We are looking for a Network Key on a 2 wire 638 sometimes referred to as WEP key or WPA key
    Novelist:
  • 112 Answers
The 2-Wire comes with built-in Wireless key, WEP-10 digit key, which is located at the bottom of the product, near the bar code label. However, you can also change the default WEP Wireless security key.
You can view the complete details to change the default Wireless key in the link posted below.
http://support.2wire.com/?page=view&article=60&text=wireless%20key&cat=&sort=
Posted on Jul 03, 2010
WAP/WEP password not working
These are the two options for your Router. Don't forget to save your settings
WPA is an upgrade to the WEP (Wired Equivalent Privacy) standard for securing your wireless network. If you would like to secure your wireless network using WPA, you will need the following:
  • WPA enabled on your Dell TrueMobile 2300 Wireless Broadband Router
  • WPA support for your wireless clients. If you are using a Dell TrueMobile wireless client, you can check for the availability of WPA enabled software update for your wireless client at http://support.dell.com.
  1. Log into the Web configuration of your router at http://my.router (or the default address http://192.168.2.1)
  2. Click on Basic Settings.
  3. Click on Wireless Security.
  4. Click on the Enable Wireless Security checkbox.
  5. Select either WEP or WPA in the Network Authentication list.
To setup WPA
  1. Enter your pre-shared key. This key must match the key that is used by each wireless client computer associated to your router.
  2. Choose a key format. This can be hexadecimal digits (0-9, A-F) or ASCII characters (any key on the keyboard).
  3. WPA Group Rekey Interval specifies how often the key rotates or changes.
  4. WPA Encryption allows you to select 1 of 2 possible encryption methods (TKIP and AES) - choose one that your wireless clients supports.
  5. Click NEXT, then Save and Restart to apply the changes.
  6. Setup the WPA on your wireless clients. Refer to the documentation that accompanied your wireless clients, or your wireless clients on-line help system for information on how to setup WPA.
May 14, 2012 | Dell TrueMobile 2300 Wireless Broadband...
Where do i find network key?
Follow these steps:
1. Open Internet Explorer then type the numbers 192.168.1.1 on the address bar then press enter.2. Make sure that the pc is connected via hard wired connection.3. After typing the numbers on the address bar, the site should be on the modem settings page.4. Go to basic settings or look for the Wireless Tab then select and browse thru it.5. Under SSID, there will be security option, check if you are using the WEP or WPA security key.6. Whatever the WEP or WPA key is, that is your network key. Since you are already on the said tab, it will be better if you are going to retype or change the WPA - Pre Shared Key and make sure that you will remember whatever the Pre Sahred Key you used.7. Select Save and apply then exit.8. You are good to go then, using your network key..
Thank you and kindly rate this post.
Jan 02, 2012 | Vizio XWR100 Wireless Router
Where do I find the Network Key (or WEP or WPA Key) number for my Belkin F5D8236 router?
Hello cyndi0417.
If you have installed your router, and have a computer connected to it through one of the wired ports, you can follow these steps to find your WEP or WPA key.
Step 1.
Open a web browser of your choice, and in the address bar type in "192.168.2.1" (without the quotation marks).
Step 2.
Select "Login" from the upper right corner of the screen. Unless you have changed the administrator password, you can just click on the submit button.
Step 3.
Look under the "Wireless" heading on the left side of the page. There will be a selection for Security, which will contain the WEP or WPA settings. The numbers/letters in the boxes is your key.
Feb 01, 2011 | Belkin F5D8236-4 Router
What is the wep
Wired Equivalent Privacy. It is an older wireless protection standard that has been replaced with WPA and WPA2.
Nov 01, 2010 | Computers & Internet
I need help getting our network key for our wireless router...
