Question about MPC Computers (9052701) PC Desktop
How to change hard drive - MPC Computers (9052701) PC Desktop
  • MPC Computers Master
  • 5,660 Answers
With an MPC computer?
To avoid all the hassle, and possibility that Restoration Disk/s are not available, I would suggest you insert your new harddrive into an external enclosure.
The external enclosure has a USB cable, that you just plug into any available, unused USB port on your computer.
Desktop harddrives are approximately 3 and 1/2 inches, across in width. (3.5)
If this problem is in direct reference to an MPC desktop computer, with the MPN of 9052701, (Model Product Number), the harddrive used is an IDE style of harddrive.
IDE is also referred to as PATA.
This is an example of an IDE (PATA) 3.5 external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1337265&CatId=2779
This way your Operating System is still on the 80GB harddrive in your computer, and the new harddrive is used for storage.
(Windows XP is one example of an O/S. Operating System)
Posted on Jul 03, 2010
  • 305 Answers
Change your hard drive by replacing another hard drive with ide a belt type one end to the mother board and other end to the harddrive..... then another wire that comes from your smps box in your cabinet with red blue green colours connect it to your hard drive thats it..
if your harddrive is sata then do the same in the sata
Iintend to change my sata hard drive to a SSD hard drive.How do I format before change
When you install Windows on your new SSD hard drive you can then transfer data from your old hard drive using an USB hard drive adapter or install the old hard drive into an USB hard drive adapter case and use it as an USB external hard drive after you have transferred your data to your laptop.
When you connect the USB hard drive adapter to the laptop, the laptop will see it as an external storage device, you can then open the various folders anf files and copy them to your new hard disk.
Apr 07, 2012 | Dell Computers & Internet
I have a Dell Demension 3000... I have a hard drive in it that has XP as the OS... I am trying to install a second hard drive as a slave and I want to install Windows 7 on that hard drive. I wiped the 2nd...
yes it will show device is working properly
did you change jumper setting of your hard drive if not see the label top of you hard drive and change jumper to slave
Sep 11, 2010 | Maxtor Hard Drive
Change a hard drive
As a general rule, SATA drive like the DiamondMax Plus 9 160 GB Hard Drive can be made either master or slave by just plugging the drive cable to the appropriate alternative SATA port on the motherboard without changing anything on the drive. MAKE SURE YOU UNPLUG THE PC FROM THE MAIN POWER FIRST! Most motherboard will have two such ports on the motherboard in close proximity to each other (just follow the 'flat' usually red or yellow cable from the SATA drive towards the motherboard to locate the ports). Hope it helps.
Dec 21, 2009 | Maxtor DiamondMax Plus 9 160 GB Hard Drive
Trouble getting my computer to recognize my simpletech hard drive
Try Control Panel, Administrative Tools, Computer Management, Storage, Disk Management.
Check there to see if the drive is listed, "online" and has a "Healthy" Partition.
RightClick on Volume (C:>) for Change drive letter and path.
Dec 16, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Computer cannot recognise the hard drive ;
inside there is a usb and data port attache in hard drive. some time thise port may be damage and also usb cable which we connect on computer may be damage. we came to know after changing two thing ,change one by one to check,
Sep 30, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
External Hard Drive Not Regonized
I can help you with this. Follow these instructions--> Start-->Control Panel-->Administrative Tools-->Computer Management, under the Storage section select "Disk management". Locate the external harddrive, and then change the drive letter.
Select the external drive. Right click, and select "Change drive letters and paths"-->Highlight the driveletter to change-->Click the "Change" button-->From the drop-down list choose an unused drive letter, and hit Ok.
The external drive should be recognized and accessible at this point. Let me know if you have any other questions.
Thank You, Raph30
Jan 28, 2009 | Western Digital 250GB MyBook External USB...
Laptop unable to read hard drive in bios
Open your screw case of your hard drive under body your laptop , release or remove your hard drive, try change with normal hard drive, check if work your 1 st hard drive is broken , you must change with new one.
Sep 26, 2008 | Computers & Internet
PLEASE HELP
Goto>
Control Panel> Performance and maintenance> Administartive Tools>Computer Management>Disk Management> Select The drive And Right Click after that select the Option {Change Drive Letter and Paths} \
here you can change drive letter and Path. If you need more help Kindly update the Request.
Mar 09, 2008 | Western Digital MyBook Pro WDG1T5000 500...
MPC Computers (9052701) PC Desktop Logo
99 people viewed this question
Top MPC Computers Computers & Internet Experts
Lee Durbin
Lee Durbin
Josh Levin
Josh Levin
orangeupstag
Level 1 Expert
Are you a MPC Computers Computer and Internet Expert? Answer questions, earn points and help others
