Electrically it is fine. The main blower is running, but the fan outside is not. I hear a humming, however. Obviously, the house is hot and nothing is frozen up.
  • 456 Answers
You either need a new capacitor and or a fan. If you
cannot hear the compressor run and it is not tripping
any breakers you may need to install a hard start
capacitor kit
Posted on Jul 04, 2010
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
How do I fix my A/C
can be a bad fan motor, defective capacitor or contactor issue. capacitor is cheapest fix if bad.
May 11, 2014 | Bryant Heating & Cooling
Central a/c fan will not start after flood
replace the fan motor as the bushes are dry and seized up.
Jun 09, 2013 | Heating & Cooling
Ac blower in mobile home starts then stops
e.o oddly i remember seeing an AC blower doing this outside of its system it seems to me the control box on the blower isnt really seeming to know what to do since its all controlled electrically and if its getting mixed inpulses then the control box itself can get confused on knowing what to do such as fan speed and controlling it to turn off and on....most likely the control box isnt working as it should and may need replacement or have an electrical guy check things out
Apr 16, 2017 | Heating & Cooling
The outside unit has power going to it but isn't
maybe it has tripped off on high pressure, as you have have said the fan is not turning so will cause high pressure. now assuming the problem is the fan is not running than check the condition of the condensator /capacitor for the fan motor. if the motors winding is still good replace the capacitor and try it ON.
Aug 23, 2011 | Goodman CKL62AR61 Air Conditioner
Hello i have Carrier Weathermaker 38tkb air conditioner unit. It's about 6 years old and when i got home today, the unit itself wasn't working. Although the blower fan in the furnace inside was blowing,...
The humming noise and dimming of the lights is an indication something in the outdoor unit is locked up or has failed.
Check the capacitor as it may have gone bad. If the capacitor is good, then you either have a failed motor, a failed compressor, or both.
Jul 07, 2010 | Heating & Cooling
Carrier 38tkb not working, but furnace is blowing
It is probably a capacitor problem. Check inside the outside unit. you will see a round cylinder with three groups of terminals on top. If the top of it is dome shaped it probably needs to be replaced. You can check it if you have a microfared tester. However if it is poofed out it probably is bad. If this is not the problem you will probably have to replace the fan motor.
Jul 07, 2010 | Carrier 38CKC036 Air Conditioner
Blower in attic & AC unit outside continuously run
Sorry to hear about your miss-fortune, you are right it is an wiring problem. Can you turn off the blower with the thermostat (cool-off-heat) or what happens when you switch the fan to (auto or on) When you say the outside unit is "rigged" is it mechanically being jammed or electrically? If its mechanically that should be removed (what a crappy thing to do) other wise it will run continuously as you may already know. That is what it sounds like, you should just be able to shut the entire system down by turning off the switch to the furnace. If it is electrically being held closed, he changed some of the wiring around in the attic unit, you better hope he was lazy and jammed a stick in the contactor in the outside unit or else you may need to learn more about HVAC wiring, none the less I would double check the thermostat wires going to the attic furnace there should be nomenclature on the unit or at least somewhat marked. This was probably disturbed when the new blower was installed, by the way that was your initial problem. Good luck and becarful
Aug 17, 2009 | Ruud Matching Split Air Conditioner
Heat pump is humming loud>
When the heat is not on. Go to the T-stat and turn the fan to the on position. With the blower now running is it making the noise? If so you probably either have something in there such as the filter that was mentioned, a piece of paper etc. or one or more of the blades on the blower wheel is vibrating. Don't let the condition persist w/o having it checked out or you may turn a simple fix into a costly one.
Jan 22, 2009 | Heating & Cooling
Fan not turning outside
Is the outside compressor running? Check the fuses in the outside disconnect by the outside condensing unit. Also check the breaker for the A/C in the main power panel.
Jul 06, 2008 | Heating & Cooling
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
