Question about Goodman CKL60AR60 Air Conditioner
Unit not cooling
My unit is blowing out air but it is not cool air,my fan on thr outside is hot
  • Goodman Master
  • 43,501 Answers
There can be a couple of things that could be happening...
The first and easiest thing is to check the air filter. Make sure that it is clean... clean it or replace it. Next check the air vents to make sure that they are open and giving you good air flow...
Also check to make sure that you are not icing up on the indoor coil... ice will tell you that you are low on refrigerant. You also could be low and not be icing over, but you would need to have gauges on the unit to check that.
Finally check and clean the outdoor coil...this also can give you problems if the heat is not being removed from the outdoor unit efficiently...
You may also have a unit that is sized in such a way that it hits the balance point at about 85...that means that your heat gain is equal to the capacity of the unit...I often try to size them for about that here in Northern PA. because wqhen seldom get hotter then that and the unit then is much more effective at removeing humidity at lower temperatures...
You can also check out the tips that I have wrote about Air conditioningunit not cooling - 2_bing.gif trouble shooting and maintenance...
Posted on Jul 04, 2010
I have a Hampton Bay AC. It is 18,000 BTU. It is 230 volts. The EER is 9.7 and it is 8.3 to 9 amps. When I use energy mode on the AC it blows warm air. What gives? Just cool mode and it blows cool.
Hi Paul,
  • Energy Saver Mode most likely shutdown the compressor and Fan Only will be running to recirculate Ambient air into the room.
  • Make sure there is no Port or Vent that is open on your unit and would let hot air from outside be mixed in with the ambient air especially if it is hot outside.
  • Also refer to the troubleshooting section of your owner's manual.
Good Luck,
JP
Jun 21, 2015 | Hampton Bay Heating & Cooling
Unit not cooling inside below 72 degrees lines sweating
how hot is it outside??? 20 degree split is usually the norm ,,,,,outside 95 then inside will be 75,,,,,where is the line sweating ,,, it should sweat near outdoor unit
Jun 02, 2014 | Ruud Central System Air Conditioner
2000 NISSAN 4X4 P/U A/C SYSTEM WILL BLOW COLD WHEN OUTSIDE AIR TEMP IS COOL, WHEN HOT OUTSIDE AIR BLOWS HOT.
your auxillary fan is not working. this fan is responsible for cooling the freon that is being circulated in your cooling system... check if there are any loose wires in front of the engine bay.
the auxillary fan is located right beside your radiator fan.
May 17, 2012 | 2000 Nissan Frontier
A C blowin hot air. cecked unit outside. Fan is not blowing. Turned off, allowed to cool off. Unit worked 10 minutes. now blowing hot air again
Sounds like another problem with the capacitor being bad, if you cannot hear the compressor operating either this may be the case.
Jun 25, 2010 | Heating & Cooling
Goodman A/C won't cool
Fan motor or capacitor has gone out. Running the unit with the motor not running can cause damage to your compressor
May 01, 2010 | Goodman CKL24AR24 Air Conditioner
My fan isn't working
well there not enough data here to make a fairly good solution. but if all the fans are running! and no cool air then it is the compressor.
Jul 14, 2009 | Heating & Cooling
Uotside unit blowing cool air but hot on the inside
It sounds like you have a unit called a heat pump. When a heat pump unit is in cooling mode the outside unit blows hot air and the inside unit blows cold air. If the outside unit is blowing cold then the indoor unit is most likely blowing room temperature or warm air. It sounds like the thermostat could be controlling incorrectly or you could have a failed reversing valve which is the device that switches the unit from heating to cooling mode.
May 31, 2009 | Ruud UBHC Air Conditioner
We have a fujitsu air con model ast9lsbcw which blows cold air from the outside unit and the inside unit is not cooling the room.
Sounds like you have it in heating mode or it is low on charge. In cooling mode, the outside fan should blow hot air not cold.
Jul 30, 2008 | Heating & Cooling
My blower motor doesn't blow air out the air ducts why
Check for a frozen cooling coil. Turn the fan to the on position at the thermostat and the cooling to off. Your cooling coil may be iced over. Allow it to run in the fan only mode until the coil has had a chance to defrost. At the outside unit you may see the large line is frosted. This is the visual indication for a frozen coil. When you return the A/C to cooling use it with the fan on while in the cooling mode.
May 26, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Goodman CKL60AR60 Air Conditioner Logo
185 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
