Question about Innovage Speaker/Caller ID* LCD Touch Panel Phone with 12-Digit Calculator
No response on screen
I put new batteries and the screen doesn't lite up and the touch keys does not do anything. Please help Lazar
  • stardust0131 Oct 06, 2008
    I have the same phone with no manual. I put fresh batteries in and nothing. The screen doesn't show a thing and I don't know how to program it. All it does is ring and shows nothing on the screen. Please send me something to
    Thank you.
  • meanmama Oct 27, 2008
    You cannot program the phone or none of the buttons to the right of the number pad will work. Is there a part I can order to repair this problem.
  • 32 Answers
Sent you an email of the manaul i have, hope it helps ya out.
Posted on Aug 12, 2008
Screen doesn't work
Try turning the phone off and remove the battery. Wait about 30 seconds or so and put the battery back in and turn it on. This is one way to reset phones or devices with removable batteries.
Sep 18, 2012 | T-Mobile HTC MyTouch 3G Slide...
DS Lite Bottom Screen and Touch Screen Replacement.
Has your bottom screen developed a fault or stopped working? Has your touch screen become less responsive or stopped working altogether or just has a few too many scratches?
To replace the bottom and/or touch screen you will need a precision "+" cross-head screwdriver and a precision tri-wing screwdriver which can both be purchased on ebay for a reasonable fee. The respective screens can also be purchased on ebay for a reasonable fee.
Firstly you will need to remove the battery cover and battery, unscrew the cover with the cross-head screwdriver, leaver it off either with a thin blade or similar, and take out the battery. Next you need to remove the remaining 3 cross-head screws, 1- top right corner of the battery compartment, 2 & 3- underneath the rubber feet along the hindge (note that screws 2 & 3 are of a gold colour).
Now you will need to remove the 4 tri-wing screws which are located 1- top left of the main body, 2- bottom left of the main body, 3- bottom right corner in the battery compartment and 4- in the top centre of the "slot- 1" hole (note this is a small black tri-wing screw).
You can now remove the back of the DS lite, be careul as there are springs and rods located on both trigger/shoulder buttons which can easily get lost (if you do somehow manage to lose them they can be replaced with another trip to ebay). Remove bother the trigger/shoulder buttons along with the rods and springs, if you can keep them together as a unit so that they can be easily fitted back on without having to fiddle about aligning the spring, shoulder button holes and rods.
Next you need to remove the 2 cross-head screws holding the main board into place, these are a different size to the others so try keep them seperate. Now you need to disconnect the top screens ribbon from the board by lifting the flap of the connector and then gently pulling the ribbon free, gently pop of the mic cable (white cable) and the wi-fi cable (lack cable) and slide out the wif-fi one so that the motherboard is free from the rest of the DS lite.
Just above where the w-fi cable was connected to the motherboard you will see a very small connector and ribbon, this is for the touch screen, carefully lift the flap and remove the ribbon, if its the touch screen thats the problem try re-connecting it and then giving it a power up to test it, if it doesn't make a difference then a replacement is needed. Flip the motherboard over and you will see where the bottom screens ribbon is attatched, as before you need to lift the flap and remove it, if you want to test a re-connection then give it a go, if it doesn't work then a replacement will be needed.
I have found that when trying to seperate the touch screen fron the LCD screen the touch screen becomes collateral damage as the force of pulling them apart tends to be too much for it so chances are you will end up replacing it (though you never know you might be lucky). So anyway, whatever screen you are replacing you need to seperate them and dispose of the faluty one,replacing it with the new one and either use thin strips of double sided tape to re-attach them (take note of the original screens position to perfectly mimic it) or just place them one on top of the other, as the shell casing should hold them into place.
You will find that there is a frame of your respective DS lite colour stuck to the touch screen, if you are replacing the touch screen you will need to remove this and stick it on to the new screen after the DS lite has been fully put back together, the reason for this is that it takes out the difficulty of trying to correctly place the frame in the exact original position.
Now all you need to do is the reversal of the taking apart process and you are all sorted.
If you now find that you DS lite does not power on or has the green light flash when powered on please see my other tips and trick I have posted on here.
I hope this helps and have to say that I accept no responsability forany damage that may occur to your DS lite when following these tips.
on Feb 08, 2010 | Nintendo DS Lite
Samsung tocco lite touch screen..
this is a factory fault that cannot be rectified, from time to time the phone will freeze and after a while will function normally as if nothing ever happened. leave the phone alone dont fiddle with it until it resumes normal function
Jul 13, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Each time you charge your battery, the charge capacity is decreased. After a large amount of charges, the capacity is decreased to an amount only enough to turn on a/the screen(s) for a second. Try getting a new battery.
Mar 02, 2009 | Nintendo DS Console
My nintendo ds lite the touch screen does not work
if your touch screen is non responsive I can replace it. I have new touchscreens in stock for $24.
Dec 07, 2008 | Nintendo DS Lite Console
Ds lite touch screen
Try taking the battery out then putting it back in, if that doesnt work i have no idea.
Feb 13, 2008 | Nintendo DS Lite Console
Top Screen Replacement of DS Lite
there is a video tutorial at
which tells you how to disassemble the ds lite
Dec 04, 2007 | Nintendo DS Lite Console
Innovage Speaker/Caller ID* LCD Touch Panel Phone with 12-Digit Calculator Logo
54 people viewed this question
Top Innovage Lands Phones Experts
Computer Repairing
Computer Repairing
Are you an Innovage Lands Phone Expert? Answer questions, earn points and help others
