Question about Easton 2009 Ea90 Slx Road Wheelset Campy Hub Clincher
How do I adjust the bearings in the rear wheel??
  • 29 Answers
This can usually be done with a bit of care. You will need two flat spanners that fit the lock nut and cone nut. Loosen the lock nut on the off side (not the gear side). Loosen the cone nut. Squeeze in some greese. Tighten the lock nut so that you feel NO movement in the axel at all. Do not overtighten. Tighten the lock nut while holding the cone nut with another spanner. Try the wheel on the bike. It should spin feely but have NO sideways movement at all. You may have to go through this process a number of times.
Posted on Mar 29, 2013
1999 mercury cougar v6 when jacked up on rear whole tire wiggled back and forth
Bad wheel bearing. I do believe yours are pressed in. You can remove the spindle and take it to a shop and have them replace the bearing.
Jan 01, 2017 | Mercury Cars & Trucks
How do you replace the rear wheel hub on a 2003 Kia sedona. All I can find is directions on front not back.
Wheel Bearings
Print
Adjustment
2002-05 Models
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Remove or disconnect the following:
    Rear wheel Brake drum Hub cover Cotter pin Lock nut cover
  3. Adjust the locknut to achieve wheel bearing play of 0.001-0.006 inches (0.025-0.152 mm).
Removal & Installation
2002-05 Models
    Rear wheel Brake drum Hub cap Cotter pin Lock nut cover Lock nut Wheel bearing retainer washer and the outer wheel bearing Hub assembly Grease seal Inner wheel bearing
  3. Clean and inspect the wheel bearings and races for unusual wear or damage. Replace parts as necessary.
To install:
  1. Pack the wheel bearings with grease for assembly.
  2. Install or connect the following:
    Inner wheel bearing Grease seal Hub assembly Lock nut. Adjust the locknut to achieve wheel bearing play of 0.001-0.006 inches (0.025-0.152 mm). Lock nut cover Cotter pin Hub cap Brake drum Rear wheel
Apr 03, 2015 | 2003 Kia Sedona
How do you adjust the rear wheel bearing?
Rear wheel bearings on front wheel drive vans are much like front wheel bearings before front wheel drive.
You have an inner and outer bearing with a nut and lock washer.
After the bearings are packed with grease, you tighten down the axle nut until snug then back it off a notch. Then put the lock washer or lock ring on. Some have a cotter pin to hold the nut in place.
The wheel should spin with no drag from the bearings.
Jul 07, 2012 | 1993 Plymouth Voyager
How do I get the rear spindle off so I can replace the emergency brake shoes on my 2006 chrysler pacifica?
Adjustment
  1. Place parking brake lever in -full released- position.
  2. Raise and support vehicle.
  3. Remove plug in parking brake shoe support to access adjuster star-wheel.
  4. Through the access hole, rotate the adjuster star wheel in the following direction to expand the shoes outward against the drum:
    1. Left brake - Rotate star-wheel toward rear of vehicle.
    2. Right brake - Rotate star-wheel toward front of vehicle.
  5. Using an appropriate tool, turn adjuster star wheel until wheel will not rotate (dead lock).
  6. Back off adjuster six detents (teeth).
  7. Rotate wheel, checking for light drag. If drag is too heavy, continue to back off adjuster one detent at a time until light drag is present. Do not back off star-wheel more than 17 detents from wheel lock.
  8. Install access plug.
  9. Adjust opposite wheel parking brake shoes using same method.
  10. Lower vehicle.
  11. Apply and release parking brake lever once to ensure proper operation of parking brakes.
Removal & Installation NOTE The following procedure may be used to remove shoes on either side of the vehicle.