What is the model number of your dlink router?
anyway, just go to your hardwired computer:
Hardwired computer:
1. open web browser
2.in the address bar typein 192.168.0.1
3. the username:admin password:(None, just leave it blank)
4. Click "SETUP"
5.Click "WIRELESS SETTING"
6.Click "MANUAL WIRELESS NETWORK SETUP"
7.change now the SSID or NETWORK NAME (create a new name to avoid conflicts with your ol network name that was saved into your computer
8.Look for security mode, Select WEP or WPA-Personnal
if WEP select 10 number as a password
if WPA-Personnal, minimum of 8 Characters
9. type in the network key
for WEP type it in WEP KEY 1 (PLEASE DONNT CHANGE key 2,3,4)
for WPA-PERSONAL type it in PRESHARED KEY at the buttom.
10. then click on save settings on the top
Thats it.....
hope this will help you
Aug 13, 2010 | D-Link Computers & Internet
How to secure my internet connection via smc router
If you plan to have a wireless network, you should set it up so that only people you choose can access it. Here are a few options for wireless network security.
Wired Equivalent Privacy (WEP)
WEP is a widely used network security method. When you enable WEP, you set up a network security key. This key encrypts the information that one computer sends to another computer across your network. The receiving computer needs the key to decode the information so that it's difficult for someone on another computer to get onto your network and access files without your permission.
Wi-Fi Protected Access (WPA)
WPA was created to improve the security of WEP. Like WEP, WPA encrypts information, but it also checks to make sure that the network security key has not been modified. WPA also authenticates users to help ensure that only authorized people can access the network. If your networking hardware works with both WEP and WPA security, we recommend that you use WPA.
There are two types of WPA authentication: WPA and WPA2. WPA is designed to work with all wireless network adapters, but it might not work with older routers or access points. WPA2 is more secure than WPA, but it will not work with some older network adapters. WPA is designed to be used with an 802.1X authentication server, which distributes different keys to each user. This is referred to as WPA-Enterprise or WPA2-Enterprise. It can also be used in a pre-shared key (PSK) mode, where every user is given the same passphrase. This is referred to as WPA-Personal or WPA2-Personal.
802.1X authentication can help enhance security for 802.11 wireless networks and wired Ethernet networks. 802.1X uses an authentication server to validate users and provide network access. On wireless networks, 802.1X can work with Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) keys. This type of authentication is typically used when connecting to a workplace network.
IF THIS ALL DOSEN'T WORK TRY THE FOLLOWING:
Wireless network security recommendations
If you have a wireless network, there are some additional security precautions that you should take.
Use a network security key
If you have a wireless network, you should set up a network security key, which turns on encryption. With encryption, people can't connect to your network without the security key. Also, any information that is sent across your network is encrypted so that only computers that have the key to decrypt the information can read it. This can help avert attempts to access your network and files without your permission. Common wireless network encryption methods are Wired Equivalent Privacy (WEP) and Wi-Fi Protected Access (WPA) and WPA-2.
Change the default administrator name and password on your router or access point
If you have a router or access point, you probably used a default name and password to set up the equipment. Most manufacturers use the same default name and password for all of their equipment, which someone could use to access your router or access point without you knowing it. To avoid that risk, change the default administrator user name and password for your router. Check the information that came with your device for instructions about how to change the name and password.
Change the default SSID
Routers and access points use a wireless network name called a service set identifier (SSID). Most manufacturers use the same SSID for all of their routers and access points. We recommend that you change the default SSID to keep your wireless network from overlapping with other wireless networks that might be using the default SSID. It makes it easier for you to identify which wireless network is yours, if there is more than one nearby, because the SSID is typically shown in the list of available networks. Check the information that came with your device for instructions about how to change the default SSID.
Position your router or access point carefully
Wireless signals can transmit a few hundred feet, so the signal from your network could be broadcast outside of your home. You can help limit the area that your wireless signal reaches by positioning your router or access point close to the center of your home rather than near an outside wall or window.
Aug 03, 2010 | SMC Barricade 7004VWBR Wireless Router
I have a D-Link DIR 615 wireless router i am trying to connect my daughters DS to the wifi but it keeps asking me for a WEP KEY???? i dont know the wep key i put the serial number in and the password but...
WEP KEY
WPA KEY
When you will make WEP key then you have to put this key on your pc first for connect to internet. It is very easy steps & your network will make secure.
