Question about Acer AT3705W-MGW 37 in. LCD Television
My lcd Tv Acer AT3201W made a loud pop which caused the circuit breaker to trip I no get no power to the tv
  • Acer Master
  • 8,457 Answers
The tv power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Jul 03, 2010
Had a loud snap when watching then no power.
TV repair, clicking and will not power on, loud snap, no ...
? 13:57
https://www.youtube.com/watch?v=UKoR7pWAHzk
Nov 25, 2014 - Uploaded by Robert DIY
TV Power board replacement - 30 - 60 minutes ($20 / $110 / $250 / Replacement) This video will show you ...
Samsung LCD 46 Pop! Then Dead! - TV Forums
www.tv-forums.com/...Repair.../Samsung_LCD_46_Pop!_Then_Dead!_...
Nov 23, 2011 - 7 posts - ‎3 authors
While watching TV, I heard a loud pop, then the tv went dead. ... Ok, so I tested the fuses and the main fuse, by the power plug, had no ...
Samsung power defect causes some TVs to fail, and a class ...
www.cnet.com > Home Entertainment
CNETFeb 14, 2012 - A defective capacitor in some Samsung LCD, plasma and DLP TVs is causing the ... The LN-S4051D is one of the TVs Samsung admits has issues ... In a February 9 report entitled "More than 7 million Samsung TVs plagued by possiblepower defect", ..... Today I heard a loud pop and now I have no picture.
Feb 09, 2016 | Samsung Televison & Video
Lights went out breaker was thrower switched breaker to on several times when I came in tv would not come on electricity is good to it so is their a fuse and where is it on tv or is there a nother place on...
Pull the TV plug out of the electrical outlet. In fact, pull all plugs from all nearby receptacles. Try the circuit breaker. If it still trips, pull more plugs from the receptacles untill the circuit breaker no longer trips. Reverse the process to isolate the plug that is causing the circuit breaker to trip. Repair broken item.
Apr 12, 2013 | Televison & Video
Tv when plugged in trips main fuse box
If there is a short circuit inside the TV, the fuse should normally blow first before tripping your breaker. The only exception is if you have a short in the ac cord or the line filter of the TV set. Have you tried the tv on another circuit to see if it trips that breaker? If not, it could be that your first circuit is close to an overload and the TV is simply pushing the circuit "over the edge".
Sep 02, 2012 | Televison & Video
Acer LCD TV At3201W will not power on. Technical support required, I have two sets and know of a third unit with the same issue. All these units were purchased at the same time. The unit will power on with...
The only thing i've seen with those Acers that generally cause that is that electrolytic capacitors in the power supply fail causing what you're describing. It would make sense that 3 TVs bought at the same time would have about the same amount of time on them, and are wearing at a similar rate.
Good luck.
Nov 28, 2009 | Acer Televison & Video
20 amp breaker pops with only a light (60watts) and a small tv on. samething occurs in another room with an iron and a light on, These items can't possibly be brawing 20 amps. Is there a problem with these...
I have been an electrician for 11 years and when these breakers came out in 2005 what a nightmare. These circuit breakers are extremely sensitive. They are designed to sense loose connections and to protect your house from fires caused by them. By increasing the load (ie. more lights or tv) it increases the size of the "arc" created by the loose connection and the circuit breaker trips before the 20 amp maximum. What I normally find as the cause is a loose connection in one of the receptacles or switches on the circuit. A lot of times, installers will use the "quick stab" inserts on the back of the outlets or switches instead of the side screws. Usually, if you "side screw" all of the receptacles and switches it will resolve the nuisance tripping. One other item that can cause them to trip is too many dimmers on the arc circuit but it doesn't sound like that is the problem you're having.
Nov 15, 2009 | Siemens 20Amp 1-pole arc-fault circuit...
How do I reset the whole TV?
press channel+ and volume- on the tv (not the remote controller) than you go into factory mode. You can reset certain things there.
Jun 27, 2009 | Acer AL2671W 26 in. LCD Television
At power up tv displays Acer logo then goes to black
will not turn off power with out unplugin it
Mar 01, 2009 | Televison & Video
Totally dead. Vizio GV42L
If the circuit breaker was tripped, more likely the fuse inside the TV power supply might also be blown. If that is the case there might be a short circuit in the power supply components, more likely on a diode or transistor/mosfet.
Contact these website to see if they have the parts for your plasma.
Good Luck.
Dec 03, 2008 | Vizio GV42L 42 in. LCD Television
Acer AT3201W LCD TV
I repaired my Acer by replacing the power supply from
http://www.power-on.com/lcd323-4m.html - $85
Acer would not sell me a replacement power supply.
Note: I needed to solder wires the new power supply to the old one,
the pinouts on the connectors on the new one would not fit the original.
Sep 08, 2008 | Acer AL2671W 26 in. LCD Television
Acer AT3705W-MGW 37 in. LCD Television Logo
376 people viewed this question
Top Acer Televison & Video Experts
Gareth Cockram
Gareth Cockram
Rommel Balcita
Martin Murray
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
