Question about JVC AV-20120 TV
Jvc au31bm5 line in the middle of the screen black on top and bottom
  • JVC Master
  • 1,213 Answers
You have a bad ground on your vertical IC, Resolder this and check the capacitors nearest this IC. There would be about four of these to check and, or replace. If you still have this horizontal line then this IC may be bad as well! This is a good place to start repairs! Thanks for asking!
Posted on Jul 03, 2010
I bought an LCD Samsung 3 years ago and about a year ago a thick black line appeared in the middle of the screen. Can this be fixed at home?
check if the lines appear on different inputs or source like hdmi,av,pc, if it happens on a different source then theres a problem with the lcd screen it needs to be fix.
Dec 26, 2014 | Samsung Televison & Video
Black line through middle of emerson led tv screen
Sounds like panel fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Screen-shots to defective LCD panel are given. You can compare it to that of your TVs'.
Apr 23, 2014 | Emerson Televison & Video
I HAVE GOOD AUDIO BUT A THIN LINE IN THE MIDDLE OF THE SCREEN THAT HAS VIDEO. ALSO THE SCREEN IS BLACK ON THE TOP AND BOTTOM WITH THE THIN LINE OF VIDEO IN THE MIDDLE.
Have you vertical deflection circuit checked for bad Vertical IC, and or Bad vertical Capacitors in the vert output section for the deflection board. Also have Vertical output Pump up Capacitor replaced, also have B+ voltage check coming from flyback transformer, for any open fusible resistors
Oct 12, 2009 | JVC AV-20120 TV
Screen on JVC TV distorted
There is an Aspect button on the Remote for the TV. This button will fix this problem.
Aspect function strectches the picture horizontally or vertically to get rid of black bars in some movies. Sometimes this is good....sometimes bad
May 19, 2009 | JVC Televison & Video
Repairing JVC AV-27D202 27" TV
This is caused by a bad capacitor in the vertical circuit. If you can solder, you may be able to resolve this yourself. If you wish to attempt this repair, please update this and I will provide additional details and instructions.
Dan
Mar 21, 2009 | JVC AV-27D202 27" TV
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
Black line in middle of panasonic plasma screen
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Oct 13, 2008 | Panasonic TH-50PV30 50 in. Plasma...
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
Aug 17, 2008 | Televison & Video
Jvc av-29ts2ek
It sounds like a vertical deflection problem. You mentioned you had a white HORIZONTAL LINE in the middle of the screen. If this line runs from left to right across the screen it's in Verticla deflection. If it runs from top to bottom, it's in Horizontal deflection. I am assuming the problem is a Vertical deflaecion problem. The repairs necessary are most likley to replace the vertical capacitors or the verticla deflection chip.
Good Luck
Ed
NC Electronic Mills, Wyo USA
Jan 05, 2008 | JVC TM-2703SU 27" TV
JVC AV-20120 TV Logo
46 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