  1. Lock out automatic adjuster in parking brake lever.
  3. Access and remove rear hub and bearing.
  4. Remove parking brake cable bolt at knuckle.
  5. Completely back off parking brake shoe adjustment.
  6. Remove parking brake shoe adjuster spring.
  7. Remove shoe adjuster.
  8. Remove upper brake shoe hold-down clip and pin.
  9. Remove lower brake shoe hold-down clip and pin.
  10. Remove upper and lower shoes with return spring from shoe actuator.
  11. Remove return spring from shoes.
    Fig. View of the actuator (1), support (2), adjuster spring (3), return spring (4), caliper adapter (5), shoes (6), hold-down clips and pins (7) and adjuster (8)
To install:
  1. Install return spring between upper and lower shoes.
    NOTE Before installing shoes on actuator, make sure actuator hooked to rear cable is positioned with word -UP- facing outward.
  2. Install upper and lower shoes with return spring on shoe actuator located on parking brake cable.
  3. Install lower brake shoe hold-down pin through rear of support and lower shoe, then install hold-down clip.
  4. Install upper brake shoe hold-down pin through rear of support and upper shoe, then install hold-down clip.
  5. Install shoe adjuster. Place end of adjuster with star wheel upward.
  6. Install parking brake shoe adjuster spring.
  7. Install bolt securing parking brake cable to knuckle and tighten bolt to 21 ft. lbs. (28 Nm).
  8. Using Brake Shoe Gauge, Special Tool C-3919, or equivalent, measure inside diameter of parking brake drum portion of rotor.
  9. Place Gauge over parking brake shoes at widest point.
  10. Using adjuster star wheel, adjust parking brake shoes until linings on both park brake shoes just touch jaws on gauge. This will give a good preliminary adjustment of parking brake shoes, before a final adjustment is made at end of this procedure.
  11. Install hub and bearing with wheel speed sensor as well as all components necessary to access it.
  12. Lower vehicle.
  13. Unlock automatic adjuster in parking brake lever.
  14. Perform final adjustment of parking brake shoes
  15. Adjustment This vehicle is equipped with permanently sealed rear wheel bearings. There is no periodic lubrication or maintenance recommended for these units.
    1. Raise and support vehicle.
    2. Remove wheel mounting nuts, then tire and wheel assembly.
    3. If equipped with AWD:
      1. Remove cotter pin, nut lock and spring washer from half shaft.
      2. While a helper applies brakes to keep hub from turning, remove hub nut and washer.
    4. Remove brake caliper and rotor from hub and bearing assembly.
      Fig. Hub assembly
    5. Disconnect vehicle wiring harness connector at wheel speed sensor connector.
    6. Unclip wheel speed sensor connector from spare tire mounting support.
    7. Disconnect two sensor cable routing clips on rear suspension crossmember.
    8. Disconnect two sensor cable routing clips along toe link.
    9. Disconnect sensor cable from bracket on brake support.
    10. Completely loosen, but do not remove four bolts fastening hub and bearing in place. Once loosened from threads in hub and bearing, push bolts up against rear of hub and bearing to keep brake support plate in place when hub and bearing is removed.
      Fig. Rear hub and bearing mounting bolts
    11. Pull hub and bearing off knuckle and half shaft (if equipped with AWD), then thread wheel speed sensor cable through hole in brake support plate as it is removed with hub and bearing.
    To install:
    1. Position hub and bearing bolts though rear of knuckle and parking brake support just enough to hold support in place as hub and bearing is installed.
    2. Install hub and bearing by first feeding end of wheel speed sensor cable through hole in bottom of parking brake support. As this is being done, if equipped with AWD, slide hub and bearing onto half shaft. Place hub and bearing through brake support, onto knuckle, lining up mounting bolt holes with bolts and placing wheel speed sensor head at bottom.
