Question about Frigidaire 24 in. FDB635RF Built-in Dishwasher
Water leaking in front of washer - Frigidaire 24 in. FDB635RF Built-in Dishwasher
  • 5,911 Answers
It sounds like your problem could be caused by a worn door seal. Over time, these seals compress to the point where they no longer seal correctly, or food particles and grime get caught between the door and seal and leave small air gaps. I personally own a Maytag such as yours and experienced the same problem. It turned out to be a tub seal that was too compressed to seal properly.
The following link explains some of the common causes of dishwasher leaks and what you can do to prevent them:
http://www.fixya.com/support/r3555822-my_dishwasher_leaks
If the model number is correct, the part number for a replacement gasket is 154782401.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and have great service. Prices vary between them, so shop and compare. The first three sites I have listed include helpful exploded view parts illustrations to assist you in locating and properly identifying any parts you may need.
This is a very simple repair. If you have questions, or require additional assistance, please post back and let me know. hope this helps you.
Posted on Jul 03, 2010
Headlight washer system leaks out all the fluid just sitting without using the pump button
first check where it's leaking from, if water dropping near front wheel it's leaking from tank first check the rubber grommet for both washer motor 1 wiper washer motor and 2 head light washer motor, both are in the water tank, if your car water dropping from front end under the front bumper it should leaking from washer nozzle in this case need to replace the head light washer nozzle. some time leaking from hose if you check from underneath you can see where it's leaking from,
Nov 20, 2010 | 2000 Mercedes-Benz S-Class
My front loading washer always fills with water when i am not using it
It sounds like one of the automatic water fill valves in the machine is leaking water when washer is off and the valves are closed. There are two manual water supply valves at the wall behind the washer, one for hot water and one for cold. Close the manual hot water supply valve and allow the washer to sit and see if it fills with water. If it does fill, then the cold water automatic fill valve is leaking. If not, then open the hot water manual supply valve and close the cold water manual supply valve. Allow the washer to sit again and see if it fills. If it does then the hot water automatic fill valve is leaking. Replace the leaking valve in your washer. You can order the new valve online using washer brand and model number on a appliance parts web store, or maybe even find it at a local appliance parts store.
May 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire gallery series front load washer leaking water on side where soap dispenser is. Have had two different repair places take a look at it- replaced soap dispenser- still leaks - repair people can't...
turn down the water pressure on the water line to the washer if the water pressure is to high it will splash out of the filler. there should be a vale on the main water line to the washer.
May 19, 2017 | Frigidaire Gallery Supreme Series...
I have front loader MFW9700 Maytag washer. Water
Check the door seal for tears and the drain boot from tub to drain boot for anything that might have put a hole in like a piece of metal from an under wire bra which front loads will spin so fast that the wires come out of the bras.
Feb 01, 2010 | Maytag EPIC MFW9700S Front Load Washer
Leaking water from the front of the washer checked the hoses and they are not leaking
If this is a top load washer the problem is usually the pump. If you can tilt the washer up at the front and support with two pieces of 2x4. Shine a light under the maching and take a mirror to observe. Fill the washer 1/2 full of water and advance the time into the spin cycle. Observe under the maching to see where it is leaking. The pump is located at the front of the washer. If the pump is leaking, replace the pump.
Dec 29, 2009 | Kenmore Washing Machines
Leaking water from front door after cycle is done
If your washer is upstairs it's probably the washer drainpipe or the piping in the walls. Go look.
Oct 02, 2009 | Frigidaire Affinity ATF7000E Front Load...
Water leaking from my front load LG washer
My LG WM2277HB also leaks after 4yrs of use. I found a hole in the front door gasket at the 3 o'clock position. I also have LE errors constantly.
Mar 09, 2009 | LG WM-2277HW Front Load Washer
Water Leak
While I do agree with eagle338 that water could be leaking from the fill hoses and the pump area, the rest of the instructions apply more for a top load Maytag washer, instead of the front load Whirlpool washer you reported.
Most likely you will have a hole in the front boot area (grey rubber seal around where the door seats). If you find such a leak, send me a note back and I'll write you up a how to to change it out.
The second most common source of leaks come from holes in the tub. This is the white outer part that holds most of the water in the machine. You will easily be able to see it when you remove the panel as listed above in the clarification instructions.
On rarer occasions, you can have something stuck in the fill tube that goes from the dispenser to the tub. Somehow small items become lodged in there. There will be a water inlet about the 10 o'clock position of your boot (grey rubber seal). Probe gently in there with your finger to see if a sock or similiar item got spun into this area.
Jul 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Frigidaire 24 in. FDB635RF Built-in Dishwasher Logo
241 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
