Am at work on Savin C2820 PS.... loaded drivers to Mac and cannot stop the machine from printing hundreds of blank pages ....
  • Anonymous Mar 27, 2014
    Our Savin C2820 is displaying error code sc555. How do I clear ir? What does it mean
  • 51 Answers
Check whether the print key on ur printer is stuck anywhere
Posted on Jul 04, 2010
My SAVIN 2820 SCAN FUNCTION does not connect to my home network.
If you have updated your OS to Vista, Win 7 or Win 8, update the firmware
Oct 15, 2012 | Savin Office Equipment & Supplies
When asked to print my c5180 all in one ejects blank sheet of paper making no attempt to print
Just click below for more information;
s.gif » Macintosh: All-in-One Ejects Blank Page or Pages in Mac OS X V10.4
Mac OS X V10.4: A blank page or pages emerge from the product when it is turned on. s.gif » A Blank Page Prints at the Beginning of Every Print Job ...
A blank sheet of paper prints at the start of every print job. s.gif » Load Paper
Instructions on loading paper and envelopes. s.gif » When I Try Printing in Windows Vista, My Printer Is Not Available in the List of Printers ...
Windows Vista: The product does not appear in the printers folder when attempting to print on a network. s.gif » HP Photosmart C5180 All-in-One Printer: Manuals
... HP Customer Care | HP Photosmart C5180 All-in-One Printer | Product information HP Photosmart ... One Printer | Product information HP Photosmart C5180 All-in-One Printer: Manuals About these files: These
Hope this may help;
Regards,
VOTIT
Aug 23, 2008 | HP Office Equipment & Supplies
Savin c2824 wont print pdf files
If its showing drivers for a different machine then the first step should always be to completely remove and reinstall the drivers for the correct unit.
Mar 02, 2012 | Savin Office Equipment & Supplies
I'd like to print from a Mac (OS 10.4) but instead of printing the requested page, it keeps printing blank pages on and on and...
Hi first have you installed the correct Mac drivers the default drivers would be winds and if youj installed from disk this may explain...Go to Ricoh.co.uk and then select the downloads tab and network drivers on the right hand tab. then you will have to select correct machine and OS make sure it is Mac. this will guide you to an external site to down load save to a folder and then install from there. Hope this helps A.
Sep 16, 2010 | Ricoh Aficio 1232C Color Copier
Can MAC OSX 10.5.x use Ricoh Aficio 1018D? Do you now alternativ drivers for ricoh aficio 1018D. HP LaserJet 5-Gutenprint v5.1.3 is o.k. for A4 but not for A3
this is an older model copier, however try going to www.savin.com and click downloads then drivers. there will be a tab for drivers, this is 10.5 though not snow leopard. Ricoh/Savin/gestetner and Lanier are all the same copier, but savin site has more mac info than Ricoh site. Usually I have better luck using already installed Mac drivers than Gutenprint, if you type in the ip it should give you a list of preinstalled Mac drivers. I believe the Ricoh 1018 corresponds to a Savin 2518 if that helps. Also use print daemon, not ipp. hope this helps somewhat as Macs are difficult with options and such on most printers. also must use PS3 for best results.
Jan 09, 2010 | Ricoh Aficio 1018D Copier
Savin 2513F, prints PDF files intermittently
I'd try a different driver, if your using RPCS, change to PCL5. You may have to upgrade the firmware in the copier too.
Aug 26, 2009 | Office Equipment & Supplies
Ricoh Adicio on a mac
Your machine requires the Postscript option installed in order to print from your Mac. The printer is printing gibberish because it cannot understand the postscript driver from the Mac. .
Jul 22, 2009 | Ricoh Aficio 2027 All-In-One Laser Printer
PRINTED PAGES ARE BLANK AFTER REPLACING PHOTOCONDUCTOR
The machine should automatically recognize the new PCU. Blank copies would lead me to think you have further problems, charge corona? transfer issues? If you try to make a copy and open the front door real fast when the paper should be at the transfer unit, is there an toner image showing on the drum? If yes, then you have charge but not getting transfer. This is a hard problem to troubleshoot without seeing machine. Anyway good luck, please rate this. Thanks ..... Wait... just had a thought. On the shaft, on the inside of the rear frame, that drives the drum there is a coupling that is spring loaded. Sometimes the shaft gets gunked up and coupling does not pop out not connecting to the PCU, which could cause blank copies and will still say replace pcu. You could add a couple of drops of oil to that shaft to loosen it up if that's the case.
Jun 30, 2009 | Savin Office Equipment & Supplies
Kyocera mita fs 1000+ error pages
install the generic postscript driver and go here to tune it http://localhost:631
Jun 09, 2009 | Kyocera Mita FS 1000 Laser Printer
Dsc328 will not print using a Mac
If your copier / printer does not have postscript 3 option installed, it will not print from MAC. Print a configuration page: "User tools", "Printer features" "list print" (or similar), "configuration page". Check under the heading of "printer languages"......you'll see stuff like "PCL 5c", "PCL 6", "RPCS", etc. If no "postscript 3", it is not compatible with your MAC, and you don't want to know how much that option is for your machine! Ridiculous!
Feb 25, 2009 | Gestetner DSc328 Copier
jasbo
jasbo