    3. Install four bolts fastening hub and bearing in place. Tighten mounting bolts to 60 ft. lbs. (81 Nm).
    4. Place wheel speed sensor cable routing grommet into bracket on parking brake support.
    5. Route wheel speed sensor cable along toe link and rear suspension crossmember connecting routing clips where shown.
    1. Connect vehicle wiring harness to wheel speed sensor connector.
    2. Install brake rotor and caliper.
      1. Install washer and hub nut on end of half shaft.
      2. While a helper applies brakes to keep hub from turning, tighten hub nut to 180 ft. lbs. (244 Nm).
      3. Install spring washer, nut lock and cotter pin on end of half shaft.
    4. Install tire and wheel assembly. Install and tighten wheel mounting nuts to 100 ft. lbs. (135 Nm).
May 18, 2011 | 2006 Chrysler Pacifica
Procedure for replacing rear whl brgs on a 2003 escape awd
4-Wheel Drive
  1. Before servicing the vehicle, refer to the Precautions Section.
    • Negative battery cable
    • Rear wheel
    • Rear brake shoes
    • Rear halfshaft nut and loosen the halfshaft from the hub
    • Wheel hub and place it in a vise
    • Inner wheel bearing race from the hub
    • Antilock Brake System (ABS) sensor bracket and move the sensor aside, if equipped
    • Parking brake cable from the steering knuckle
    • Brake line from the wheel cylinder and support the knuckle
    • Lower shock absorber nut
    • Lower ball joint by holding the ball joint stud
    • Upper ball joint
    • Coil spring while noting the location of the insulator
    • Steering knuckle cam
    • Steering knuckle
    • Snapring and press out the outer wheel bearing race from the knuckle
      Click to Enlarge
To install:
  1. Install or connect the following:
    • New wheel bearing into the steering knuckle
    • Snapring to the knuckle
    • Wheel hub
    • Steering knuckle cam and hand tighten the bolt
    • Coil spring
    • Shock absorber lower nut. Torque the nut to 85 ft. lbs. (115 Nm) for 2002-04 models; 129 ft. lbs. (175 Nm).
    • Upper ball joint. Torque the nut to 76 ft. lbs. (103 Nm).
    • Lower ball joint. Torque the nut to 76 ft. lbs. (103 Nm). Align the steering knuckle cam and torque the bolt to 85 ft. lbs. (115 Nm).
    • Brake line to the wheel cylinder. Torque the brake line bracket bolt to 15 ft. lbs. (20 Nm) and the brake line fastener to 11 ft. lbs. (15 Nm).
    • Parking brake cable to the backing plate. Torque the bolt to 16 ft. lbs. (22 Nm).
    • ABS sensor bracket. Torque the bolt to 80 inch lbs. (9 Nm), if equipped
    • Halfshaft nut. Torque the nut to 214 ft. lbs. (290 Nm).
    • Brake shoes
    • Rear wheel
  2. Fill and bleed the brake system.
  3. Check and adjust the wheel alignment as needed.
2-Wheel Drive
    • Rear wheel
    • Rear brake drum
    • Wheel hub nut
    • Wheel hub
    • Snapring
    • Wheel bearing outer race from the knuckle
      Rear hub removal
      Inner wheel bearing removal-rear hub/bearing
      Rear wheel bearing removal-2wd
      Rear wheel bearing removal-4wd
To install:
  • Wheel bearing in to the knuckle
  • Snapring
  • Wheel hub into the wheel bearing
  • Wheel hub nut. Torque the nut to 214 ft. lbs. (290 Nm).
  • Brake drum
  • Rear wheel
    Rear wheel bearing installation
    hope this helps if so send testimonial comment or even any other questions you have
Jan 16, 2011 | Ford Escape Cars & Trucks
The rear drum wont come off as i would expect
Yes, Undo the 32mm nut, first. And, don't get the bearings dirty with dust from the brake drums, or , if you do, replace the inner and outer bearings with new greased up ones.prev.gif next.gif REAR DRUM BRAKES Brake Drums REMOVAL & INSTALLATION CAUTION
Brake linings contain asbestos. Asbestos is a known cancer-causing agent. When working on brakes, remember that the dust which accumulates on the brake parts and/or in the drum contains asbestos. Always wear a protective face covering, such as a painter's mask, when working on the brakes. NEVER blow the dust from the brakes or drum.
