the icon on the Notification area appears. Note While the message "Setting up the Wireless Devices. Process may take several minutes. Please wait." is displayed, do not: place your computer into power saving mode. turn off Windows or log off from the current user. turn on and off the WIRELESS switch. Confirm the settings and click OK. The dialog box about the icon on the Notification area closes. Hint If you check the "Don't show this dialog in the future" check box, the dialog box will not appear next time you close the Wireless Device Switch dialog. To analyze the network condition You can analyze the network condition if you select either or both of the wireless functions under "Wireless LAN" in step 2 above. Click the "Diagnose" button to start Windows Network Diagnostics. When the network analysis is complete, the result is displayed. If any problems are found, follow the on-screen instructions. Hint Windows Network Diagnostics is the function to identify problems the network has and present solutions to them.
Mar 01, 2011 | Sony Computers & Internet
I have a NetGear router set up as a primary router connected to the modem but it was giving me problems with WiFi. I bought Bellkin f7d4302 to use for reliable WiFi connection and also to connect my main...
I got your issue, I hope you are trying to connect the 2nd router to the first router through LAN-LAN connection (i.e, LAN port of the first router is connected to the LAN port of the 2nd router)
Then you need to change the ipaddress of the 2nd Play Wireless router . Please follow these steps.
1. Connect the computer-router with ethernet cable and open up internet explorer and clear the address box and type in 192.168.2.1 and hit enter.
2. You will be logged into the Belkin router setup page, in the Left hand side under LAN setup click on LAN settings
3. It will ask for Login password, leave it blank and click on submit
4. Change the LAN ipaddress from 192.168.2.1 to 192.168.5.1 and click ok
5. The page will say cannot be displayed, then clear the address box and type in http://192.168.5.1 and hit enter
6. If your first router is connected to the internet , then automatically the internet status will says connected
7. You will be able to go online wired
Good Luck!
Thanks in Advance!
Regards,
Prema
Dec 29, 2010 | Belkin Wireless Play Router (F7D4302)
How to set up nintendo wii internet
  • 1 In order to set up your Nintendo Wii internet connection, you need to have high speed internet service, such as DSL, cable, or fiber optic.
    If you want to use a wired connection for your Wii, you will need to purchase the Nintendo Wii Lan Adapter and a long ethernet cable to reach your router or modem. The Wii Lan adapter is available from many sources for about $30 and the cable will cost you around $10 or more. If you want to plug in your computer and Wii at the same time, you will need a router. You do not need a router if you are planning on unplugging your computer when you use Wii over the internet. Honestly, wireless routers cost about $35 and don't require a cable, so I purchased a wireless router instead. Plus, I don't want an ugly cable running across the room.
    If you still want to use the Wii Lan adapter to connect to the internet, here are the steps to connect your Wii Lan adapter to your Wii game system:
    Make sure your Wii game system is turned off.
    Attach the Wii Lan adapter to the USB port on the back of your console.
    Connect the other end to an ethernet cable that goes to your router or modem.
    Turn your console back on.
  • 2
    If you are using the Nintendo Wii Lan Adapter to connect to the internet, follow this step. If you are connecting to the internet via a wireless router, skip this step and go to step 3.
    To connect your Wii via a wired connection:
    Go to the Wii Menu.
    Click on the round Wii button on the lower left corner.
    Click Wii Settings.
    Click the right arrow to go to page 2.
    Click on the Internet button.
    Click Connection Settings.
    Click Connection 3.
    Click Wired Connection.
    Your Wii will do a connection test and hopefully everything will be all set. You are now finished.
  • 3
    To connect your Wii via a wireless connection:
    Go to the Wii Menu.
    Click Wii Settings.
    Click Connection 3.
    Click Wireless Connection.
    Select Search for Access Point. Click OK.
    Select the access point you want to use. Click Save and OK.
    You may be prompted to enter your password.
    Your Wii should now be all connected.
  • Nov 28, 2010 | Nintendo Wii Console
    My HP Pavilion laptop no longer connects to the internet via wireless.
    When wired go to Lan Settings which is under Internet Explorer>Tools>Internet Options.>Connections>Lan Settings. Make sure no boxes are checked after clicking Lan Settings.
    Jul 06, 2010 | HP Pavilion dv1000 Notebook
    Unable to connect wirelessly to the internet, the wireless icon is orange , when it should be green. When windows diagnosis the problems it says that windows cannot resolve wireless connectivity issues.
    Internet Connection Errors
    If you have a virus or malware that is not letting you connect to the internet or your settings have been corrupt, there is a simple setting that you can look for to correct the error. The most prevalent of these is that you can connect to the router and your network but you have no internet access. This is the one I will concentrate on here.
    Bring up your internet browser and click on “Tools”, scroll down and click on Internet Options.
    Now click on the “Connections” tab. At the bottom of the page, click on the LAN settings button.
    Make sure the box for “Automatically detect settings is checked. Now, Un-check the box that states to use a “proxy server for your LAN” at the bottom. Click OK and OK.
    Reboot the machine and try to connect to the internet, you should be able to. I have to also add that in some cases if you have “Selective Startup” selected through “MSCONFIG”….it may be beneficial to change that to “Normal Startup” until you get the other settings configured.
    Mar 16, 2010 | Toshiba Satellite A105 Notebook
    Browsers/ PC
    Check there is no proxy server in internet explorer
    Open IE
    Click Tools --> Internet options
    Click Connections Tab
    Click Lan Settings
    Make sure "Use a proxy server for your LAN" is not checked
    Check "Automatically Detect Settings"
    Click OK and OK
    If this doesn't work check there are no values set for IP addresses in
    Start --> (Settings) --> Control Panel --> Network Connections
    Right Click your Wireless Connection --> select Properties
    Scroll down to TCP/IP in the centre box and Click it to select
    Click properties and chose "Obtain Automatically" for both IP and DNS
    Click OK OK or Close
    Try Internet again
    Dec 16, 2008 | Dell Precision M60 Notebook
    Cant connect to the internet from my laptop with either wireless or wired. its a hp dv2700 running vista premium
    Jul 15, 2008 | Computers & Internet
    Wireless connection to Router is OK. But can not brouse internet.
    If you go to control panel, then to internet options, on the connections tab, click the LAN settings button. Make sure there aren't any boxes checked, then hit OK, and hit OK again to get out of there.
    If your connection is still not working, go to Network Connections in control panel. Right-click your wireless connection and go to properties. There will be a list of items with checked boxes. Scroll down to the Internet Protocol(tcp/ip). Click it one time to highlight it, then click the properties button. Make sure your settings are Obtain IP address automatically. And Obtain DNS server address automatically.
    You should be working. If not, let me know.
    Jan 28, 2008 | ASUS WL-500W Router (WL500W)
    Toshiba Satellite L305-S5894 Notebook Logo
    69 people viewed this question
    Top Toshiba Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
