Question about Quasar SP-2725 27" TV
White line across black screen (setup mode?) model
White line across black screen (setup mode?) model SP-2724E Tried holding the power and action down at the same time and unplugging. Still no change
    Problem Solver:
  • 15 Answers
If line is horizentle check vertical ic supply and out put capcitor if line is vertical check yoke wirsand cap 560k at horizentle yoke and any print brunt
Posted on Jul 03, 2010
On my kenwood receiver vr 707... I'm having difficulties in getting any base for subwoofer. I pluged in the "subwoofer pre-out" like it says in the manual but it seems as if there's no power...
hi,
p { margin-bottom: 0.21cm; }
You have to set the subwoofer setting in you system .for that do the following.
1 .For the remote control, press and hold the TUNER key for more than 3 seconds to switch to receiver mode.
  1. Press the SETUP key to enter the SETUP mode and select SETUP SYSTEM using up arrow or down arrow
  2. Select SP SETUP and press the SETUP key again so that the speaker system indication "SP SYSTEM" scrolls across the display.
  3. Press up arrow or down arrow to select OTHERS and press SETUP key
  4. press the up arrow or down arrow to select the SUBW ON and press SETUP key
    exit the setup and try. Is the subwoofer is working or not
ok
Jan 26, 2011 | Kenwood VR-707 Receiver
In my aficio 2022 appear SC 542 ERROR, contact assistance. what do it mean?
Normally you need to replace both the overheat thermostadts and thermistors in the fuser.
What you can try first is this.
Press Clear All 107 then press and hold the stop button.
The screen will change to SP mode and you want to enter copy sp mode.
You will then look in the "5" section and scroll to 5810 and run that procedure to reset the code.
You then power the machine off and on. If that doesnt work more than likely the overheart thermostadt has gone bad and will need replaced.
Aug 27, 2010 | Ricoh Aficio 2022 Black and White Copier
White dotted lines across newly purchased Sansung 6300.
that is a connector error needs to be reseated but if it is new return it for an exchange
Apr 19, 2010 | Samsung SP-P4251 42 in. Plasma EDTV
Vizio 42 in TV LCD HDTV white line across to of
That white line (usually jagged) is actuallly part of the transmitted picture. However, you are not intended to see it because it is located in what is known as the 5% overscan area. Your TVs today are more than just cable ready... they are a versital, technology filled multimedia display. You can see that line because the screen size or wide mode you are using is intended for 1080p/24 signals. You have 0% overscan with this screen size setting. This allows you to see ALL of the picture, including portions of the picture the broadcaster did not intend for you to see. You can change your screen size using the Wide feature in the Setup menu. See pg.62 of your user manual for details and descriptions of the various wide modes.
Mar 14, 2010 | Vizio VW42LF 42 in. LCD HDTV
Black Screen with white line across the
the vertical IC most likely has failed
Jul 19, 2009 | Televison & Video
Quasar TV sp 2724E Loses the picture
Sounds like a failed vertical amplifier circuit. This is normally primarily contained in an integrated circuit mounted on a heatsink.
There are other possibilities along the line but the one above is the most likely.
Now all you need is a TV repair shop that is still in buisness.
Jan 03, 2009 | Quasar SP-2725 27" TV
Black Vertical Lines in screen
All I can tell you is that you maybe have left your T.V. on a channel that didn't move for so long, or maybe someone else did and it burnt the screen. Plasma's run off of plasma gas to create the great picture and they collect on the screen and stick. What you need to do is go to your menu and look for "screen burn protection" and put it on white and let it sit for 20 minutes. All of one color such as white doesn't harm your T.V. The only way anything burns is like a bright white line in front of a black background.
Oct 26, 2008 | Samsung SP-R4232 42 in. Plasma HDTV
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Mymonitor is black and the on button from the monitor is green and is flashing
i havent seen this question asked, and believe me i have searched. i have compaq presario, windows xp media edition 2005, 64 amd processor, model # SR2017CL, with HP 1703 17" monitor. Prob-put computer in hibernate mode other evening, without turning it off. when i woke up, screen had diagonal lines going across it. i rebooted, well manually restarted, since comp would not respond.
Message comes up white with black writing, essentially, prob with active desktop, restore or turn off. i tried to turn off and screen went back to diag. lines. looks like the horizontal hold of a tv screen is asque. tried adjusting monitor to no avail.
tried a few more times, was fine for a few mins then went to same thing. now when i turn monitor on it blinks red, blue, and so on.
just whole screen that color. so i am at the point where i dont
know if its the comp or the monitor. (i am quite a newby)
ty for any help you can give
ellie
Jan 30, 2008 | HP Pavilion F1703 17" LCD Monitor
Quasar SP-2725 27" TV Logo
213 people viewed this question
Top Quasar Televison & Video Experts
 Grubhead
Grubhead
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
