There a hummings noise and the picture is coming out a different color i checked the bulb its still good any suggestions
  • 5,138 Answers
If your TV is a Samsung then its the Color Wheel ,Its really hard to give you correct information without knowing the Make and Model number printed on back of TV.
Posted on Jul 03, 2010
After about 30-60 minutes TV starts to hum and picture gets distorted, could this be the color wheel...???
Sounds like a sync problem due to color wheel speed. clean and lubricate color wheel motor with tiny amount of Z-Max lubricant (liquid Buckey balls, available at Wal-Mart), on each bearing. make sure wheel is free-wheeling and turns easily. Should cure problem. If the color wheel is in good shape, there is a power supply problem, which may be due to dried out electrolytic capacitors or a regulator that's failing. Troubleshooting or controller board replacement may be needed. Regards.
Dec 07, 2015 | Mitsubishi WD-73840 73" 3D Home Cinema...
Loud humming or buzzing noise have picture but flashes all different colors resets and goes off after awhile good pic after that
The tv problems and causes are 100% is the tv colors wheel it is causes and the tv problems.The tv are having humming or loud buzzing noises sounds are the causes of the tv colors wheel going off and out control of it motor mount and spinning in at high RPM speed and different colors showing up or flahes of black and white color in the tv back ground.The tv colors wheel must have to be replace.Best hire a tv tech to do the replacement of the tv colors wheel,because have to take out many mechanicals parts before can even come to the tv colors wheel is self to replace it.
Aug 19, 2011 | Samsung HLP5067W Television
My warranty has run out of course and now my tv decides to flash after running for awhile randomly. It looks like interfereance, but after a few minutes the three lights start to blink and it tunrs off. It...
Ur tv have a colors wheel design inside,it dying and will be dead soon.Tv have humming,squiling noises or motor noises.Have colors or blak&white flashes within the pictures.The colors wheel is old and it it worn out not spinning correctly inside it motor mount anymore.Hire a tv tech. to do this,because colors wheel sit way back of many machanical parts must take out even can come to the colors wheel it self to replace.Never done this or have no machanicals skill don't tries this.Hire a tv Tech. ok.
Jan 06, 2011 | Samsung HLN5065W 50" Rear Projection...
I've a Samsung DLP Model HLR-4266WX that has started to hum and is distorting the picture. I've replaced the cooling fan on the heat sink in the back and that didn't work. Is there another fan in the set...
Color wheel would be cause of hum noise and distorted picture on screen.
Please note that color wheel is not user level repair and requires expertise because it is located in light engine, the most sensitive and expensive part of dlp tv.
If you are good with electronics stuff fix then have service manual copy in hand to start inspecting color wheel.
Aug 26, 2010 | Samsung DLP HL-P5663W 56" TV
Screen went B&W and I hear a loud humming noise from the TV...
Hi John,
If you are hearing this noises,that's your Color Wheel.
The reason fot that is because your color wheel spins 5000rpms(revolution per minute) and something that modifies the balance if the disc can cause different things.Unfortunately in order to check if your color wheel is working properly you need to open your TV and physically check out.
Grinding= Most probably the color disc is broken and you need to replace it.
Spinning / Buzzing = The bearing of the wheel is loose and is loosing its balance,eventually it will brake.
The best thing to do is to take the color wheel out and spin it ,if you feel that the disc kind of wobbles or doesn't spin smoothly you have to replace it.
You can check DM they have very good prices
http://www.discount-merchant.com/SearchResults.asp?Search=samsung%20color%20whee l?click=52978
I hope this will help,please keep us posted
Oct 05, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Same humming , but then goes off.
Color Wheel it is you can get one for around 95.00 up depend s on Part# BP96-00674A cost 113.69 Call Encompass Electronics 1-800-638-3328.Just looked it up they have it.
Sep 18, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
I have a 44 inch 44nhm84 DLP. When the TV is turned on, it makes a loud humming noise that goes down in intesity twice and then finally a lesser humming noise after the picture comes on. At first I thought...
This does sound like a color wheel. To my knowlege, Toshiba does not sell the Color Wheel seporately. In short, you have to replace the Opical Block. The cost of this is very exspensive and Toshiba may not sell it to you. You may have to go through a Toshiba Service facility to obtain it. Check prices of new LCD sets before investing the money.
Hope this helps,
Skyassoc
Jun 18, 2009 | Toshiba 44NHM84 44" TV
Humming noise
There are only two moving parts in this set. The fans and the color wheel. Typically when the color wheel starts to break or go on the fritz, the tv stops working. Count your blessings you've still got the picture. Open the back and turn the tv on. The color wheel is located on the optics block tray. The fans are very visible with the back off. Stop the fan for a second and see if the sound goes away. If not, you might want to start looking around for a replacement color wheel. Rivervalleyelectronics.net is a good place to start. Sometimes Discountmerchant.com carries them too. Be aware that there two different wheels available. If the fan is the culprit of your problem. Radioshack will likely have a replacement for you. If you need further help, post a comment or email me and I'll send you pictures of what to look for. Cfoley@hawaii.rr.com
Good luck.
Mar 21, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Toshiba #62HM95
I am wondering if this sound might be your color wheel spinning. The color wheel often makes a low humming noise as it spins. Try checking to see if this is not the source of your noise. You need the color wheel to generate the colors needed to turn the B&W picture generated by the DLP into a color picture.
Thank you,
Shuttle83
Nov 08, 2007 | Toshiba 62HM95 62" HDTV
Televison & Video Logo
Top Televison & Video Experts