  1. Raise the vehicle and support safely.
  2. Remove the wheel and tire assembly.
  3. On vehicles without rear bearing hub, remove the dust cap, cotter pin, nut lock, wheel bearing nut and washer from the spindle. Remove the outer wheel bearing. Remove the drum with the inner wheel bearing from the spindle. If the drum is difficult to remove, remove the plug from the rear of the backing plate and push the self adjuster lever away from the star wheel. Rotate the star wheel to retract the shoes. Remove the grease seal.
  4. If equipped with a rear bearing hub, remove the drum by removing the retainer screws from the drum and pulling the drum from the hub assembly. If the drum is difficult to remove, remove the plug from the rear of the backing plate and push the self adjuster lever away from the star wheel. Rotate the star wheel to retract the shoes. To install:
  5. On vehicles equipped without rear bearing hub, lubricate and install the inner wheel bearing. Install a new grease seal. Install the drum to the spindle. Lubricate and install the outer wheel bearing, washer and nut. Adjust the bearing preload following the procedure outlined in the "Rear Wheel Bearing'' of this section. When the bearing preload is properly set, install the nut lock and a new cotter pin. Install the grease cap.
  6. On vehicles with rear bearing hub, install the brake drum to the hub assembly and install the retaining screws.
  7. Install the wheel and tire assembly. Adjust the rear brakes as required.
  8. Apply the brakes until a firm pedal is obtained, prior to moving the vehicle.
Jul 12, 2010 | 1991 Hyundai Excel 4 Door
How do i remove the brake drum of a 1997 hyunidai excel do i need to remove the centre nut that also takes out the wheel bearing
With Rear Hub Bearing
  2. Remove the wheels.
  3. Remove the dust cap, cotter pin and loosen the locknut
  4. Remove the washer and outer wheel bearing.
  1. Remove the drum with the inner wheel bearing from the spindle.
To install:
  1. Install the drum on the spindle.
  2. Install the outer wheel bearing and washer.
  3. Tighten the locknut to 108-145 ft. lbs. (150-200 Nm). Turn the brake drum while tightening the spindle nut to seat the wheel bearings.
  4. Install the cotter pin and dust cap.
  5. Install the wheels
  6. Adjust the rear brakes.
Apr 23, 2010 | 1997 Hyundai Accent
Is the rear wheel bearing on an audi a4 adjustable, or just a standard roller bearing?
The rear wheel bearing on 2000 Audi A4 is adjustable! Very simply to do this work.
Feb 27, 2010 | 2000 Audi A4
Trying to remove rear brake drum cover,have already adjusted star wheel and still won't remove. what am i doing wrong? for a 93 plymouth grand voyager
  1. Raise and support the rear of the vehicle on jackstands.
  2. Remove the wheels and tire assemblies.
  3. Remove the brake shoe adjusting slot cover from the rear of backing plate.
  4. Insert a thin tool through the adjusting slot and hold the adjusting lever away from the star wheel.
  5. Insert an adjusting tool and back off the star wheel by prying downward with the tool.
  6. Remove the center hub dust cover, nut, washer, brake drum, hub and wheel bearings.
To install:
  1. Inspect the brake lining and drum for wear.
  2. Inspect the wheel cylinder for leakage. Service as required.
  3. Remove, clean, inspect and repack the wheel bearings.
  4. Install the brake drum and tighten the hub nut to 20-25 ft. lbs. (27-34 Nm), then back off the nut until bearing pressure is released.
  5. Retighten the nut finger tight, align the cotter pin hole and install the cotter pin.
  6. Adjust the rear brakes as described in the beginning of this section.
Removing the rear drum adjusting hole cover plug
Oct 07, 2009 | 1993 Plymouth Grand Voyager
Audi a4 tdi 51 plate
ring the main dealer and ask for torque setting they should tell u
Oct 17, 2008 | 2001 Audi A4
Easton 2009  Ea90 Slx Road Wheelset Campy Hub Clincher Logo
323 people viewed this question
Top Easton Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you an Easton Cycling Expert? Answer questions, earn points and help others
