My HE4 front loading Kenmore washing machine leaks when I run a full load (no problems with a very small load)
  • 5,911 Answers
If your FRONT LOADER is leaking, the following link can give you guidance on how to inspect the washer to determine where the source of the leak may be coming from:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
Most commonly, the source of the leak comes from the door bellow (gray rubber seal). They do wear out with age and can develop small rips and tears. A routine inspection of the perimeter of the door seal can determine if you have any holes. If the seal is damaged, it must be replaced. The following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope you find this information helpful.
NOTE: The leak may only appear with heavier loads, because more water is in the drum and it is being displaced by the laundry load.
Posted on Jul 03, 2010
I just moved and all of a sudden it won't drain completely
In the move, the removal men tipped it over and have split one of the hoses. First off check the discharge hose at the back for cracks, kinks or crushing..
Dec 30, 2015 | Kenmore Elite 45986 Front Load Washer
Front load washer leaking on the floor
Check the bellows gasket real carefully for a hole, and make sure the door gasket is good and no problems with how it fits to the front of the machine.
Pull the machine out, and watch it from all angles with any covers off that can be removed without interfering with function. Run a quick rinse and see what leaks.
Nov 24, 2013 | Kenmore Elite HE4 Electric Dryer
Washer won't spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 14, 2011 | Kenmore Elite HE4 Electric Dryer
Kenmore washer # 110.26742500 doesn't fully dain. clothes are wet at the bottom of full loads? any ideas?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Oct 02, 2010 | Kenmore 24732 Top Load Washer
Describe your Kenmore 24032 \ 24036 Top Load
Water pump is my first guess. Did you check the hoses that hook to it? The pump is in the front of unit. Give full model number to further assist you.
Jun 15, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore elite washer model 20952992 pouring water
We had the same problem. The bleach dispenser tray is located on the drum below the bleach storage pan. The dispenser tray has very small holes that were plugged by rust from the hose clamp that attached the dilution water supply hose to the bleach storage pan. I removed the top of the washing machine to discover the problem, but it may be solved by attaching a flexible tube or small hose to the end of a vacuum cleaner hose and cleaning out the dispenser tray. There is room between the dispenser tray and the storage pan and is located in the front right corner.
Dec 10, 2008 | Kenmore Elite HE4 Electric Dryer
Panel on front says " 888" what problem is that
Her isds the website that Kenmore refered me to for your manual but I needed the serial number as there are four of them available.   I hope this helps.
http://www.managemyhome.com/mmh/
Dec 10, 2008 | Kenmore Elite 45986 Front Load Washer
Water trickles into Kenmore front load while machine is off and door is open
sounds like a bad water inlet valve stuck open and permitting watertto enter even though not on, untill you replace the valve turn off water between uses part number 8181694
Oct 31, 2008 | Kenmore Elite 45986 Front Load Washer
Leaks water onto floor in front of washer after spin cycle, help
open the door though, put your hand around the rubber boot assy, run *** all around looking for small tears, and or holes, if so replace it. only other thing to do is remove the lower access panel and watch it spin a load and youll be able to detect where te waters coming from
Mar 22, 2008 | Kenmore Elite 45986 Front Load Washer
Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
Mar 09, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
