Question about HP Photosmart C6280 Printer
My printer says insert memory card - HP Photosmart C6280 Printer
    President:
  • 1,070 Answers
Welcome to FixYa...
I assume the message is not an error message and does not indicate an issue with the product. The message is designed to be an invitation to print photos from a memory card. Follow these steps to insert a memory card into the product.
  1. Locate the memory card slot on the front of the product that is compatible with the memory card to be printed from. Each type of memory card slot accepts only one type of memory card, and only one memory card can be inserted at a time.
  2. Insert the memory card into the appropriate memory card slot.
Some times you may be trying to print Some Data may be from Memory card , you Choose already-But actually your MMC not in/Not Properly in...Hope you find it.....Thanks for Contacting FixYa...
Posted on Jul 03, 2010
3 Suggested Answers
SOURCE: printer formating the printer
how do i open the printer to change my cartridge?
Posted on Jan 26, 2008
MLFnet
  • 328 Answers
SOURCE: i have a hp psc 2355 printer everytime i insert
Is it the same memory card each time? If so, try with a different memory card.
If it's with all the different cards, verify that there is nothing wrong with the connector that the memory card touches.
-=/ Daft Tech /=-
Posted on Oct 25, 2009
After inserting memory card in printer, how can you view pictureson your computer?
With the printer turned on and connected to the computer, once you insert the memory card, it should show up as a removable drive in Windows Explorer. Click Start and then Computer. This should show you a dialog displaying the drives accessible to the computer The memory card should be in this list.
Jan 12, 2014 | Brother MFC795CW AllInOne InkJet Printer
Printer will not recognise camera memory card hp p315 photo printer
Was your Lexmark P315 printer able to detect this particular memory card before? Try to re-insert the card - it could be due to a slight communication problem. Have you tried inserting a different known working compatible memory card into the printer's card slot? This could be due to faulty memory card.
Also, please refer to Memory Cards Supported by the Lexmark P315 Photo Jetprinter.
Jul 26, 2011 | Lexmark P315 Photo Printer with 2.5" LCD...
HP Printer C6280. It has power, when powered up, the LCD flashes the HP logo then goes blank. Not initializing the scanner or cartridges.
Have you inserted a memory card? The LCD menu may not activate until a memory card is inserted. If a memory card has been inserted the printer may have goe into sleep mode while reading the card information.
See here for information on compatible memory cards and memory card issues:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00059994&cc=us&lc=en&dlc=en&product=3194498&tmp_track_link=ot_search#N1954
Dec 18, 2010 | Office Equipment & Supplies
What is insert card
This printer can print photos that are stored on a flash memory card.
Insert card means to insert the flash memory card into the printer so you can select the photos you want to print.
Apr 01, 2010 | HP Photosmart C6280 Printer
Do I need an adapter?
The printer has its own slot for a memory card.
Turn your CAMERA off.
Remove the memory-card.
Turn your PRINTER off.
Insert the memory-card into the printer.
Turn your PRINTER on, and it should recognize the memory-card.
Dec 28, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
Have a HP 2175 all in one. in the front how do I insert the camara memory card ? or is this possible?
You can only insert a memory card if it is made to be inserted in that printer.
If yours works like mine, you must remove a blank "slug" before you can insert a memory card. The slug is shaped exactly like the memory card. And more that that, when you remove the slug, you must look at the slug to see how it is orientated. In that way, you can tell how to insert the real memory card.
Most of them have a corner missing, as if it had been removed, or cut off. If you then line up the memory card to match the way the slug came out of the printer, you can then put the memory card into the printer the way it is supposed to go and that way, it will be "read" by the printer.
I hope this helps.
-a.
This URL will take you to a page on HP's site, dedicated to the memory card:
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=2527&tmp_task=useCategory&lc=en&dlc=en&cc=us&product=90809&lang=en
Dec 05, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I have a hp psc 2355 printer everytime i insert
I had the same problem with my HP L7590 All In One. After trying a number of things to reset nothing worked. Then I tried this just as a last resort and it worked.
Insert the/a memory card( it will tell you that you can only use one card at a time).
With the card still in turn off the printer using the power button.
Wait for 30 seconds then turn power on again.
The screen should say reading card. So wait for it to finish reading and all should be fixed.
If this does not work, try again using a different card.
good luck
Send me Kudos if it works.
Oct 25, 2009 | HP PSC 2410 All-In-One InkJet Printer
How do you transfer photos from memory card inserted in HP C5280 printer to my computer?
You cannot read that memory card inserted in HP printer to your Computer because that HP Card Reader port is only for direct access printing from memory card.
All you have to do is use a Multi-memory card reader into the PC where connected to USB port.
I'm sure 100 works!
Oct 09, 2009 | HP Photosmart C5280 InkJet Printer
How to use the memory card reader
To access the memory card reader without using the software provided, follow the steps below. If no card is inserted, the green light on the card reader will be on.
Insert a memory card.
• Insert the card with the brand name label facing up.
• If there is an arrow on the card, make sure it points toward the printer.
• If needed, make sure you connect the memory card to the adapter that came with it before inserting it into
the slot.
Wait for the light located to the right of the slots on the printer to come on. The light blinks to indicate the memory
card is being read or is transmitting data.
• The printer recognizes one memory card at a time. If you insert more than one memory card, a message appears
on the display prompting you to remove all memory cards inserted.
• If a USB flash drive is inserted together with the memory card, a message appears on the display prompting you
to choose which memory device to use.
When reading of images is complete, the number of photos found appears on the display. Then you can make your selection and print. these are the types of memory card supported by you printer.
xD-Picture Card
• Secure Digital (SD)
• Secure Digital High Capacity (SDHC)
• Mini Secure Digital (with adapter)
• Micro Secure Digital (with adapter)
• MultiMedia Card (MMC)
• Reduced Size MultiMedia Card (with adapter)
• MultiMedia Card mobile (with adapter)
• Memory Stick (MS)
• Memory Stick PRO
• Memory Stick Duo (with adapter) or Memory Stick Duo PRO (with adapter)
Mar 18, 2009 | Lexmark X5495 All-in-One &USB...
Memory card issue with Epson r300
Hi , reinstall the printer driver with sd inserted.
Jan 25, 2008 | Epson Stylus Photo R300 InkJet Printer
HP Photosmart C6280 Printer Logo
931 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
