Question about Belkin Wireless USB Hub
Blue screen with multifunctional printers
Hello I am from Belgium.
Everything works with the Belkin wireless USB hub but not a multifunctional printer. I have already tested it on another computer : bleuscreen.
Also tested with another multifunctional printer : bleuscreen.
Have also got support from Belkin with no results : firmware update.
I think I need a specialist !
    Scholar:
  • 144 Answers
Normally the USB hub is design to connect to the device that doesn't consume electricity like handy drive,MP3 player.So in your case the multifunctional printer, I think this one really need a direct connection to your PC,instead of going through USB hub.Try to move some other device to connect to this hub and connect your printer directly to PC..due to many restriction with printer like electricity,port,etc...
Posted on Apr 20, 2008
We have a Belkin USB hub successfully networking 3 printers to two PCs. We are currently making the drastic switch to two new iMacs to replace the decrepit, outdated PCs. How can we get the printers up...
it's a wireless access point;configure your imacs pc with any pivate ip address like 192.168.1.1/192.168.1.2 etc and don't forget to installed ethernet driver and wireless daemon is on select the authenication protocols as stated in the access point;hope it connect
Dec 01, 2009 | Belkin 5-Port USB Hub
Usb hub unsafely unplugged from notebook. now
do one thing boot ur vista without usb hub then go to device manager remove your usb drivers of the hub disconnect the hub from computer, restart notebook, then connect the hub back when windows boot let vista to install the driver of that hub, after that connect your devices one by one ok let me know what happen? :-)
Aug 21, 2009 | Belkin (F5U237) 7-Port USB Hub
Wireless hub
I had the problem that,even though the hdd connected it would fail after a period of time (video streaming or file transfers). Set up was Samsung Q45 running wireless g connected to a belkin draft N Router. 3 other PCs (all g) using 2 different OS (Vista and Mac) had same problem.
Solution after months of searching, problem solved. Fitted Draft n PCMCIA card, and to ensure it was running at 300Mb had to use WPA PSK + WPA2 PSK security mode . Now works brilliantly and has managed to stream a full HD movie!! The Wireless link is now running faster 10Mbs compared with 4Mbs on g, although not fast it at least enables the HHD to be used in a stable configuration. Problem seems to be that the unit will not work properly unless wireless n link is used.
May 18, 2009 | Belkin Wireless USB Hub
HP printer will not print over wireless network using Belkin hub
Try turning everything off, wait a couple of seconds and then turn it back on.  Also try disabling McAffee to test.  When you go to printers and faxes on the PC, what is the status of your printer?
Apr 16, 2009 | Belkin (F5U237) 7-Port USB Hub
WD My Book 1TB not recognised by belkin modem router USB storage
I have a work around for this.
In the detail of the Belkin manuals it says you can attach up to 4 USB storage devices via a USB HUB.
I had an old Hub so I Connected the HUB to the router and the Maxtor to the HUB --- It worked :-) It came up in a few seconds.
At first I powered the HUB but later took the power out of the hub and it still worked ;-} However when I used a different HUB it would not work without power to the HUB.
The HUB I use is an old Belkin 4 port Tetra Hub. The newer 7 port Belkin HUB (5 Rear 2 Top) only worked with the HUB powered.
Hope this helps untill Belkin Upgrade the Router sofrtare.
Apr 07, 2009 | Computers & Internet
Blue screen when playing iTunes on Logitech Z-10 speakers
Before, you return it, can you unplug the Wireless USB Hub, and plug in your iPod and does it work just fine?  Also, the USB port that you're plugging it into - is it USB 2.0?
If both answers are YES to the above - then definitely return it.
It's not your speakers.
Mar 11, 2009 | Belkin Wireless USB Hub
Wireless capability?
You should be able to buy a USB Wireless hub which you then connect to your printer using a USB cable.
The hub will come with software and instructions that then allow your laptop/PC to connect and use the hub as if it was a wired unit.
Belkin do something like this so that's probably a good start.
Jan 03, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Belkin Wireless USB Hub Logo
201 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
