Question about RTO Sole F80 Treadmill
Error code main 1.4-- The treadmill stops at approximately 20-30 mins doing the manual mode
4 Suggested Answers
  • 13 Answers
SOURCE: I have a Quinton Clubtrack treadmill Error E105 NVRam Failure
fax me @ 281-469-9550 your full model number and I can fax you the setup modes.
Posted on Aug 10, 2009
AJIN G
  • 6694 Answers
SOURCE: 9.33 treadmill set manual 30
hi,
It have some problem with motor controlling circuit board. The repairing in the circuit board of treadmill should done by an experienced person in it, because there are harmful high voltage areas in the circuit board. Consult some one who is experienced in it.
ok
Posted on May 22, 2011
  • 910 Answers
SOURCE: Star Trac 2 treadmill. Power supply ok.
I can't find any reference to a Star Trac 2 Model.
Can you confirm from the following link using your SKU or Serial No. which is your Model.
http://support.startrac.com/index.cfm?fuseaction=prodinfo.ibp02&typ=1&sty=1&dct=&wsr=&sid=
Posted on Jul 31, 2011
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
I have johnson jet 7000 treadmill and its showing error 2 what can i do
HI,
Error 2 means P0 P1 P2 P4 P5 ( P0 ....Min. ,Speed P1 ....Max, Speed P2 ....Mid.Speed, P4 ....Min.Slope, P5 ....Max.Slope )have a wrong parameter values. You have to go the engineering mode and set the parameter. Here i have added a link which will guide you to the service manual of Jet 7000. read the section 4 (console maintenance mode guide) and re-calibrate the treadmill parameters P0 P1 P2 P4 P5 .page no(4.3).
http://www.cross-ir.com/Downloads/JET7000-6000-1.PDF
WWW.electro-medical.blogspot.com
Sep 16, 2015 | Exercise & Fitness
What's the problem of error 1 on my york t520i treadmill that stopped working, I need your help please.
Error 1: Speed sensor error Turn the power switch off and on again to reset the treadmill. If the treadmill returns to normal operation, you may continue to use the treadmill. If treadmill does not return to normal operation, then call the dealer for advice.
ERROR 1 CODE This is a safety feature that can stop the treadmill from functioning. This error can occur because the computer is not receiving the correct information from the speed sensor located near the motor. As a precaution the computer stops the treadmill until it begins to receive the correct feedback. By performing a few simple checks, the error can be cleared quickly and easily, and the treadmill can be ready for use. The treadmill does not move and displays "ERROR 1" Switch off the treadmill at the mains, and then switch it on again. If "ERROR 1" still shows switch off and push the running mat round (1 cycle) using your feet. Then switch back on. If "ERROR 1" still shows, then UNPLUG from the mains and check all of the wire connections made during the assembly. (SEE BOLD PRINT) UNPLUG If the treadmill still does not move, then please contact the helpdesk. Doing this may reset the program error, and the treadmill will be ready to use. This should reset the sensor, and the treadmill will be ready to use. Once the cables have been checked, turn on the treadmill again. This should eradicate the problem. 1. 2. 3. When assembling, there are several cables that need to be connected. It is very common for these cables to look like they are connected when they are in fact not fully connected. Make sure that these cables are connected as tightly as possible. The connections may have come apart whilst assembling the treadmill. here is a link to your treadmill web site http://www.yorkfitness.com.au/uploaded/pdf_71T520i%20Treadmill_5562.pdf
Mar 02, 2015 | York Exercise & Fitness
Carol lewis mot566 error code 03
1)probably a faulty speed sensor
2) speed sensor is not plugged in properly.
3)possibly a faulty motor
4) Main control board or lower board.
The error codes will differ between makes and models but could be e1.
Check this video for speed sensor.
http://www.youtube.com/watch?v=23ZgWaVEQjA
adjust the speed sensor:Move the motor to slacken the pulley, then lift the motor to get underneath. That is where the treadmills speed sensor will be located. It is usually a square or rectangular shaped green module with connectors at both ends.
Finally after you did the adjustment you can conclude:
A) Faulty Speed sensor B) Main Motor faulty C) Main Motor Controller faulty.
attached block diagram for treadmill that I did for any treadmills,see how the Main Motor Board has function for 90% of the treadmills.
sincerely.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Nov 23, 2011 | Exercise & Fitness
I have a sportcraft treadmill tx335 it shows error 7 why and how do i fix it
Error code seven is due to the console getting locked. I called Sportcraft and they said to do this: Unplug the treadmill for five min and then re-plug the treadmill. Now push the ON/OFF switch to ON and insert the safety key. Now press the MODE and STOP button simultaneously. Without releasing the buttons take out the safety key and insert it again. Now you should hear a beep and the display will come on. Release MODE & STOP and now press the Speed increment (+) button
Oct 31, 2010 | Health & Beauty
I have the Lifecore Fitness T900HR treadmill and when my husband is running it stops. We have made sure all the connections are tight even the safety key but it still stops. When I am using the treadmill...
