Question about HP Deskjet D1560 InkJet Printer
The printer is showing the message offline,how to reslove this
    Scholar:
  • 42 Answers
Please click on start on the computer----Control Panel-----printers and Faxes.
Please right click on the printer icon and click on use printer online.
Then again, click on the printer icon and click on cancel all documents.
The issue will be fixed.
If still you are not able to print, pleae follow the below steps.
Click on Start on the computer---- and in the search box or RUN type "services.msc" and hit enter.
Here you will see an option "print spooler".
Just stop that print spooler
and then restart that spooler.
This will make it print.
If still you are not able to print, please follow the below steps.
FOR XP operating system
Click on start button on computer then control panel then printer and faxes.
Click on the option of Add a Printer and click on Next on the Wizard.
On the next page select the option of Local Printer and uncheck the option of Plug and Play devices.
On the next page, select the option of Use Existing Ports and select the option of USB Virtual Port and click on Next.
On the next page, select HP as the manufacturer and Deskjet 990c as the printer.
Verify the printer name and set the printer as default then click next.
Select print a test page option.
Click on Finish.
FOR VISTA operating system.
Click windows logo and go to Control Panel.
Click on Printers.
Click Add a printer. This launches the Add Printer Wizard.
Click Add a local printer.
Now, Use the drop down arrow to select USB port 001 then click Next.
Select the Manufacturer as HP from drop down list and select DeskJet 990c from printer drop down list. Click Next.
Click on Finish.
Posted on Jul 03, 2010
HOW TO FIX...PRINTER IS OFFLINE BUT IT IS ON...WE ARE UNABLE TO PRINT.
If you are getting a status message as the printer is offline on your pc,and afterward you can't ready to print the reports.
Steps to Resolve the Printer Offline Issue:
Step 1:
At first, you need to check your network through the HP Scan Doctor which encourages you to discover and fix the printing issues.
Steps To Run the HP Scan Doctor
    •Open the HP Scan Doctor tool by double tapping the symbol.
    •Start- - >Select your printer- - > Fix Printing
    •Then the list of issues displayed on the screen as result.
    •If the tool shows the white checkmarks at that point there is no issue.
    •If the tool shows the white wrench then the issues are found and repaired
    •If the tool shows the yellow shout point then the issues are found however that can't be solved or skipped.
    •If the device shows the red stamp then you have to take after the on-screen guidelines to determine the issues.
    Step 2:
      Set Your Printer as Default Printer
      •Search your gadget on your PC and select your printer and uncheck the Pause Printing and Use Printer Offline
    •If you can capable print implies your printer is online.
    Officejet 4650 keeps going offline then proceeds with following step Step 3:
    Check Whether You Connect With Correct Port
      •Go to printer- - > Printer Properties - >Port
      •For USB association utilize USB or DOT4
      •For Network Connection use WSD, organize, Standard TCP/IP Port Step 4:
      •Update the printer firmware which may resolve your issues
      Step 5:
      •Manually connect the wired or wireless connection
      Step 6:
        •For network connection just you have to add the second printer to your Windows.
        •Select your printer - > Properties - >Add Port - > Standard TCP/IP Port - > Next port
        •Now you can ready to print implies stop the troubleshooting. Still get the same issue mean you need to connect the printer customer support via +1-800-836-3987
Jan 08, 2016 | Office Equipment & Supplies
Why the offline message
Check the status of the printer at Control Panel. Set it to online if it's shown as offline. If this doesn't fix the problem, check whether installing the vista driver available at your printer manufacturer's website helps.
Step 1:
a. Click Start, go to Control Panel and select Hardware and Sound.
b. Click Printer.
c. If the Printer is offline, it shows "Offline" status. If the Printer is online it shows "Ready".
d. If the Printer is offline, set it to online.
e. Right-click on the printer and select "Use Printer Online".
f. The display should change to ready when the printer is set to online.
Read More....
How to Fix an Offline Printer eHow and HP Printer Support
Thanks,
Jul 16, 2014 | HP Officejet Pro L7780 Printer
Got canon MF4200 printer that was installed and had status of ready when complete. After few hours, status is changed to offline. How can I reslove the issue and return to ready status?
I am also getting this type of problem. I did everything like troubleshooting, repair, update reinstall of driver but I still got this problem. My computer is also connected with other network printer and every printer is working fine except thi MF 4200 printer. Please help me to solve this isssue.
Jan 25, 2011 | Office Equipment & Supplies
Offline
If the Lexmark printer creates any error message that shows offline mode, you might have to convert the printer to online mode. In order to turn on online mode select the start menu and click on the "Printers and Faxes" icon. This shows you all the printers and other devices that are connected to your system at that time. You might have to double click on the printer icon in order to change it to online. A pop up might come up while performing that and you have to go to printer option in the menu bar of pop up window and have to uncheck "Use Printer Offline."
Jan 20, 2011 | Lexmark E260dn Laser Printer
My computer sys it is offline, and it is making noises but won't print anything.What is wrong with it?
Rcommend you download and install the HP Print Diagostic Utility. The utility is designed to reslove common printing problems, including 'printer is offline'.
Go here, select your operating sysytem, a list of available downloads for your printer, including the driver, software and updates will be displayed.
If you do not know your operating system, i.e. 32-bit vs. 64-bit, open Control Panel and click on System. Look under System Type.
Choose the desired downloads for your system.
Jan 16, 2011 | HP DeskJet F380 All-In-One Printer
Printer Offline Message
If your system is showing Printer Offline message, then you need to check the status of the printer in control panel. If it is offline then you need to set it online. The following steps will help:-
1) Click start -> Control Panel -> Hardware and Sound -> Select Printer.
2) If the printer is online it shows "Ready". and if the printer is offline, then it shows "offline".
3) Set the printer online if it is showing offline.
4) Now right click the printer and select "Use Printer Online".
5) The display should change to ready.
Note:- If still you are facing the issues, then update the printer driver or you can also take assistance from any tech support provider such as AskPCExperts. To know more you can also visit: http://www.askpcexperts.com.
Jan 07, 2010 | Epson Aculaser C1100 Printer
My printer is offline - how do you get online
delete printer drivers
if ur using from an usb then
restart ur pc or laptop
and reinstall drivers
check if any error message is showing on ur printer
Nov 30, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Dell printer 1710 n .
In Control Panel - Printers, Right-click the Dell 1710N and remove check for Offline.
Jun 12, 2009 | Dell 1710n Laser Printer
Printer has connected but offline.
your printer correctly installed to your pc the printer driver I mean did your install it correctly? The usb cables has correctly attach to the CPU and printer? Thier is no broken wires of your usb cable did you try to replaced it with new one usb cable.
Apr 18, 2009 | HP Deskjet 2360 InkJet Printer
HP Deskjet D1560 InkJet Printer Logo
132 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
