Question about Whirlpool 24 in. GU2500 XTP Built-in Dishwasher
Lime build up hard water sediment build up dirty dishes
    Sergeant:
  • 338 Answers
We live in the country and we have white film all over our dishes especially our glasses. My wife ran a cup of vinegar through the wash cycle and it solved our problems. I am not an expert at this but anything is worth a try. I hope I helped you.
Posted on Jul 03, 2010
I have a kitchenaid dishwasher that doesn't dissolve even liquid soap. At the end of the cycle there is hard compacted soap residue that ends up blocking the holes where the water shoots out and there are...
Try getting some calcium, lime and rust remover. Follow the instructions on the bottle and run the dishwasher empty using only the CLR. Check your incoming water lines for calcium or lime build up.
Sep 17, 2013 | Dishwashers
Whirlpool dishwasher model GU2275XTVQ1 cleans poorly on top only
Check your hose, pump and all water lines for lime scale build up. Sometimes if you dont use some kind of lime away product every few months your machine will/can get lime scale build up from hard water causing it to not properly dispense the water through out your machine. You can also try to run a load with no dishes and no soap but put just lime away in your machine. It might just clear any clogs you might have or starting to get.
Jan 27, 2013 | Whirlpool Gold GU2275XTVy Dishwasher
Calcium & lime build-up on dishes, in dishwasher
Often times well water is hard. This is a problem with residue on dishes. There is a product available for dishwashers that goes in just like the soap and fast dry that aids in the removal of hard water. This product is available at most stores.
Aug 11, 2010 | Dishwashers
The dishes coming out dirty on my Whirlpool Gold Quiet Partner IV. Cycle seems to complete. The soap is being used. Not sure how old it is ... it came with a house I just bought. Any suggestions?
Clean the jets on the unit. Jets are the small openings the water comes out of. Contact Whirlpool, follow their recomondations, or add some CLR or Lime Away to the washer without a load of dishes. Both products remove Calcium Lime and Rust deposits which impede the flow of water, causing your dishes to come out dirty
May 16, 2010 | Dishwashers
Our glasses are really cloudy. How do we clean the inside of the dishwasher?
This may be a hard water issue, but assuming it's not:
Pour 1 liter of white vinager into your dishwasher and run through a full cycle.
If this fails:
Pout 1/2 liter of CLR into you dishwasher and run through 3 full cycles.
N.B. Vinager is preffered as it's non-toxic.
Other possible issues:
hard water, lime/sediment buildup in hot water tank, not using rinse-aids like "jet-dry"
Sep 08, 2009 | Maytag Dishwashers
A humming sound is coming from my gas water heater.
It is probable a lime build up in the bottom of the water heater tank. You can remove the bottom heating element and clean the lime out, keep in mind this sometimes turns into quite a job though. And you may damage the heating element during removal and have to purchase a new element.
Jun 23, 2009 | Rheem 81VP6S/430126 Water Heater
Clogged water dispenser in Bosch dishwasher
Hi, Logmanup (slight bouts with dyslexia, sorry)
By "spinning water dispensers", I assume you mean the spray arms, right? OK... if they are getting clogged with debris it would be nice to know what kind of debris. Pieces of broken glass? Plastic? Lime scale? Iron? And yes, when they get clogged they won't rotate, won't allow pressurized water through and therefore won't clean the dishes.
For the purpose of this solution, I'll assume that there are little white particles clogging up the jets on the spray arms. This indicates hard water and lime scale build up.
Other than completely disassembling the entire motor/pump assy. (you really don't want to go there), the best way to clear this out of the system is to use an over the counter chemical called Dishwasher Magic or something similar. If the lime scale build up is really bad (and it sounds like it is), use a couple of bottles to start with and follow up with a bottle per month thereafter.
As an aside... If I assumed correctly about the lime scale build up, that means that it's also affecting other appliances as well. Mainly, your hot water heater. If you haven't done it before, please read this to perform maintenance on it. And a product something like this for your washing machine.
I hope this was helpful. Let us know if this works or not. If not, please write back and we'll go a little deeper.
Mar 12, 2009 | Bosch Dishwashers
Thick white coating inside dishwasher and on dishes
That's lime build up.Buy some c.l.r. (calcium,lime,rust) remover from a supermarket.Pour a cup in and run a long cycle,you may have to repeat this until it's gone.
Mar 04, 2009 | Dishwashers
Dirty dishes
Try putting a cup of white vinegar in the empty dishwasher & running it on fast wash. Should eliminate film; do you have hard water where you live? If so lime build up could be the problem.
Hope this helps.Cheers.
May 16, 2008 | Dishwashers
Whirlpool 24 in. GU2500 XTP Built-in Dishwasher Logo
146 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
