Question about Kitchen Ranges
Oven range does not work (broiler and oven)or heat up. Upper burners are working. Whirpool Model # RF 3663XDWO Serial # FF 4705148 Fault code Lights as F3
  • josephrajara Apr 19, 2008
    Jim 147,
    We just opened the back cover and moved and after shaking the wires and unit started working as before. There was a loose contact as you described. I was trying to do the same but I was not sure until I got your message. Thank for the advice. It worked.
    Joe.
  • 145 Answers
F3 on that model should be a sensor problem. It's the metal probe coming in from the back top inside the oven. Check for a loose wire first between sensor and oven control. Be sure to unplug unit before taking back off to check for wires.
Posted on Apr 17, 2008
Whirlpool Gold Series stove. When turning on the oven to pre-heat, the broiler came on and we got a fault saying FAULT - PRESS ENTER TO RETRY.
Appears the burner is faulty, check connection at burner receptical first then check with meter for opens. Here is the Whirlpool link for parts repair manual etc. https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.whirlpool.com/services/replacement-parts.html&ved=0ahUKEwiCvdH97rDTAhVk7IMKHX4gAtMQFghZMAA&usg=AFQjCNEsdfUwvP3qyVcDj7qJikAtiHTfUQ
Apr 18, 2017 | Whirlpool Kitchen Ranges
I have a GE Profile XL 44 gas range, Model #JGBP79BEA2BB, Serial #RV224810P. The Broiler works, the oven does not. I am fairly certain the problem is the round style oven Igniter. I am trying to verif
What have you got to lose , 25.00-65.00 I would see if the ignitor works . Have someone else turn it on while you watch underneath if it sparks the try to get it closer to burner .
Jan 20, 2015 | GE Kitchen Ranges
Oven does not work: pilot light out? How feasible (how dangerous) to try to relight pilot light? T Phillips Winston-Salem, NC
Actually, your oven probably doesn't have a pilot light at all. In order to ignite the oven, it has an oven igniter. If you open the broiler, look up on the "ceiling" of the broiler to the back of the burner. There, you'll see a white block. That is the igniter. What it's supposed to do is heat up (electrically) and when it heats up enough, the gas valve turns on and the oven lights. What happens with these, is that the heating element on it opens from years of use and must be replaced. Inside the broiler door (usually) is the stove's model and serial numbers. Write them down and visit your local appliance parts store with those numbers and they'll give you a new one. (Usually around $30-$45 or so.) Also, you can usually change the igniter from inside the oven by removing the bottom drip plate, so that'll save your back a lot of straining. :)
I hope this helps and hope you have a wonderful holiday season!
-Jason
Dec 22, 2010 | Whirlpool GS460 Gas Kitchen Range
Why does the surface burners and broiler light but not the oven burner on my Kenmore gas range? Kenmore gas range around 14 years old the model number is 362.7352192. We were using the oven and in the...
The oven gas valve coil has failed Need to replace. Go to repairclinic.com and put in the model and order the coil for the valve. It controls the gas valve.
Sep 11, 2009 | Kitchen Ranges
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven won't light or self cleaning but broil works
sounds like the spark module to me. you need to find the model # for this one. if you have the electrical schematic, you can ohm out the spark module.
the model & serial #'s should be under the door frame, when you pull out the bottom drawer.
Sep 13, 2008 | Whirlpool Kitchen Ranges
Oven, broiler don't work
The main control board is what you need to replace here.Please Rate This !
Jul 06, 2008 | Kenmore Kitchen Ranges
Kitchen Ranges Logo
162 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
