Question about Whirlpool LER5636P Electric Dryer
Whirlpool LER4634EQO Timer has not worked for years. Not the problem tho. Dryer was making some grinding-like noise. Shut itsel***. Went to restart by pushing button grinding noise and then stops pretty quickly. (heat works.) thank you for any help!!
    Problem Solver:
  • 15 Answers
Check the bush may need oiling
Posted on Jul 03, 2010
My whirlpool electric dryer makes a loud grinding noise
Is there anything caught between the dryer drum and any housing. Can you hear it when the drum is turned by hand.
Jan 26, 2014 | Whirlpool Dryers
I have a ler4634eqo and it runs but it stopped heating up and drying the clothes. It still blows air just cold air.
check circuit breaker heat is on seperate circuit may run with one circuit then check continuity on element,then limit switches, then timer
Feb 11, 2013 | Whirlpool LER4634J Electric Dryer
Engine makes grinding noise when starting
people like Ariana new help their help who with their and tooo sorry happen just so now 5012731103
May 24, 2017 | 2000 Chrysler Town & Country
The dryer will make a loud scretching noise like metal rubbing on metal and then after about 10 minutes the dryer will shut off and when you try to restart pushing the timer/start button, it just make a...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 31, 2011 | Dryers
I have a LER4634EQ1 WHIRLPOOL electric dryer. Last week it started to shut down before completing a cycle. The other day it completed the cycle but the clothes weren't dry. It also makes a loud noise when...
if the noise is a rumbling sound tha that would be your roller's.the other problem sounds like a bad timer.time to think,do i put that kind of money in a 12 year old dryer or get a new one.
Nov 05, 2009 | Whirlpool LER5636P Electric Dryer
Hi,Dryer wont restart
def. sounds like a bad or failing motor situation... motors cost anywhere from 125 to 200 dolloars... not too hard to replace though....
Sep 24, 2009 | Whirlpool LER7646E Dryer
Whirlpool LER4634EQO Runs for about 2 minuts and shuts off.
It is possible your Cycling Themostat is not working properly. It determines at what temperature to turn heat on and off to maintain a consistent dryer temp. The High Limit Thermostat would turn off the heat but your dryer would still run. That leaves the Thermal Cut Off which is turning off your dryer. It might be faulty and turning off at too low a temp, or it might be doing it's job. In that case something else is wrong. If you can check the exhaust air temperature at the dryer, it should be under 175 degrees. If you are absolutely sure the vent is clear, then replace the Dryer Cycling Thermostat.
Aug 25, 2009 | Dryers
Dryer doesn't want to run- makes grinding noise
its sounds like a worn bearing problem.with the m/c switch off ,turn drum by hand and see if it is hard to do so.if you get a gritty feeling in your hands or hear a grinding noise,then that is probably the bearing.
Jul 23, 2009 | Dryers
Whirlpool Estate Dryer not working
Sounds like the motor has seized. Try manually turning the drum with your hands. Is it hard to turn? If it is then the motor has seized up. If not, the windings in the motor may have shorted. Hopefully this answers your questions
Apr 08, 2009 | Whirlpool Dryers
Whirlpool LER5636P Electric Dryer Logo
136 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
