Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
I have a kenmore 52552100 side by side that all of a sudden quit cooling/freezing, a fan on the back constantly kicks on than off again after a few seconds
    President:
  • 1,561 Answers
I advice you check the fan if it is not occupy by dust or dirt, it it is, vacuum the fan with air blower to see if it will fix the problem, because if the fan on your refrigerator is not rotating or working your refrigerator cannot be cold.
If the fan is not dirty, or perhaps after you vacuum the fan with a blower, the problem still persist, it means you will need to replace the fan on your refrigerator, to replace the fan, follow the procedure below.
Turn off the power to the appliance by unplugging the refrigerator from the wall. Open the freezer door and take all the food out. Remove the freezer shelf.
  1. Remove the back panel of the freezer compartment. You may have to remove one of the freezer shelf supports on the side to get the panel out.
  2. One of my screws was corroded in place. When I tried to remove it, the head started to strip. I used an electric drill and a large twist bit to drill the head off that one. Hopefully, you won't have to do this. If you do, be very careful not to drill through the back plate, or you might drill a hole in the evaporator. Then you will have trouble you probably can't fix.
  3. 4Remove the plastic housing covering the fan. Mine had 4 small hex screws holding it in place. Once this is done you can see the evaporator fan. Mine had two screws holding it in place and three wires hooked to the fan. Make a note of the position of the wires.
  4. 5Carefully grasp the wire connectors and wiggle them off. Don't pull on the wires themselves, only on the connectors.
  5. 6There is a little metal box that the fan sits in that will come out when you remove the fan.
  6. 7Get the new fan motor out of the box. The fan blade is not attached. Get the new plastic fan and remove the bronze-colored metal clip on the fan's hub. Carefully press the fan onto the fan motor shaft. About 1/8" of shaft should protrude from the front of the hub. Use the needle nosed pliers to spread the metal clip apart, and slip it on the hub. Push the metal clip down into place with the flat screwdriver. The front of the clip should be approximately flush with the front of the hub.
  7. 8If you have a steel freezer interior you will use the grommets, screws, and bushings to reattach the new fan. The mounting holes in the new fan are much larger than the holes in the original fan. If your freezer has a plastic interior, you may not need these parts.
  8. 9Position the electrical lugs on the fan so that they will be in the best position to receive the wires when you reinstall it. In my case this meant rotating the ground wire lug (green wire) to make the wire fit better. There was almost no slack in my wires.
  9. 10Use the screws that came with the fan to position it and just hold it in place. Don't screw it down yet. Next connect the wires in the same way they were connected before, Now screw the fan down tight, but be careful not to strip out the plastic screw mounts.
  10. 11Rotate the fan by hand and check for noise. If the fan blades are hitting something, you will have to reposition a part. Once it sounds good, turn the power back on for a minute and make sure the fan operates quietly. Don't touch anything inside the refrigerator at this point.
  11. 12Once again, unplug or disconnect the power, then reinstall the plastic fan housing and the freezer back plate. Put the shelf back in and you're done!
Take care.
Posted on Jul 03, 2010
  • 1 more comment
  • monika_montg Jul 05, 2010
    Thanks for your answer. I had the fridge looked at and was told that it was the compressor and to just get a new fridge as the repair would be around 500. I paid $75 for a quick diagnosis.
  • Larry Goad
    Larry Goad Mar 01, 2014
    Same frig., mine was the master control board that they wanted $400- $500 to fix. I removed conforml coating with heat gun, sure enough COLD SOLDER JOINTS ON MAIN RELAY TO COMPRESSOR.. This is a manufacturing problem, but none of the makers are not responsible for this problem. Board wasn't hot enough through wave solder process. Those parts should be hand soldered. Just think of all of the people who will be paying for this board replacement for a cold solder joint problem.
  • Larry Goad
    Very easy to fix but the repairmen will not do this, only board swap. What a shame.
Wont cool anymore or freeze,used to be able to unplug and it would start working again.Not this time ,the compresser will not come on.is there a sensor to tell it to come on.
If it won't come on then it can't cool or freeze. Was it not freezing before it quit? Not freezing could be low freon and the inside coils may be iced up. This unit may have a bad start capacitor or need a hard start capacitor kit to help it kick on. Empty the freezer and take a look-see behind the removable back panel. Come on back .
Sep 07, 2013 | Samsung RS2630SH Side by Side Refrigerator
I have a Kenmore Coldspot Side by Side that is about 13 years old. It appears to work for about 12 hours or so and then both sides quit working and then the cycle begins again. The ice will all melt...
Hi, from my experience dealing with repairs of refrigerators and freezes, it is a fact that you likely have a bad condenser coil, condenser fan or condenser motor whenever your refigerator switches itself off and put it self on again. So you have to check one after the other to ascertain the faulty part and replace it...
May 15, 2011 | Kenmore Side by Side Refrigerator
Kenmore SxS 596.52673200 stopped cooling
You have a refrigerant leak. Your coil in the freezer should be frosted. You're looking at 600 dollars minumum for repair.
Sep 12, 2009 | Frigidaire FRS23H7CS Side by Side...
Kenmore a/c window unit fan not kicking on with compressor.
Likely a bad motor, when this occurs verify the board is sending voltage to the motor.
May 30, 2017 | Kenmore Heating & Cooling
Refrig/Freezer not cooling
"compressor not functioning". You Probably need a New Compressor. I have a Family Member whos Refrig/Freezer Compressor had to be replaced under Warranty when it was only 2 years Old.
May 12, 2009 | Refrigerators
Cleaned coils,lower fan, drain lines. Checked door seals, temperature reset, both fans are runnign but
Need a New Compressor. That is the only way of Cooling. If it was working and not cooling it could be the Condensor or low on Freon.
Not cooling, compressor kicks in for 3 seconds then back out
No the PTC relay on the compressor is bad. Need to replace it.
First be sure to unplug frig. Remove the cardboard cover that covers most backs of the frig units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Apr 04, 2009 | Kenmore 53642 / 53644 Side by Side...
Water freezing up in the bottom of the freezer
your defrost drain is stopped up then when it defrosts in steed og going down the drain its running in the freezer floor remove the back panel in the bottom of the freezer and clear the drain hole under the evaporator
Mar 12, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore fridge stopped cooling
sounds like its freezing up on you. check the drain outlet and make sure that its clear. also i would replace the defrost timer on this unit because its suppose to bring on the heaterfs to melyt the ice so thaat yoiu don't have to. they are around 30 mdollars at the appliancew repair store and all you need is the model number and serial number for the uit. after you get it it's either on the very top of the refrigerator section or in the very back. It has 4 wires going to it. good luck.
Jan 12, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore Refrigerator Freezing Up - Won't Defrost
i have a side by side kenmore frig freezer on th frig side the pop is freezing up and the water that comes out the door whtat could be wrong
Oct 12, 2008 | Refrigerators
Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator Logo
166 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
