Question about Garden
How do i get the clutch off of a poulan chainsaw. i know it is a left handed thread but how do you hold it fixed to turn it off?
    Brigadier General:
  • 4,088 Answers
Try stuffing some starter cord into the spark plug hole to block the piston rising--make sure that the piston is high enough in the cylinder that the cord doesn't get jammed into one of the cylinder side ports (exhaust or transfer). It also requires a special tool to turn the clutch. Don't use an impact wrench as it will shear the flywheel key. Good luck.
Posted on Jul 03, 2010
How do i get the clutch drum back on my chainsaw
the clutch is held on with left hand threads not right hand threads like most other bolts
Jul 28, 2012 | Poulan 14" Chainsaw
I am unable to get the bar and chain off of my Poulan Pro 260 42cc chainsaw because the stud for the clutch brake housing has broken loose inside the housing. When turning the clutch brake nut the clutch...
I ran into the same problem and I "cheated" my way through this. First of all, the thread is metric on the stud. Take an imperial nut and start to thread it on the stud. Don't force it, it will stop after half a turn. Now you hold the imperial nut with a socket or a wrench, and use a flat wrench to undo the other nut(the one that is stuck). It took me 2 minutes to remove it and no damage done at all.
Hope it helps
Mike
Jun 25, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How do i change the clutch?
You didnt say what model this is, however there is a special tool for most mcculloch clutches, it has two pins that fit into the two half round holes in the clutch centre, there is a 19mm nut on the outside which enables yoy to jat the clutch off against compression, left hand thread.tool part no. 530031112
Apr 06, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How do i replace the drive mechanism for a poulan pro model pp4218avx
Ok, start by removing the side cover, there will be a large plastic nut with a flip up lever, undo the nut anti clockwise, now remove the guide bar and chain which are now free, there will be a c clip and washer holding the clutch drum on, remove the clip witha suitable screw driver, remove the large washer, the clutch drum will now just pull off, there is now a small washer to remove, you will now see the clutch, there is a special tool required to remove the clutch, it fits into the two half circle cut a ways in the clutch centre, the clutch is threaded onto the crank with a left hand thread, once the tool is fitted you put a 19mm spanner on the tool and jar it off against compression. The special tool is part no. 530031112.
Feb 19, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a Poulan Pro #sm4218av. My problem is the clutch drive is locked and won't release
The bearing between the hub mechanism and the outer drum may have seized. Try spraying some WD-40 into the bearing and work the outer drum back and forth. If you can get it to turn, then put a little bar oil into the bearing and continue to work it some more. If this doesn't help, you will need to replace the clutch (left hand threads). This might be an opportunity to get familiar with your local saw service shop. Hope this helps!
Nov 24, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
On my petrol chainsaw the cog that turns the chain is not moveing
The sprocket should be fixed to the outer clutch drum. With the engine off, and the bar and chain off, hold the sprocket with channel lock pliers and turn the outer clutch drum by hand. If the sprocket does not turn, but the drum does, then the clutch must be replaced. (Left hand threads) To keep the engine from turning while trying to remove the clutch internals, stuff starter cord into the upper cylinder head area so that the piston cannot rise above the top of the exhaust port. If you have a saw service shop near you, you might farm out the clutch replacement. It usually requires a special tool to turn the clutch internals. Good luck!
Jul 23, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Poulan countervibe 3400 clutch removal
Hello DJ; I suspect she is has some age. The IPL I found (below) shows an outboard clutch and no chain brake.
http://www.ordertree.com/modelinfo/PWE/3400-Gas-Saw/75.3400-Gas-Saw.1.59.1.html it may be helpful with disassembly. Clutch detail is on the "Handle Bar Assembly" print.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make certain the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
3. Most (99.9%) clutches have left hand threads (tighten it to loosen it). If a finger nail held in the thread and rotated clockwise comes off the shaft it is a left hand thread. If it pinches against the clutch it is a right hand thread.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jul 18, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
How do i take the clutch dog out of a poulan chain saw
Watch the video it will help. Left handed thread.
  2. A length of starter cord or nylon rope may be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. It is probably a left handed thread (tighten it to loosen it).
    Let us know how it worked for you. GL
Lou
Oct 18, 2009 | Poulan Garden
How do i pull the clutch assymbly off my paoulan pro 18" 42 cc saw
R² Drive Link Inboard Clutch
http://www.youtube.com/watch?v=YUbSIHMSSP8&feature=PlayList&p=4A4A1DF66590854E&index=0&playnext=1
The C-clips tend to fly when being removed. Please wear eye protection and exercise care.
View this; it will help. Your clutch is a left handed thread.
  1. Check at the IPL for your saw to see if any special tools are needed.
You didn't provide the model number of you saw, I can't be more specific. You can find an IPL (exploded parts list) that will list any special tools here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
Lou
Sep 29, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Wildthing 18" chainsaw 2375 sprocket/drum replacement
mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 mso 9]> mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> mso 10]> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi tchild,
my name is Dennis Gladx and I can assist you with the problem of getting the sprocket off of the crankshaft of your chainsaw.
To remove the centrifugal clutch and sprocket you unscrew it from the crankshaft and it has a left hand thread. Also a little trick to remove anything from a crankshaft that could turn while you want to unscrew the item, Remove the spark plug and insert some rope into the cylinder for the piston to squeeze against and you will jam the piston without damage.
Glad to be of assistance Please rate this solution because I can learn from your rating. Thank you
Nov 08, 2008 | Poulan Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
