Xerox 5837 .. I have no fault code displaying but paper keeps stopping at the fuser, the copier stops and says open and remove paper.
    President:
  • 567 Answers
Hi please make sure no paper is stick up inside the printer, then uninstall the drivers and reinstall them again. Please let me know if this solve the problem.
Posted on Jul 03, 2010
  • DonnieRoach Jul 03, 2010
    this is a very large copier not a printer so as far as I know there are no drivers.
  • Hilton Bristol Jul 03, 2010
    Hi thanks for replying,you copier seem to have a software problem please go to http://www.support.xerox.com/go/prodsele... you will see three steps to follow.First step is to select your product type,the second step is to select the product family and then select your model of copier and download and install the drivers for it. That is the manufacturer support website which provide download and support for all xerox products.
    Thank you for asking
Fault code 010-110 for 3535 xerox
The fuser exit switch sees something in the fuser. The exit switch is stuck . there is actually a piece of paper in the fuser.
Or the switch fell out of the slot.
You can just losten the two thumb screws on the fuser , remove the fuser and check it out.
Oct 06, 2010 | Xerox WorkCentre M-24 Color Copier
We have XC865 the copier was working just fine until today. The paper keeps jamming inside. It would start to copy and then just gets stuck in the middle of the cycle. So I have to open the machine up...
Most likely a common problem of a broken fuser drive gear. This is especially true if the lead edge of the paper is stopping at the fuser assembly. This is the assembly that is hot to the touch. There is a upper fuser roller drive gear that breaks on these and causes the fuser roller to stop turning. So everytime the paper gets to the rollers it stops and a jam reults. The gear is 16.00 at precisionroller.com part number M510X
Here is a picture of the gear.
Sep 17, 2010 | Xerox Office Equipment & Supplies
FAULT CODE 124-373 ON WORKCENTER 5225 WILL NOT CLEAR
Xerox 5225 keeps showing error 124-373 and cant one to enter into set-up or status mode.How to correct this error?.I have jobs to copy for urgent meeting soon.your email is needed
Aug 28, 2010 | Xerox Workcentre 5225 / Copier, With...
Xerox 5837 Fault Code 06-305 I can't find this code anywhere and all it says when I push the i (info) button is "Call Service Technician" .. which would be ok, but we are 50+ miles from the nearest...
Hi Donnie,
The code 06-305 for Xerox 5837 means "Exposure Carriage Registration Sensor" fault.
You can download the document which explain the codes from this link which I uploaded for you.
Hope this helps.
Kind Regards.
Jul 02, 2010 | Office Equipment & Supplies
XEROX WORKCENTRE 5222/5225/5230 A FAULT OR ERROR FAULT CODE 010-327
010-150, 155 Too much or not enough paper in duplex tray 10-300 Fuser thermistor 10-302 Low fuser temperature 010-304 Bad fuser temp 10-308 High fuser temperature or open thermistor 010-310 High fuser temperature 010-312 Fuser not up to temperature after energy save 010-314 Fuser problem 010-320 Fuser web finished 010-330,327 335, 340 Exit switch, vertical sensor switch actuated when power is turned on
Sep 03, 2009 | Office Equipment & Supplies
Xerox Regal 5790 Paper Jam
Wat is the code about this problem 08-300 its maine the Füser is not start on the same time when the cluts is not werking oder the pall is not gooing to this point open the front dore an you cann sche small cluts this is no good contact of its not working then you can puss the small wiel to the bik rol en the paper wil to the füser turn the green wiel and the paper go to füser out. I had this problem also with Xerox 5760 the same .
Apr 10, 2009 | Xerox Office Equipment & Supplies
Xerox 8560 37X Fault code
either the paper pulling gears are not spinning properly or they are craked or getting blocked by any dust particles.
or the fuser unit in the copier is not getting properly heated up.fuser unit has to be checked first before replacing and the printer /copier needs to be opened to check the fuser unit.
Feb 26, 2009 | Xerox Phaser 850DP Thermal Printer
Xerox Phaser 5500 printer...paper stops halfway thru fuser unit.
Are the paper tray settings correct? If you have the tray mis adjusted, such as the tray thinks it has 14 inch paper in it and it has 11 inch, it will just shut down like that.
Make sure the settings are correct on the computer and the printer.
Also, its unlikely but the latch for the load springs in the fuser may be unlatched, but you shold NOT be able to close the covers like that.
Jan 06, 2009 | Xerox 5500/DT Laser Printer
Xerox 5837 with 08-310 Error
If you donot find paper in the machine check for a stuck actuator or a bad sensor.
Jun 03, 2008 | Xerox 5830 Copier
Xerox Doc12 10-386 error code
That is a fuser overheat. Make sure that the paper path module is securely locked into place.
Look for a piece of paper wrapted in the fuser.
Or replace the fuser itself.
Apr 11, 2008 | Xerox DocuColor 12 Color Copier
jasbo
jasbo
