Question about Garden
Troy bilt "horse" 21 hp model #14AT809H766 I replaced the pto belt (upper belt) on deck and the new belt began to smoke. Belt tension seemed good and I verified teh part numbers that the dealer gave me. I checked for obstructions before and after engaging and disengaging belt. Any ideas?
  • 5 Answers
SOURCE: troy bilt horse pto clutch will not disengage
The problem is lack of lubrication in the pto coupling. Losen the two swing bolts carefuly,block the front under the motor. Separate the tine transmision from the housing and grease both sides with as much grease as you can work in. Work the lever as you do this. Should fix the problem.
Posted on Feb 14, 2009
SOURCE: belts slippin on troy bilt horse
Have you adjusted the locking cam for forward. This cam is held in place with one bolt. The further you move it down the tighter it will make the belt
Posted on May 05, 2009
  • 22 Answers
SOURCE: Troy Bilt Tiller tines do not engage
You likely have a clutch problem, never saw one that a simple adjustment would fix. I'd take off the tiller (there are two bolts that hold the tiller portion to the transmission, and check to make sure the clutch is sliding in and out. My hunch is either the lever is loose on the shaft or the allen-head little bolt that they use to shift the clutch has come out. Be sure to grease the clutch while you're in there.
This should be covered in your owners manual. Shame on them if they didn't mention this.
Posted on Jun 14, 2009
SOURCE: where do i find serial numbers on troy bilt horse tillers
On the old Gardenways Horse the serial number is stamped into the top of a little flange on the side of the transmission just to the right (viewed from behind) of where the handles attach. It may be covered in gunk so a douse of mineral spirits and a little scraping will reveal it.
You can download the manual and parts list from the Troybuilt site. Enter "HORSE" for the model and the serial number.
Posted on Aug 06, 2009
MNfisherman
  • 11896 Answers
SOURCE: The deck belt keeps falling
Either the belt is stretched out and needs to be replaced or there is an idler/tensioner pulley that may be weak and not putting enough pressure on the belt.
Posted on Jun 30, 2010
I have a troy bilt 42 inch 17 hp lawn tractor. The problem is when I cut grass and i get in some thicker grass the blades turn off then I back out the blades restart. The engine never bogs down
One or more of your drive belts is in need of adjustment or replacement, maybe. Possibly, your electric (or manual) PTO clutch could also be adjusted. You do have the spring tensioner on the deck engaged, right? You say the engine doesn't bog when this happens so I am inclined to think "clutch" and/or "PTO belt" to the deck and/or the "deck tensioner" are the things to check.
The tensioner will be the easiest, it is a handle on the left side ON the deck. Has a BIG spring on it. Make sure it is engaged.
Is yours a Troy Bilt manufactured in Troy New York or is it another manufacturer (MTD?). Troy Bilt is actually out of business, having sold the Troy name to a variety of makers depending on the model line. I don't have the run down on who makes what any more (tillers, chippers, mowers, blowers, trimmers, etc.), but Troy Bilt of Troy, NY is no more. :-(
I have a 16 HP Troy with 42 inch deck driven through a electric clutch. I also have a "grass pump" on my deck. Important maintenance tips: Keep the bearings greased, keep the deck clean underneath. The belt on the deck should have the tensioner released when you are NOT mowing. Keep the blades sharp and in good repair. Mow with engine at full speed. When you get to areas of heavy growth, slow the tractor down (hydro drive) or reduce to a lower gear (gear drive). NEVER adjust speed using the "clutch" (hydro drive or gear drive). When you engage the blades (electric or manual) always have the engine just above idle, bring the engine speed up slowly to preserve the belts and reduce stress on all components.
I am sure this is the fix for your trouble. If there is anything else or if I missed the ball, please let me know and we will go further.
Thanks for your question @ FixYa.com
May 30, 2011 | Troy Garden
Deck belt broken, l need a diagram to replace new belt on a Troy bilt riding lawnmower, 42 " cut 20 Hp, model # 13AP60TG563. Thanks
You will find the diagram on the left side of the deck as you sit on tractor by left foot. It will be located under the foot pedal that has the routing diagram specifically for your Troy-Bilt mower model. Note that owner's manuals may not have the most current schematic.
Also you can check this link to download the diagram:-
http://www.seapyramid.net/rt/belt-diagram-troy-bilt-riding-lawnmower/
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 20, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
The deck belt keeps falling off of my Troy-Bilt 14AT809H766 Horse riding lawn mower. Why? How do I fix it?
Jun 30, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
I have a 19 hp Troy Bilt Super Bronco with the
sounds like spring tension on top of deck is connected to a bolt post,mine broke and went missing with the spring,blades kept slipping,didnt know how to tighten belt,go figure
May 18, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Need a owners manual for troy bilt 17.5 hp 42 inch pony lawn tractor
HOW TO CHANGE A BELT ON
  • Troy-Bilt 17.5-HP Manual 42" Riding Mower
  • Nov 30, 2009 | Mtd Garden
    I have a model 13aq609g063 troy bilt riding mower. It has a 18hp briggs & stratton, 2 cylinder, ic engine. the engine runs fine, the bottom pulley on the engine for the pto belt turns when running, and...
    Another possibility, is a broken spring or a tight/ rusted idler pivot arm.
    with the engine off & the deck down, engage the pto & pull on the belt to see which pulley is the tensioner
    Nov 07, 2009 | Garden
    Troy Bilt 190cc Z-Start Model 12A-446A011 21"Inch Deck
    You need to remove a pulley to put the new belt on.
    Jim
    Jun 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
    Garden Logo
    348 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    john h
