Question about BYTECC 1 Bay ME-350U2 USB 2.0 External Drive Case
Was not able to access files from Smartdrive Exterior Hdd. Now computer does not even bring it up in My Computer. WinXP Pro
  • 76 Answers
Change the USB cable
Posted on Jul 03, 2010
I have a seagate barracuda 7200 7 40GB, with 2 partitions: 1-(c:/)WindowsXP, 2-(d:/)for save my personal files.At PC startup, the message that appears is missing OS. BIOS detected HDD, but Windows CD no,...
you can take backup of D drive om other computer .
Conect your harddrive to that other computers CPU but make sure that your hardddisk is slave which has issue you can set slave your hdd with jumper read on harddisk.
then connect it to cpu with SATA or IDE .
Then winxp find that all partition then take backup.
AND IFyou haven't other computer you need winxp bootable disk.
Boot your computer with winxp disk then follow the procedurer then you see on screen
your old winxp for repair then when it ask for "r"
Presss "R"
thats it.
Thwen it repair your winxp then you can use easily.
Aug 22, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
Seagate 750GB usb HDD asks to format,when opening by double click
The disk is either damaged or the USB interface is damaged.
1) You could try opening the external case and connect the disk to your computer directly (Using IDE/S-ATA cables)
2) Format the HD and use data recovery software/service.
May 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
USB HDD not showing in My Computer
It could be that the USB port on that computer is not delivering enough power.  Will your Drive accept external power?
May 12, 2009 | Computers & Internet
Unable to access my documents after reload winxp
Just about anytime you do an install and not burn the data to disc, that happen. Not always but most often.
That data is lost as far as I know. I did same thing and lost 200 movies.
I now burn everything to disc.
Sorry about the news....
Feb 23, 2009 | Computers & Internet
Recovering My Dcuments from failed system
You have to take ownership of those folders. Right click on the folder and open the Security tab
Dec 25, 2008 | Microsoft Windows XP Professional
No Allocated letter on HDD
hello,
i think you lost the mbr of old hdd. Or you have a virus problem on your pc. firstly you boot the pc with new hdd and then scan the whole drive by an updated antivirus and then boot prom old hdd. if it is not solve your problem then rebuild the mbr by any software which are avalable on net.
i think it can solve your problem.
ramesh
Nov 29, 2008 | Western Digital 250GB MyBook External USB...
Parallels Desktop
Hi toy4runner,
Did you check the permissions of the folders that need to be openend by parallels to get to the file? (just select the folders one by one and for ech of them press apple - I and check the permissions section of the information pane. Chnaces are Parallels is trying to access a folder but doesn't have the right permission.
If all seems okay, check this:
http://kb.parallels.com/en/4680
Hope it helps
Apr 27, 2008 | Apple MacBook Pro Laptop Computer with...
Hard Drive Partition Table Error
If you have a spare HDD, you could install win xP onto that and set the problem drive as a slave. You may then be able to access the slave drive and save some of your files.
Apr 27, 2008 | Seagate Barracuda 7200.8 300 GB Hard Drive
Satelite l200 bios problem
If your computer is running a sata HDD, then you may need to install the drivers for the sata controller at the beginning of setup so that your HDD can be found.
F3 is the key used to quit setup, so XP has not found any hard drives.
The other thing to check is in the bios when the computer first boots to see if the hard drive is even being detected by the computer.
If not, then check it has the power and data cables attached.
If the drives are IDE and you have 2 on the same cable,then make sure to set them to master and slave, or both to cable select so they can be found correctly.
Hope that helps =)
Apr 09, 2008 | Computers & Internet
Recovering files from a bad drive using external hdd enclosureh
Hi, I usually use GetDataBack (2 versions FAT and NTFS). I have used this program to recover files from HDs similarly connected (external case > USB). The freeware versions will allow you only a limited number of files at a time, the paid version will allow you to recover all (including purposely deleted files). There are similar programs/freeware but my experience with GetDataBack has been super so far that I really have no reason to look for another one. Pls refer to the 2nd image on this link where GTB was recovering files from an HD that is not even recognized by Windows XP in "My Computer". http://www.fixya.com/support/t191153-device_recognized Hope this be of some help/idea. Post back how things are or should you need further information. Good luck and kind regards.
Sep 11, 2007 | Fujitsu Desktop MPG3204AH 20.4 GB Hard...
BYTECC 1 Bay ME-350U2 USB 2.0 External Drive Case Logo
133 people viewed this question
Top BYTECC Computers & Internet Experts
Stan Skaggs
Stan Skaggs
Raymond Lidington
Level 1 Expert
indiana650
indiana650
Level 1 Expert
Are you a BYTECC Computer and Internet Expert? Answer questions, earn points and help others
