Question about Mitsubishi VS-50605 50" Rear Projection Television
Rear project TV problem
I saw you had a post about a rear project TV with a rolling lined screen. Can this be fixed?
  • 1 more comment
  • Jason31 Apr 17, 2008
    I don't use the Picture in Picture, never have. How do I bypass it?
  • Anonymous Aug 02, 2008
    it takes about thirty minutes or so after the tv is turned on for the lines in the tv to go away.
  • dromej31 Aug 02, 2008
    Mu tv takes about 30 min for the lines in it to go away then its ok,.any way to fix this?
My tv rolls so bad you can not see a thing. so what i did [ you may not believe it but it works for me] i removed the front cover removed the wood panel then in about 15 seconds it stopped rolling about 4 hours later it started to roll again so i set up a small [ 8" ] fan in front and it stopped rolling if i turn the fan off it starts rolling again when i turn the tv on in the morning it starts to roll until i turn the fan back on i know it sound stupid but it works the roll i have is very bad and it works
Posted on Jan 14, 2009
  • Mitsubishi Master
  • 8,617 Answers
Yes it can be fixed depending on your model number if its the VS50605 they have a kit to repair the PIP module which controls vertical sync (Rolling) or you can bypass the module to correct it but you would lose the PIP function. Let me know if you need more info.
Posted on Apr 17, 2008
  • Sonny Berry
    Sonny Berry Apr 17, 2008
    solder two lengths of wire on each leg of the two capacitors listed in the proceedure below so the caps wont short out when they cross over each other. Heres the by pass if you need me to clarify anything send me an email slinteriors@yahoo.com
    There is a quick test you can do to determine if the problem is in your PIP module, using two 4.7uf/50v electrolytic capacitors. The PIP module plugs into two connectors on the main board. Remove the PIP module, and on connector VP on the main board (the 11 pin connector), use one cap to jumper from pin 7 to 9 (negative lead on pin 9); and use the other cap to jumper from pin 5 to 11 (negative lead on pin 11). If the PIP module is bad, you will now have video.
Thick black line rolling up the recorded video of the TV
That is the camera not being in sync with the refresh rate of the TV. With consumer gear, there is really not much you can do about it.
Sep 08, 2009 | Mitsubishi WS-65809 65" Rear Projection...
The on and off switch will shut the TV off after
my philips rear projection tv shut down within 1 minute when on rolling the letter av from up to down and curved uo and down also have red lines in screen
Sep 01, 2009 | Philips 50P8341 50" Rear Projection...
Old magnavox 52 inch big screen tv - screen rolls, jumps, loses c
the screen on my hdtv has alot of marks on it how do i get another
Feb 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
Rolling screen
my screen on my mitsubishi won't stop rolling
Aug 22, 2008 | Mitsubishi VS-50607 50" Rear Projection...
CONVERGENCE AMP
average price for the repair is around 400.00, sounds like there is an extra charge because of the distance involved.
Jun 06, 2008 | Hitachi 51F510 51" Rear Projection...
Sony -kp65wv600
I got this TV for FREE from a guy posting it on craigslist because he saw "BLUE SWIRL LINES" also knows as "Retrace Line" on the screen and he went to several repair people and got high repair costs so he was giving it away for free, but i found a guide that tells you how to adjust the tv to make the blue or green or red lines go away, aparantly the line show up because the voltage on the color ray gun tubes that get out of adjustment. Here is the Link to the REPAIR GUIDE. http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Jan 11, 2008 | Sony KP-57WS500 57" Rear Projection...
White horizontal lines on screen
Replace all electrolitic capacitors on the Proscan pcb.
Dec 11, 2007 | Televison & Video
KDF 42 Sony Wega
Nov 08, 2007 | Sony KP-57WS500 57" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
181 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
