Question about Sanyo VPC-T1060 Digital Camera
Drivers for my computer to be compatible - Sanyo VPC-T1060 Digital Camera
  • kakima Jul 03, 2010
    Have you considered NOT connecting the camera to the computer?
    The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
    Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sanyo Master
  • 102,366 Answers
Having gone over a month without a response, I assume this is no longer a problem.
Posted on Aug 09, 2010
How do I get my Toshiba PA3761U-1dv2 to work on my computer?
Install the driver and the software onto the computer first, providing that it's a compatible OS. Then attach the usb optical drive. Let the computer detect the optical drive and associate it with the driver. If you attached it first uninstall it and restart the computer and do as I said above. If that doesn't work, try different USB ports, check that the driver is compatible with the OS, if it's an older driver working on a newer OS like Windows 8 try running it in compatibility mode and with administrative rights.
Oct 16, 2013 | Acer Computers & Internet
I just bought an hp 2101nw print server and I cannot use it because the driver is not compatable with windows 7 and it seems that hp has no driver software for windows 7 for this print server. Is there a...
If the OEM is not making a driver then your probably out of luck. You may have to go back down to Win XP or sell or return the item. Not all manufactures have caught up with Win 7 drivers so you need to make sure there is a driver for the equipment you purchase.
Apr 27, 2011 | Office Equipment & Supplies
Webcam compatible forfujitsu life book
All of the cameras are compatible with any computer. The only problem is with its driver. The driver of the camera should be compatible with the operating system of your computer. There are sometimes that the camera manufacturer gives you a driver which is not compatible with the operating system of the computer. However, this is not really a serious problem because any manufacturer has their own website where you can download the updated driver which is compatible to the operating system.
If your camera doesn't work with your computer, then, you need to download or install the driver that came with the camera or go to the website of the camera's manufacturer.
Apr 13, 2011 | Computers & Internet
The computer doesn't detect any sound drivers.
The Motherboard you have talked about supports mostly all the operating systems. If the computer is not detecting the audio driver, most probably the drivers you have installed is not compatible with the Operating System you are using right now. As you have not told what is operating system, I'm not able to find out the proper solution for you. So, I'm giving this link, where you can download all the drivers compatible for your Operating Systems (eg. XP, Vista, Se7en, etc.). For example, if you are using Vista 32-bit, then download the corresponding driver compatible for vista (i.e. Vista x86)....otherwise the driver will never work.
Here is the link for downloading your OS compatible drivers: Download Drivers for Biostar G41-M7
Now install the driver the properly and enjoy working :)
Dec 25, 2010 | Biostar G41-M7 Motherboard - Socket 775,...
I need the software to run it.
The manual and driver for supported OS versions are here: http://www.dxgusa.com/downloads . The manuals for all of their cameras are listed first and then the drivers. They are listed in order so the DXG-572V driver is in the third line, third from the right of the driver section.
The driver may not have been updated from the original which for Windows XP/ME/2000/98SE. In Windows Vista 32-bit the driver may work or the correct driver may be in the OS. For Windows 7 32-bit, use the driver built into the OS. (Microsoft's compatibility center provided the information.)
With the 64-bit versions of these newer versions of Windows, the compatibility is unknown. However, the driver from the DXG site will probably not work without the compatibility mode, if it works at all. For compatibility mode, right click on the exe file and choose Properties, select the Compatibility tab and set it to run as Compatible with an older version of Windows. Then right click and Run as Administrator. Otherwise, keep it on a computer with the older OS, use a dual boot with the older OS or a virtual computer with an older version of Windows. With Win7 Pro or Ultimate, you can use the XP mode for a free virtual computer. (Download and install Microsoft's Virtual PC and then XP mode; install the camera to the virtual computer.) All other methods will need a licensed version of an older version of Windows. The only issue with the virtual computer is that files can't be shared between the two computers directly. Put them on external or optical media to share them with the real computer.
I hope this helps.
Dec 14, 2010 | DXG Technology DXG-572V Digital Camera
I have a computer with windows 7 and when i try to install my us robotics modem it says it is not compatible. I cant hook up to the internet to download a driver for it on that computer.
Old modems are usually not compatible with the newer operating system like Windows 7 because there are no compatible drivers for them.
Best thing is to get a new modem with is compatible with your OS.
Jun 27, 2010 | Computers & Internet
Need driver that is compatible with windows 7
Not compatible or not working well with windows 7?
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
May 15, 2010 | Dell E173FP 17" LCD Monitor
After installing win 7 on my vaio VGN FZ21E the livecam do not work;where can I find the driver for this webcam;the vista driver do not work;
check with the manufacturer's website to see if there is an update for the drivers. some hardware are not fully compatible with W7 as yet.
Nov 09, 2009 | Sony Vaio VGN-FZ21ECEK Notebook
I cant find a driver to the motheboard i have
Here is a link to your motherboard. They don't have the Windows 7 drivers but you might be able to set the driver compatibility to XP. I'm not sure but its worth a try.
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How to change driver compatibility (this example uses Vista)
1. Right click on the driver setup executable file and select the Compatibility tab. Set compatibility settings to Windows XP (Service Pack 2), and set the program's Privilege Level to run as administrator.
2. Install the device drivers and reboot the computer.
3. Right click My Computer, select “Manage” in the new window select Device Manager. Select the unknown item on the list. Right click on the unknown and select Properties, and then select the Driver tab. Select the Update Driver button and let it search for the drivers. A warning will appear regarding the lack of a digital signature. Tell Windows to install the driver anyway.
4. Reboot computer.
5. Search for your xx.exe or open an Explorer window and drill down to c:\windows\wher driver installed
6. Right click on the exe and select the Compatibility tab. Set compatibility settings on the exe to Windows XP SP2 and make sure the executable can run as an administrator
Hope this helps. At least until they come out with the proper drivers.
Nov 08, 2009 | MSI MS-6702E Motherboard
Can't get speakers to work.
Hi...
Mostly of the sound driver now are need a compatibility if your installed driver is not compatible it will affect the hardware. It's better that you will know the model of your motherboard, if you know the model you need to search the model and download the sound driver witch is compatible.
For now the all motherboard are High Definition Audio.
ICmanServer
Jul 30, 2009 | Ozaki DT-500 3-Piece Speaker System...
Sanyo VPC-T1060 Digital Camera Logo
Top Sanyo Cameras Experts
teddyboy
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
