Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
My printer won't print from my computer. It is connected right and I ran a Calibration page and printed a demo sheet and all was fine. When I go to print the block that pops up for the printer shows 2 percent on the line and has cancelling on the top that has been there for hours.
  • 52 Answers
If your using windows XP go to start then control panel and on to printers and other hardware look for your printer, right click and set it as the default for your pc.
With windows 7 -- Start/control panel/hardware and sound and click printers then just right click the prineter you have connected and set it as default.
Posted on Jul 03, 2010
I need to calibrate my hp deskjet 3845 but when I click the button to calibrate it says it's lost communication with the device
Hello
Calibration is one of the functions performed from the Printer Assistant icon on the desktop. If the Printer Assistant icon on the desktop has been deleted from the system, the same tasks can also be accomplished from the Printer Toolbox . The Printer Toolbox can be accessed through the Printer Folder or by right-clicking the Printer Icon on the Taskbar
Please follow these steps to calibrate your printer
Double-click the Printer Assistant icon on the desktop. The Printer Assistant menu will appear with a list of options
Select the Tools and Updates option or the Utilities option (depending on your driver version).
Printer Maintenance menu will appear.
Select the Calibrate Printer tab from the Printer Maintenance options
Click the Calibrate tab. The printer will print the first calibration page.
In the Cartridge alignment page, please inspect the straight colored lines in Sections A, B, C and D . Choose the straightest lines in each section to indicate the best cartridge alignment.
In the Page alignment area, please verify Section E . Then, select the bar and the arrow closest to the edge of the page without being cut off, to indicate the best page alignment.
In the Calibrate Device window, enter the selected alignment values in the Pen Alignment and in the Page Alignment fields and click the Continue tab
The second calibration page will be printed now. The page will contain two patterns: a square and a cross . The lines on the patterns should be horizontally and vertically aligned . Click the Done tab if the lines are correct or the Calibrate tab to repeat the calibration process
The first calibration page contains five sets of alignment patterns. The calibration will cover two areas of alignment. The Cartridge alignment is designed to obtain the best print quality and the Page alignment is designed to ensure that the print is aligned correctly on the page.
If the Printer Assistant and its files have been deleted from the system, the maintenance features in the Tools and Updates section of the Printer Assistant are also available in the Printer Toolbox .
Open the Printer Toolbox and perform the services by following the instructions below:
Right-click the Printer Icon on the Taskbar .
Click Open the Deskjet Toolbox option.
Select the Printing Service tab in the Printer Toolbox .
Choose the Calibrate the printer option.
NOTE:HP recommends to use HP plain paper when performing the cartridges calibration process.
NOTE:These printers could work with one or two print cartridges. HP recommends to perform the cartridge calibration process with the two cartridges installed in order to get the best print quality. Anyway, the printer can also be calibrated with one cartridge installed if the customer decides to work in that way.
Jan 16, 2011 | HP Deskjet 3845 InkJet Printer
We havev a hp psc 2310 all in one. when it prints there is a partial shadow print behind the text. Whart should we do
from the printer or from the computer you will have to make a calibration page and then scan it.
or - take out the cartridges and put them back, the printer should make its own calibration page, after it has finished take the printed page and place it on the platen glass and hit the scan boton.
Nov 12, 2010 | HP Office Equipment & Supplies
Printer not printing photos with all colors
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Verify that the label on the ink cartridges is intact, and that the cartridges are not damaged.
  3. Verify that the KODAK Ink Cartridges have not been refilled.
  4. Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  5. Close the printer access door.
  6. Check the printer status monitor on your computer (or the LCD screen on the printer) to determine if there is sufficient ink available for your print job.
  7. NOTE: Once the "Black ink cartridge is low" or "Color ink cartridge is low" message is displayed, print quality can be affected.
  8. Reprint the picture or document that had the quality problem
If still same quality then...
  1. Load inkjet paper into the paper tray.
  2. On the control panel, press Menu.
  3. Select Calibrate Printer.
  4. Select Print Calibration Page
  5. Press Start.
  6. When the print is complete, press Cancel to end the calibration process.
  7. Check the six color bars on the printed calibration sheet.
Are the color bars completely filled with solid color?
If no then:
  1. Press Menu.
  2. Select Clean Printhead, then press OK.
  3. Select Deep Clean, then press OK. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows steady, press OK.
  5. Select Calibrate Printer.
  6. Select Print Calibration Page
  7. Press Start.
  8. When the print is complete, press Cancel to end the calibration process.
  9. When the print is complete, press Cancel to end the calibration process.
  10. Check the six color bars on the printed calibration sheet.
If again No...
then printhead needs replacement... call Technical Support to get it replaced
May 25, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Calibration Page did not print
press copy and photo together . hold down until printing starts then press copy only with calibration page on scanner
Apr 02, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
WONT PRINT CALIBRATION PAGE
Take out the cartridges and turn off the printer. Turn it back on, and THEN put the ink cartridges in. After that, try to print the calibration page.
If this does not work, clean your printer using the cleaning maintenance from your HP printer software
Jan 06, 2009 | HP PhotoSmart 7550 InkJet Printer
My computer is Windows Vista.Printer ishp officejet4215 all-in-one.I started to print from computer saw article ran 26 pages, so I hit cancel after page 1. Now the printer will not print any new matter...
delete the pending print go to the control panel printer and fax andselect your printer double click there its show pending print deleteall or cancel all and and unplug your printer then connect it restartyour computer then check it.
reply me
mujahed@imsindia.co.in
Sep 26, 2008 | HP Office Equipment & Supplies
5300 printer
To calibrate the printer right click on the printer icon and open the status monitor once you open it there is 3 symbols on the top right of the box one looks like a hammer and wrench in an x configuration, next to that is an i for i for about and a ? for help. Click on the x which is Maintenance it will bring up a new box which has 2 options calibrate and printhead cleaning when you chose calibrate it will print a calibration sheet which you then need to put into the scanner portion and press the start button, these instructions will also come up on the screen when you go through the process.
Jun 14, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
NO CALIBRATION SHEET
Hello, you can print a calibration sheet from the front panel of the printer. Hit menu on the panel of the printer and scroll down to calibration printer and hit ok. Then hit ok on print calibration page and it should proceed to print a calibration page. After it is done printing, it will tell you to scan the calibration sheet.
Feb 10, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
96 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