Their might be high friction between the belt and deck thus causing the error 1 code when your husband is on it. Try lubricating the area between belt and deck using silicone lubricant ( refer to owners manual). Then the lighter of the two "aka wife" walk on the treadmill for about 5 to 10 minutes.
This should take care of the problem if not then their is an issue with the belt and deck ( 85% of problems on treadmills are belt and deck related)
Jul 31, 2010 | RTO LifeCore Fitness LC-T900HR Treadmill
Err22 showing.How can I start?My machine is Precor 956 model.
The speed sensor is a hall effect sensor that emits a pulse when a flywheel lobe passes between
its transmitter and receiver. The speed control circuit processes the pulse train emitted by the
speed sensor. The speed sensor signal is a real time representation of the operating speed of
the treadmill. The speed control circuit compares the real time speed (speed sensor output) with
the speed that it expects the treadmill to be operating at and acts accordingly to control treadmill
speed or initiate an error code sequence, if necessary. Typically, if a problem exists with the
speed sensor the drive motor will operate (perhaps only briefly) before a speed related error
occurs (errors 20-26).
1. Set the treadmill circuit breaker in the “on” position. Using a DC voltmeter, measure
the voltage between terminal 3 of J2 (green wire) and terminal 4 of J2 (black wire) on
the lower PCA. Slowly, rotate the drive motor flywheel. The voltage should read
approximately 5 Vdc when a flywheel lobe is between the speed sensor “legs” and
approximately 0.25 Vdc when a flywheel lobe is not between the speed sensor “legs”
2. If the voltages in step 1 are correct, go to step 5. If the voltage in step 1 is 0 Vdc or
significantly low when a flywheel lobe is between the speed sensor “legs, continue with step
3.
3. Measure the voltage between terminal 1 of J2 (red wire) and terminal 4 of J2 (black wire) on
the lower PCA. The voltage should read approximately 5 Vdc.
Flywheel
Speed
Sensor C954, C956 Treadmill
Page 1-24 Page 24
4. If the voltage is missing or significantly low, disconnect the speed sensor plug from the lower
PCA. Measure the voltage between pins 1 & 4 of the J2 plug on the lower PCA. If the
voltage is approximately 5 Vdc, replace the speed sensor. If the voltage is missing or
significantly low, replace the lower PCA.
5. At this point the speed sensor output is good, but a speed error occurs. There are two
potential causes for this condition. They are upper PCA or lower PCA. There are no good
means of troubleshooting these components other than substituting known good
components. Replace only one component at a time. If the component that you replaced
does not correct the problem, replace the original component. Try substituting the lower
PCA first then the upper PCA, if necessary.
tips extracted from the technical manual Precor956
Jul 14, 2010 | Precor C956i Treadmills with HR /...
Message in the display "err 2" and my kettler treadmill doesn't work
Hi Rendra,
Try this:
Switch the treadmill off and then on again.
Push the "minus" speed button and the "stop" button simultanuously.
If all is well you will now have entered the maintenance mode.
Next push the "plus" speed button and the "stop"button smultanuously.
Now you you've reached the error mode.
Push the "plus" or "minus" speed button to browse the error codes untill you've reached "L er".
The push start to erase the message.
Turn the power off and then on again to restart the treadmill.
With any luck the error has disappeared and the treadmill will function again. If not.....you'll have to contact Kettler.
Btw...This error occurs when the belt is "pushed" by the runner. For example when you put weight on the handlebar and the push your feet backwards.
May 10, 2009 | Exercise & Fitness
I have a dishwasher that only works intermitently...
most fault codes are 10, 20,30.........90 not familar with c2. ther is a fault earky on in a prog where if the pressure switch does not retun to empty the prog stops and displays 10 or 30. the pipe leading from the front of the sump to the pressure switch can sag. tieing it up to stop the sag can cure this..
Feb 27, 2007 | AEG 24 in. Favorit 60870M Free-standing...
RTO Sole F80 Treadmill Logo
71 people viewed this question
Top RTO Exercise & Fitness Experts
Jim London
Jim London
Howard
Howard
Jax Planet
Jax Planet
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
