Question about Dishwashers
Smeg dishwasher with E9 fault code - Dishwashers
  • davidsoriano Sep 27, 2008
    My SMEG dishwasher has E9 code
  • Anonymous Jan 04, 2009
    E9 showing
  • 1462 Answers
SOURCE: E2 error in smeg dishwasher
e2 is overfill or flooded base.
take the bottom front panel off and see if there is water in it and if so, mop it out. if it reoccurs, then you have a leak.
you will see a float device in the front approx middle and this is what actuates e2. if fault is intermittant, try putting a small weight on this - a washer for example.
if e2 is being caused by overfill and not a flooded base, then the water intake moulding needs replacing
Posted on Nov 20, 2008
  • 298 Answers
SOURCE: dishwasher has a overfill problem rinse light flashing
An Idea: the Overflow sensor or float is bad, stuck, disconnected and its messages to STOP filling aren't getting thru to the CPU
This is usually located in the right frony of the machine or in the side wall. Float types get gummed up with 1/2 dissolved soap powder (god what we do tho the water systems) see if it moves. Sensor types have a hole that feels or senses water. If clogged, they lie. Clean out with toothpick and blast with a bit of hot water and air. Retry
If fixed, let me know... if not, see the yellow pages for parts dealers ;-)
Cheers
Posted on Mar 27, 2009
taran_2005
  • 10515 Answers
SOURCE: I have a Smeg DWF410 dishwasher with error message
E9 is a repetative E1 error - flood protection activated. Check tray under machine for leaks. If dry, find youself a nice long cable tie and lift the rubber flap at the back of the sump moulding underr the filters. Proceed as if rodding out the drains - you'll be surprised how much muck and goo comes out. Usually solves it.
If problem still persists, let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 13, 2009
  • 3741 Answers
SOURCE: E9 error on a smeg dwf 66 dishwasher. Can't find
http://www.ukwhitegoods.co.uk/modules.php?name=Forums&file=viewtopic&t=45951 click the link directly also click this link directly to get the exact picture http://www.ukwhitegoods.co.uk/modules.php?name=Content&pa=showpage&pid=102 --------------- also try this open the door, switch it off, switch it on and immediately press the program button 4 times within 3 seconds. (Don't wait for any lights when you switch it on, just quickly press the button 4 times).
The two end lights should light up. Press the program button and one of the lights should go off.
Switch it off for about 20 seconds, switch it on, switch it off for about 20 seconds, switch it on and it should be reset.
If resetting doesn't cure it, check that the base isn't flooded and the anti flood device activated.
If you're getting any other error code don't do the reset, just post the lights that are flashing, 1 being left and 5 being right.
------------- Check for water in the base of the machine, not the tub.
Drain the water from the base, if there is any, and the machine will reset itself.
If there's no water follow the reset procedure as previously described.
You must get the two end lights lit first before you can carry out the rest of the reset procedure.
If you can't get the two end lights lit then it's possibly a faulty pcb.
----------- if by chance its faulty pcb then Faulty PCB.ne pcb costs £120 + VAT + call out charge so not worth doing
Posted on Aug 30, 2009
  • 3247 Answers
SOURCE: A feew weeks ago Smeg
As you know E9 is linked to the water inlet problem.
There are two scenarios here - 1) Are you using the Aqua-Stop safety system? If this is trigerring then it can shut the inlet water. The reason it can trigger is if the flood device located at the base of the dishwasher under the tub is seeing water. Now it is possible the 2 weeks wait for the technician caused the water to dry out and the dishwasher worked on his arrival. But the leak could have started again when it worked once again. So you could have a leaky hose or the door gasket.
2) going by the description of the error codes in this smeg document, I can foresee the error E9 is linked to the water level system which is not able to detect the level required for the dishwasher to start wash cycle. Possible cause is gunk around the sensor that detects the water level in the tub.
Refer a possible solution reported at this forum site.
What I am not clear is why is the dishwasher not doing anything now when you press the start button. Maybe try one thing at a time.
Please post a comment to confirm which way it progressed.
Posted on Oct 26, 2010
Smeg D1 612 CA dishwasher wont run
You may have to give a little more information.
Have a look at the manual, here -
http://www.manualslib.com/manual/343502/Smeg-Di612ca.html
and check for error codes/lights etc (p17; faults E1-E9)
Hope this helps
Oct 28, 2013 | Smeg Dishwashers
Fisher & Paykel DishwasherDW60CCX1 - bought new 22.5.12. Error code E9. How to fix this please, as not in the instructions book!!
The code like E9 or F9 in F&P dishwasher usually implies controller fault. No solution but to call authorised technician unless you know how to replace the controller. Need to have a diagnostic tool to check what is happening. You should still be under factory warranty.
Dec 22, 2012 | Fisher and Paykel Dishwashers
What does the fault E9 mean on our Fisher & Paykel DW60CC dishwasher mean and how do we fix it?
The fault E9 means the controller has a problem. Obviously it is not a complete fault as you are still getting the fault codes. Some key circuit in the controller has become faulty and this prevents dishwasher from working. Usually the controller needs to be replaced. But first try to turn the mains power off and back on after a short delay. This might reset the controller (boot up).
Dec 09, 2012 | Fisher and Paykel Dishwashers
Smeg DW167.1 error code
I HAVE A SMEG DW167.1 AND IT COMES UP WITH A E9 FAULT, DOES ANYONE KNOW WHAT I CAN DO TO SOLVE THE PROBLEM ,THANKS
Jun 22, 2012 | Smeg Dishwashers
Keeps showing check water
Mar 20, 2011 | Smeg STX2 Dishwashers
I have a Smeg DWF410 dishwasher with error message E9
Hope i helped you.
Jul 13, 2009 | Smeg 18 in. DWF410SS Slim-Line...
Showing e9
not solved it why do these things all cost money? only wanted help . maybe cheaper to buy new one thanks
Feb 24, 2008 | Smeg 18 in. DWF409WH Slim-Line...
Dish washer
what does e9 in your manual say
probable leak in machine
Feb 23, 2008 | Smeg 18 in. DWF409WH Slim-Line...
Dishwashers Logo
1,112 people viewed this question
Top Dishwashers Experts
