Question about Dishwashers
Although appears to be working electrically no water getting into machine
    Problem Solver:
  • 15 Answers
Check solonide
Posted on Jul 03, 2010
Via Venezia coffee machine is not pulling/pushing water through the coffee filter although it is on and hot. Steamer works. Tubing appears to be properly attached. Any other suggestions?
check for limescale, try to descale the machine under vendor instructions, if you live in an area with hard water this may be the
problem.
I hope this was useful.
Sep 01, 2012 | Coffee Makers & Espresso Machines
When we switch the dishwasher on it trips the electricity. It's worked fine for 2 years but now won't work at all and just trips the electricity.
Your dishwasher has a serious electrical safety fault which is causing the protective breaker to trip (although it may have a simple and cheap cause). With all due respect, your question clearly demonstrates that you lack the knowledge and skills to carry out a diagnosis and a safe repair (especially vital for anything which uses water and electricity). Before doing anything else, fully disconnect your machine from the main electricity supply by either unplugging it or for a machine connected to a flex outlet by turning off the wall switch and then removing the fuse.
Sorry, but in this instance you only have two choices: get a qualified dishwasher repair engineer in or replace the machine. Anything else could be lethal.
Oct 08, 2010 | Beko Dishwashers
Washing machine EWF1087 Main light works, nothing else does, no display. Machine stopped half way through a wash, still full of water and clothes.
http://safemanuals.com/314159.php?k=0412aef66a84f8f875bfc5cd7f91d5c0&ID=281660&q=AEG-ELECTROLUX%20EWF1087
user manual.
http://www.home-appliance-kitchen-aids.com/washing-machine-repairs.html
troubleshooting advice.
Washing-machine-repairs - The washing-machine fills with water but does not start the washing cycle
1. The water level sensor or float switch may be faulty. If the unit does not sense that the water is at the right level nothing will happen.
2. When the water filling rate appears very slow, the inlet water filters may be clogged. Although not that common the inlet solenoid valve can jam and only partially lift.
3. The cycle timer or program circuit board may be faulty
http://www.washingmachinerepair.info/the_enquiry.html
Shows how it should operate.
There is a thermal switch inside the pump and this corrodes even after a year. If the filter is blocked the the pump has to work harder and so heats up (a lot). This switch is prone to staying open once it trips out.
SOLUTION
Isolate machine from mains and water supply.
Empty machine with drain hose and bucket at floor level.
Clean Filter out.
Turn machine on its side.
Remove electrical connections from pump.
Remove 3 screws holding pump (small leakage so get a towel).
Remove PUMP from machine. (be observant now)
Remove plastic cover over coil on pump.(its easy)
Thermal switch is soldered between 2 of the now 3 visible terminals. about 7mm x 15mm x 2mm in size
Remove small insulating cover and bend switch up about 30 degrees then flick with fingernail and blow out the dust or rust.
This resets the switch (horray)
Replace insulation on switch and bend back into position gently.
Replace cover over the coil.
Turn pump by hand (resistance should be like pushing 2 small/ medium size magnets together the wrong way)
Return pump to machine and reconnect pumps electrical connections. 2
Reconnect machine to mains (water and electric and waste)
Turn on machine while holding START and SKIP BUTTONS at the SAME TIME.
Leave it off for five mins then turn off and turn on again.
If it does not work straight away RESET again and Repeat as above.
SELECT PROGRAM AND WASH ALL YOUR TROUBLES AWAY.
Apr 11, 2010 | Washing Machines
F-08 error message on Hotpoint Washing machine WT761? The original fault on the machine was that it was tripping out and taking out a resetable fuse in my fuse box a few seconds after turning the machine...
If it works fine with the heater off then i would say that fault appears to be element..the readings you get seem okay, put you meter onto megs and check, with wires off if you get electrical leakage between live and earth...Body....of element, it could be element is heating with no water in machine causing it to burn out..this is a problem with this machine...Wish you well
Oct 07, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Ice maker not working
Cause could be the solenoid valve which controls water flow into the ice maker.
Could be bad solenoid, bad relay for solenoid, clogged solenoid valve, corroded electrical connections, etc.
More info? Let me know...
Charlie
Aug 14, 2009 | Refrigerators
Waher not working
It should mean "no water detected entering machine" or "pressure switch trip not detected". Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Check inlet valve operation
  • If there is water in the unit:
    1. Check Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Check there is not a siphon problem
  • Check wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Check pressure switch operation
  • Check flow meter operation
Jul 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water not draining although spin still ok. Then went bang!
Called out a plumber who diagnosed that the machine was not worth mending. He charged me £25. Now have new Indesit WM.
May 23, 2009 | Bosch Washing Machines
Neff S4340 integrated dishwasher seems stuck on cycle
yes take it apart under sink where it drains could be gunk in there
Feb 17, 2009 | Dishwashers
Cold water inlet not opening
Check the filter on the cold water inlet first to make sure it is not blocked. Next check the cold water solanoid. Take it out. Clean it, let it dry.
Jun 16, 2008 | Fisher and Paykel GWL11 Top Load Washer
Dishwashers Logo
Top Dishwashers Experts
