Can't pick up all the signals
I've had this TV a few months and it has worked fine. I had it hooked up to a Terk bow tie antenna and picked up about 20 digital signals in addition to analog signals. I decided to hook up the Viewsonic to the roof mount antenna that our other TV uses. My husband used a splitter thing and we hooked up the Viewsonic to the roof top antenna. I ran "auto scan" and picked up the same channels as before except now some of the channels had different numbers, like channel 10 was found way over on channel 37. Then yesterday, suddenly I can only get a few channels. I ran the "auto scan" again. I hooked up the old Terk antenna..."auto scan" again. Nothing helped. I called Viewsonic, they had me do the same things I had already done. We reset the TV to factory defaults. Still no good.
Can you help? I did find out there are no "Factory Authorized" repair locations and my only option is to pay for repair myself or send it back to Viewsonic.
  • Anonymous Mar 15, 2014
    element television
    Genius:
  • Televison & ... Master
  • 1,689 Answers
I always tell people to carefuly read their instruction manual and consult the product tech support before determing that there is actualy a fault with their unit.
If sounds like the tuner module or the controler board for the tuner may be failing, or there is a power supply distribution fault to the tuner section and or its controler. This has to be service by the manufacture.
One of the criteria I recommend when people buy an expensive appliance or TV is to make sure that there is local authorized service. I also recommend an extended warrany for expensive items. The warranty is like insurance. You may or may not need to collect!
Jerry G.
Posted on Apr 17, 2008
How do we set up the tv to pick up air channels with the indoor amplified antenna?
Terk FDTV2A HDTV Indoor Antenna Unboxing Setup Test Part 1
double check your TV is set to the correct input before scanning.
the link above shows installation
press the helpful button
Jan 22, 2016 | Sharp LC52E77UN 52 in TV
I just hooked an antenna to my sony bravia and it only picks up a few digital channels. I have two other Tvs hooked to the same antenna and the both pick up so many more channels. What could be the pr
i think the 'front end fet' or channel fet has failed
this amplifies the incomming antenna signal
however is the center pin of the antenna plug on the tv loose
inside the tv is a metal box this is attached too
it changed the UHF signals to a lower frequency range called an IF
the UHF signals are normaly have a path like this
antenna>>safety >>>amp>>mixeramp>>output to DTV decoder etc
the amp bit or connection to the tv is wrong
as its working quite well and gets like 2 channels
look inside the socket on the tv and examine it carefully for any bits of wire
or as i say loose connections
may just need to be soldered inside the can to reconnect the center pin
it will still give like 2 3 channels as the gap caused by the bad solder joint
will still allow some RF accross
so... its either a gubbed UHF RF amp or a broken connection or a short ... so...
Dec 11, 2014 | Sony Televison & Video
My rca indoor antenna will not pick any channels up on my hd flat screen tv
Signal not strong enough in your area for this indoor ant...Does it work with an outdoor ant?
Nov 29, 2013 | Televison & Video
I have a problem with varying reception issues on my digital tv. some shows have full pixelation and freezes, but other programs are fine. I read on a forum that this could be a problem with ''program...
You can try a different antenna or a signal booster.Or use more than one antenna for picking up signals from different directions and use a diplexer to combie the signal into one.I have a Terk HDTVo and it will pick up stations from 40+ miles away when it is clear,but is choppy during storms.There will be under menu or tools on your remote a diagnostics option that will show signal strength on the chanel you are watching. Well hope this helps.
Feb 24, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Indoor antenna problem with Magnavox LCD TV Model 15MF605T/17
I have found most of these indoor antennae to be ineffective and a waste of money, however, I do not know anything about this particular antennae. I to have a Dish DTVpal, which I love! It's ugly and probably won't fit in your kitchen, but the best solution is to make your own "bow-tie" antennae, mount it indoors or on the roof and run a cable to the kitchen. Directions can be found on You-Tube. I live in SE Idaho (Pocatello) and can get 13 channels, most without having to adjust the antennae.
May 27, 2009 | Philips Televison & Video
Sanyo TV, older model, tv converter box, terk antenna, will not p
DP models are already digital there is no need of a converter box. connect a outdoor antenna to the tv directly.
Mar 04, 2009 | Sanyo DP32746 32 in. LCD Television
Weak or no signal
you would need to know if the tuner is picking up analog signals in the air well( stick a wire a little bit in the tuner connection to see if channels pick up good or use an antenna , if so there should not be a problem with the cable being hooked up to it , if there is a problem even with an antenna then the tuner is bad and will need to be replaced , and the cable could have caused it to go out , but make sure that the tuner is working or not first.
Nov 27, 2008 | Televison & Video
I`ve set up my philips digital terrestrial receiver DTR220 and i`ve scanned for all channels, but i can`t pick up any because my aerial is not picking up any signal. I`ve tried different, stronger aerials...
I actually moved my tele to the other side of the room to see if it would work in a different spot and it took me ages to get some signal by moving my aerial around. The signal still wasn`t strong and i didn`t have alot of the channels and then i turned it on a few weeks after and it was working perfectly. Don`t ask me why! :s
Jul 21, 2008 | Audio Players & Recorders
Televison & Video Logo
236 people viewed this question
Top Televison & Video Experts
