Question about Philips Televison & Video
My disk wont eject from my philips 3400/37 recorder. I get a message that says blocked on the window
  • cdavis480 Jul 05, 2010
    Well it worked. Thanks!!!!!!!!!!!
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Disk Locate your disk player’s manual Eject button. It is usually a small hole located underneath the disk drawer. Insert a stiff wire—such as a paperclip or safety pin—into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open. Remove the disk and see if there is a problem with it. If still the issue is not resolved then take a smallest screw driver and press the eject button and simultaneously use the screw driver towards you and disk drawer will come out. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 03, 2010
  • cdavis480 Jul 03, 2010
    There isn't a small hole underneath the disk drawer...that was the first place I looked.
  • Rylee Smith
    Rylee Smith Jul 03, 2010
    Then please take a smallest screw driver and press
    the eject button and simultaneously use the screw driver on the upper side of
    the disk drawer and pull it towards you and disk drawer will come out. Please
    assistance.
    Thanks
    Rylee
I have a dvdr3355.It has a rewritable dvd in it thatI have been using and has recorded programmes on it.I am trying to remove it but the window just says blocked and I cannot find a way to release it.Could...
If you cannot get the disk to eject, power the device off and insert a paper-clip into the emergency-eject hole in the front of the device. It should be located just under the disk tray.
Feb 27, 2008 | Televison & Video
I was watching a dvd and it froze half way as i was watching it. it now says blocked and wont eject the dvd any help would be great thanks
1. You will need the Philips support to eject this DVD
call the tech support and they should give you the remote code to eject the DVD.
Feb 04, 2010 | Philips DVDR610 DVD Recorder
Tray wont open on my philips cdr600 recorder , can it be fix
You can try the following:
Unplug power cord.
Plug back power cord.
Press start and push repeatedly the eject button while the unit is starting, before the Player start reading the CD.
Try this a couple of times.
if that does not work, then you will need to disassemble the unit, unplugging from power, and removing the screws at the bottom and at the back, to access the drive and remove disk manually.
Jun 18, 2009 | Philips CDR600 CD Recorder
Unknown disk type
Press 'Disc Menu' and wait for 'no disc' to appear on the screen. Eject the tray by pressing the 'open / close' button on front of the recorder. Enter the following numbers very slowly on the remote control ' 0086000 ' Press ' OK ' button on your remote control. Close the tray by pressing ' open / close ' button on the front of the recorder. You can check this has worked by pressing ' 0009 OK ' on your remote after the tray has closed. A display will pop up on screen showing the Region as 0. This means you should be able to play discs from all Regions. If this doesn't work the first time! try again! Hope this helps!!
Jan 24, 2009 | Philips DVDR3380/05 DVD Recorder
3370 H player is 'blocked' cannot eject disk
The eject motor drive may be weak. I find that lubrication does not solve the problem.
Oct 16, 2017 | Televison & Video
Hi there, try tapping it lightly with your hand just above the tray and then press eject button!! It works everytime with my one!! Hope this helps!!
Nov 01, 2008 | Philips DVDR3380/05 DVD Recorder
Disk Recover message and trays are locked
I have had the same problem. To reset the machine when this happens: 1.Switch off with front panel switch (display dims, but still shows same message). 2. Switch off at mains socket, leave off for about 15 seconds. 3. Switch on at mains socket then front panel - machine should then start up as normal.
I have experienced the "disc recover" condition several times now, when a radio recording has run to the end of a disc, and for some reason the recording process has not terminated properly, resulting in the loss of the recording. I found by trial and error that if you switch the mains off at the socket without first switching off at the front panel, then the disc can become corrupted and useless.
I suspect it is partly dependent on the make of disc as my current batch of TDK RWs do it almost every time, whereas with my last batch (can't remember if they were Maxell or Memorex) seemed much better.
I think the only way to prevent the problem is to manually stop the recording before the end of the disc is reached, I suspect possibly before the 74 minute 'red-book' CD limit is reached, even on an 80 min. disc, though I haven't yet tested that theory properly.
Hope this helps,
HifiJohn
Aug 31, 2008 | Philips CDR796 2-Disc CD Recorder
DVDR 3460H - problem ejecting disk
1) Turn it upside down.
2) Turn it on
3) Press eject button & use screwdriver with special slot
Similar example
http://www.ryan.com.br/prod_dvp642_ejection.htm
Mar 23, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Hung up - disk won't eject
cd recorder disk will not eject
Dec 08, 2007 | Panasonic VDR-M70 DVD Camcorder
Televison & Video Logo
48 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
