Question about LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television
Have changed the bulb in the dlp tv still has a blue @ red dots on the screen,it reset ,door closed good
  • LG Master
  • 5,138 Answers
Light Engine needs replacing Call UED 1-800-648-6657 for prices on rebuilt ones if they have any,also try Encompass Parts Distrubtion 1-800-638-3328.
Posted on Jul 03, 2010
Power light blinking red..tv won't come on after replacing lamp
DLP TV Repair Tutorial - DLP Bulb Won't Turn On - YouTube
? 14:13
https://www.youtube.com/watch?v=5frOnh58Z6M
Jun 26, 2013 - Uploaded by ShopJimmy.com
DLP TV Won't Turn On Common How to Replace Ballast DeadTV ... solid green power light plus sound ...
• New Lamp Doesn't Turn On? Try This! - Fix Your DLP - FixYourDLP.com
www.fixyourdlp.com/forum/viewtopic.php?t=19
Mar 12, 2009 - 50 posts - ‎36 authors
Mine did the same thing after replacing the lamp. ..... TV won't turn on and Color Wheel is GOOD, Temp sensor is GOOD, Ballast is GOOD, and ... • NEW Bulb- still not working
Jan 14, 2010
• Resetting the Samsung DLP Lamp Counter/Hour Meter
Mar 20, 2009
• Samsung Dead Lamp, Black Screen, or Intermittent
Mar 12, 2009
More results from www.fixyourdlp.com
Samsung DLP: replaced lamp however tv won't turn on - HDTV ...
Dec 09, 2015 | Televison & Video
My WD60638 has a couple of white dots on the screen, what causes this and how can i fix the problem
if its a dlp tv most likely the dots are from.the bulb if its an lcd tv your screen may not be of high quality u need to change it
Oct 02, 2015 | Mitsubishi WD-60638 DLP TV
Light bulb
White dot for DLP Projector TV is not because of the light buy. It is caused by aging DLP chip ( DMD Chip.) Your TV DLP Part should be the following image:
Check the post how to place it diy
May 04, 2012 | Televison & Video
I have blue dots all over my screen aa well as
This blue dot and hue problem is due to bad lcd in your tv as its Sony dlp tv that has optics block, that is also called light engine, it consists of 3 lcds, filters and lamp to produce an image that projects on front screen.
In this tv, blue lcd became defective and complete light engine will be replaced to get it fixed.
As other expert talking about blue CRT (cathode ray tube) that does not exist in this tv and my fellow expert has no idea about this kind of tv, sorry for that.
Hope this info will help you, let me know if you have additional question.
Thanks.
Dec 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
The tv has power , the volume comes on ,but no picture,just black screen. The red change lamp light has been on for some time,and it is still on
I believe this is a DLP set. There is a single high power bulb that shines thru the dlp chip and onto the screen. My old Panasonic 55" (forget the model) had the bulb access on the front left side-1 phillips screw to remoce the door and another to pull the light assembly. Replacement bulbs are available plain or in the assembly-your choice. Just google your make and model plus DLP bulb and you should be good to go- I paid $85 for the bulb alone- order 2 as the life span is much shorter than what panasonic claims- there was even a class action lawsuit over this issue that covered about 10 different set.
Dec 19, 2009 | Panasonic PT-51HX41 51" Rear Projection...
I have a toshiba 65hm167 no red color on the screen
Your TV is a DLP one lamp does it all, not like the old projection TVs with the Red, Green & Blue CRTs. Your TV may have a bad light engine or lose cable connections.
Good luck
N Sabre
Nov 08, 2009 | Toshiba 65HM167 65" Projection Television
Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Jul 11, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Have little white dot's on screen will changing
Highly unlikely the bulb could be at fault; it sounds a lot like a defective DLP chip. If you are not aware of how this device functions, it is an array of physical mirrors which can fail individually and cause the effect you are having. The bulb failing would cause a loss of the entire screen, not just a few points.
Jul 05, 2009 | Samsung DLP HL-P5663W 56" TV
LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television Logo
Computer Repairing
Computer Repairing