First check your network option also.
Right click on your network then you see the property then go to security See dropdown menu If you have wep key then follow these steps if you did not see thi.
WPA is same as WEP
(WEP)
You need to sign in your router first.
1.open a web-browser such as Internet Explorer and enter the IP address of the router (192.168.0.1)
http://192.168.0.1/
2. Select "Admin" from the drop-down menu and then enter your password. Leave the password blank by default.
Now you can see your D-LINK webpage where you find your wep key.
Clik setup then wireless setting
Now you see on this page
1. Wireless Security mode then drop-down-menu Set Enable WEP
2. Authentication - Choose Shared Key.
3. WEP Encryption - 64 Bit.
4. Key Type - HEX
5. Default WEP Key - WEP Key 1
6. Now Make a key( You can choose any password but remember only 10 charcters allowed)
7. Now Save setting. then your router gonna boot up make sure let it boot. It connected after 5 minute.
You should write your password in paper first then you will have to add this key into your pc. network.
You can not connect internet because you have to put these Key(password) into your pc first.
Go to your network connection in your pc Choose your network
Or
You see two computer( internet icon) on the desktop
Right click then connect to network then you see so many network & your network ( Which you create).
Right click on your network then you see the property then go to security choose wep key then put the password(KEY).
WPA
1. Wireless Security mode then drop-down-menu - EnableWPA
2. Clipher type -TKIP
3. Passpharse - create own password here( don't put any personal info there)
Save setting
Device restart.
Now check Network status. Its working now.
Follow youtube video
Jun 10, 2010 | Computers & Internet
What does wep64 key mean and what do i need to do fot the xbox 360 live connection
WEP Wired equivalent privacy is supposed to give the same security as a wired network in a wireless network. 64 means a 64 bit key is required to get the thing working. Look on the bottom of your wireless adaptor for the key it will be in the format xxxx xxxx xxxx xxxx. type it in carefully when requested.
Feb 08, 2010 | Microsoft Wireless Network Adapter Xbox...
How do I put an encryption on my linksys router?
Securing your wireless network is a simple process, which generally does not require a lot of time. This can be done by:
  • Enabling WEP or WPA on the Router
  • Enabling Wireless MAC filter on the Router
  • Disabling SSID Broadcast on the Router
NOTE: The wireless security modes available may vary depending on the model of the router and wireless adapter you are using.
Enabling WEP on the Router
Wired Equivalent Protocol (WEP) is a type of wirelesssecurity which does not change. It provides comparable confidentialityto a traditional wired network. There are two types of WEP you canchoose from:
a. WEP 64-bit: This type of WEP consists of 10-hexadecimal codes. To enable WEP 64-bit, click here.
b. WEP 128-bit:This type of WEP consists of 26-hexadecimal codes hence it is moresecured compared to WEP 64-bit. To enable WEP 128-bit, click here.
Enabling WPA on the Router
Wi-Fi Protected Access (WPA) is a type of wireless securitywhich is dynamic in nature. Meaning, it changes depending on the timerenewal you will specify. Hence, WPA is more secured compared to WEP.
  • Temporal Key Integrity Protocol (WPA-TKIP) – utilizes a stronger encryption method and incorporates Message Integrity Code (MIC) to provide protection against hackers.
  • Advanced Encryption System (WPA-AES) – utilizes a symmetric 128-bit block data encryption
To enable WPA, click here.
Enabling Wireless MAC Filter on the Router
Wireless access can be filtered using the MAC address of thewireless devices transmitting within your network’s radius. You caneither permit or prevent specific wireless computers access to yourwireless network.
To permit wireless computers to connect to your wireless network, click here.
To prevent wireless computers to connect to your wireless network, click here.
Disabling the SSID broadcast is one way of securing your wirelessnetwork. This procedure will prevent other users from detecting yourSSID, or your wireless network name, when they attempt to viewavailable wireless networks in your area. For instructions, click here.
Jul 11, 2009 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
281 people viewed this question
David Payne
David Payne
