Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
I have an older model F6056-900 Hoover steamvac Spin Scrub Cleaner. My first problem was that I loaned it out to a friend. Anyway she ran over the hose (used for attachments) with her car. I tried using the cleaner for carpet cleaning this morning but when I tried to put the solution tank into place...its loose...won't snap back in like it used to. When I can get it somewhat in place the solution just complete drains out through the bottom fo the tank. The leak is where the small hole on the bottom of the tank meets the hole on the unit itself. I'm wondering if there is a seal missing or something? I hate to dump the unit if there is an easy fix. Thanks in advance
reddevil6
  • 1673 Answers
SOURCE: lost manual
Go to www.hoover.com, there is a link on the left side of the page to download manuals, make sure you have the correct model number.
Posted on Jan 10, 2008
SOURCE: Leaking Hoover Steamvac
Mine did this exact and it turned out my pump was cracked.
Posted on Mar 30, 2008
reddevil6
  • 1673 Answers
SOURCE: Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
Posted on May 26, 2008
SOURCE: My Hoover SteamVac spin scrub #5914-900 will not **** up solution
http://www.hoover.com/pdfs/manuals/F5914900.pdf here is the manual for your model try cleaning the vent inside the plastic container in the front of the machine if its new you may still be under warrenty and contact info for that is on the site above as well!
Godbless
Posted on Jun 21, 2009
SOURCE: I have a Hoover steamvac Dual V carpet cleaner
Corkyron,
Corvetteking is on the right track. However, if the Turbine, which he refers to as the "drive assembly" is locked up, it is possible to remove the screws and clean and lube the 2 bearings inside. The where the fault of my turbine freezing up. A new turbine is about $40 so it's worth the few minutes to open it up, clean and lube it.
If the drive brush, the one with the long square extension, is broken, like mine was, the only thing I have found is to buy the whole brush block at Hoovers.com for about $27. I only need the one drive brush but can't find the part alone.
For a diagram and parts list go here: http://vacuumcleanershop.com/Hoover/Hoover-model-F7412-900.htm
Posted on Jun 24, 2009
How doI hook up furniture/stairs attachment
Hoover Steamvac Spinscrub - How To Attach Hose and ...
? 2:54
https://www.youtube.com/watch?v=XTgoEezUlRs
Mar 13, 2011 - Uploaded by Doug Weeks
... spin tool. Used for stairs and stains etc. hand held. ... Hoover Steamvac Spinscrub - How To Attach Hose and Spin Tool ...Every time I attach the upholstery and then turn the vacuum on, water begins to leak from the bottom.
Hoover SteamVac Connecting Hose & Tools F5915900 ...
? 1:41
https://www.youtube.com/watch?v=heAeez1YlFc
Nov 23, 2011 - Uploaded by HooverVideoGuides
How to properly connect the hose and tools ... Hoover VacuumVideo Guides ... I cant get the water to come out the water isnt coming out the spray part to scrub my furniture ... Get Best Price for Hoover SteamVac Carpet Cleaner here ... for the love of god when not using the hand tool where on the machine ...
Hoover SteamVac Connecting Hose & Tools F5912900 ...
? 1:41
https://www.youtube.com/watch?v=fPU9pXgNo98
How to properly connect the hose and tools ... Hoover SteamVac Connecting Hose & Tools F5912900 F5914900 F591... ... Hoover Vacuum Video Guides .... Hoover Steamvac Spinscrub - How ToAttach Hose and Spin Tool ...
Jan 09, 2016 | HOOVER COMPANY Steamvac Deluxe
My hoover spin scrub has no suction wont pick up water why?
No suction means somewhere in the intake side of the system you have either a blockage or an air leak.
Jan 21, 2015 | Hoover Brand New SteamVac Spin Scrub...
How can I get power switch to work on hoover spinscrub steam carpet cleaner?
Replace the switch.
http://www.ereplacementparts.com/hoover-f5914900-steamvac-with-clean-surge-parts-c-37315_37419_37425.html
Aug 28, 2014 | Hoover SteamVac F5914-900 SpinScrub...
The scrub brushes dont spin anymore
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine gear will have to be replaced. You can access the turbine gear by removing the hood. You can find a genuine hoover replacement part by following the link below. Just find the model number of your Steamvac.
http://www.usavacuum.com/Hoover-SteamVac-Parts-s/105.htm
Oct 23, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
NO DIRECTIONS FOR HOW TO ATTACH AND USE STAIR TOOL FOR MY HOOVER
Here is the link to Hoover's manuals. I could not locate a model F5900-900 But i believe it is F5914-900. Please verify before downloading manual by checking the serial number stick for a model. Its silver and should be on the back or bottom.
Dec 09, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Have a Hoover Steam Vac Spin Scrub, Model # f5858-910
You can order parts from http://www.searspartsdirect.com
Dec 08, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam vac spin scrub
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40488&thid=640907
Posted by mid-nite on Jun 02, 2008
My aunt lost the instructions to her steam vac, and she never got the chance to read them. Do you know how to operate it?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac F5914-900 Spin Scrub Upright. The best thing to get an owners manual is to download the owner’s manual from the Hoover website or to call your local vac dealer or to call the Hoover Factory / Manufacturer to have them send you out in the mail a new owner’s manual for the model you have listed above . the phone 3 are listed below:
. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 02, 2008 | Hoover SteamVac F5914-900 SpinScrub...
May 24, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
85 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
