Question about Garden
I have a Craftsman mower model ##917.256490 with a briggs & Stratton 15.5 hp ohv engine. I put on a new stator and flywheel and it would not start unless I poured gas in the carb. Then it would run for for a few seconds. So I had the carb rebuilt and now when I try and start it it backfires through the carb. I checked the valves and they seem to open fine... Do these engines ever jump time?
Briggs & Stratton engine model # 4455770435E1, need to find out what part number to order to fix alternator? Told our "stater" was bad?
The alternator (P/N 592831) should put out around13-14 volts DC with no load (other than charging the battery. If the voltage drops only when the deck is engaged but not when the lights are on it could be a connection to the mower clutch causing excessive current draw. I suggest covering the fundamentals such as ensure the battery is healthy, ensure all connections are clean and tight before condemning the stator. then and only then would I remove the flywheel to inspect the stator.
Aug 16, 2014 | Briggs & Stratton Briggs Stratton Intek V...
What is the air gap between the flywheel and coil on 22 hp
.030 (thirty thousands). I use brass shim material as it is not magnetic.
Jul 19, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Have to hold chocke out to keep it running
sounds like the needle and seat is dirty within the carb
Aug 11, 2009 | Briggs & Stratton Briggs Stratton Intek V...
How do I clean the flywheel on my Craftsman/ Briggs & Stratton lawn tractor
What is on the flywheel?
You can wash it off with water spray or clean with soapy water. Let engine cool down before cleaning it. Let it dry before running the engine.
Aug 03, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I craftsman 20 hp twin mower quits after waarm up
SOUNDS LIKE A FUEL PROBLEM OR DIRT WHAT OTHER SYMPTONS DOES IT HAVE
Jul 08, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
110 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
